Author Topic: GroovyMAME 0.289 - Switchres 2.22f  (Read 751044 times)
arc11
  • Last login:May 27, 2026, 09:59:50 am
Re: GroovyMAME 0.287 - Switchres 2.22b
« Reply #520 on: May 13, 2026, 01:15:54 pm »
Last year while I was searching for a workaround, I found odd in the lines :
    // determine the scale factor
-   float scale_factor = target_font_height() * scale / one_to_one_line_height;
+   float scale_factor = std::min(target_pixel_height / float(raw_font_pixel_height) / options().font_rows(),
+                        target_pixel_width / float(raw_font_pixel_height) / options().font_rows());
that a division is made between
 target_pixel_width
and raw_font_pixel_height
if I understand correctly this expression the second line should be
target_pixel_width / float(raw_font_pixel_width) / options().font_collumns()
I don't know if  raw_font_pixel_width and font_collumns exist, i just put meaningful names
just an idea....
Calamity
  • Moderator
  • Last login:October 08, 2026, 02:12:30 pm
  • Quote me with care
« Reply #521 on: May 21, 2026, 12:51:55 pm »
Hi arc11,
 target_pixel_width
just an idea....
Yes I understand why the code looks wrong. But it is right. There's no such thing as font pixel width (neither font columns). The only property that's defined for fonts is their pixel height.
The problem is this code in GroovyMAME is meant for integer scaling of bitmap fonts (.bdf fonts). Currently MAME defaults to a true type font that doesn't work so well when integer scaled, specially at extreme pixel aspects as the one you're using for the menu (768x240).
So probably I should make uismall.bdf the default in the provided mame.ini to avoid this problem in the future.
I took some time to replicate (sort of) your setup here, this is how GroovyMAME looks when -uifont uismall.bdf is used. The mode on screen is 768x240 (portrait / rotated).
Steps to create a log:
arc11
« Reply #522 on: May 27, 2026, 10:00:19 am »
Thanks for the reply
with this way of launching mame, the font is readable, but the menu is not as good as with the original mame code
Calamity
  • Moderator
« Reply #523 on: May 27, 2026, 04:58:02 pm »
Hi arc11,
The picture should look exactly like the one I posted (I configured my system with your resolution to do the test). If it doesn't, there must be something else broken with your configuration.
EDIT: Make sure to set font_rows 30 in ui.ini.
« Last Edit: May 27, 2026, 05:39:26 pm by Calamity »
Calamity
  • Moderator
Re: GroovyMAME 0.288 - Switchres 2.22d
« Reply #524 on: June 10, 2026, 02:56:33 am »
GroovyMAME 0.288 is out!
What's new in Switchres 2.22d (June 2026)
  - Lockless latency-optimized audio buffer enabling very low latencies with PipeWire on Linux, and lower latencies overall on Windows [intealls].
  - Set a default refresh for Switchres when no screen device exists (fixes hardlock on KMS).
RobeeJ
  • Last login:Yesterday at 03:43:12 am
« Reply #525 on: June 10, 2026, 03:53:08 am »
Thanks Calamity!
JPetersen
  • Last login:August 14, 2026, 10:46:54 pm
« Reply #526 on: August 14, 2026, 10:47:08 pm »
Thanks for 0.289!  :)
Calamity
  • Moderator
Re: GroovyMAME 0.289 - Switchres 2.22f
« Reply #527 on: August 29, 2026, 03:10:20 pm »
Groovymame 0.289 is out (we had 2 releases this month, use the latest one):
What's new in Switchres 2.22f (August 2026)
- [intealls] Audio latency reduction and code fixes/simplifications:
    * For games not using VIDEO_UPDATE_AFTER_VBLANK, shave off vblank time for audio latency
    * Register minimum count buffer count across both audio updates for emusynclog
    * Update audio at m_vactive_ratio instead of 1.0, pushes audio earlier and reduces end-to-end latency, but maintains non-negative latency without -afd
    * Reduce minimum buffering latency to 0.1 ms, increase skip duration to 1 second, decrease minimum adjustment to 0.25 ms, only really matters for PipeWire
    * Fix XAudio2/WASAPI available() calculation
    * Add mutex for sink registration
    * Fix out-of-bound read resulting from fractional audio updates, fixes gyruss (and maybe others)
What's new in Switchres 2.22e (August 2026)
 - Properly store the current mode in the -nomodesetting case. Fixes redundant mode changes happening when the new mode is equal to the previous one (like with super-resolutions) and the mode change is delagated to the renderer (like with Windows d3d).
ronbin
  • Last login:September 10, 2026, 07:51:10 am
« Reply #528 on: September 09, 2026, 05:48:04 am »
Hi
I have a little problem with groovymame 0.288. I'm using an intel card with super resolutions so I have to force 4:3 aspect ratio. I've changed the "keepaspect" option to 0 in mame.ini but the option is still enabled when I launch a game. If I launch the game with "-nokeepaspect" everything works as expected.
I'm attaching four files
-mame.ini
-switchres.ini
-wrally.txt (log when I launch the game with no options)
-wrally_nokeep.txt (log when I launch the game with "-nokeepaspect")
Calamity
  • Moderator
« Reply #529 on: September 10, 2026, 02:47:49 am »
Hi ronbin,
In mame.ini, look for the option "aspect auto" and replace it with "aspect 4:3". This is required since your desktop resolution is 1280x480 and MAME wrongly assumes your screen isn't 4:3 because of that.
ronbin
« Reply #530 on: September 10, 2026, 04:58:21 am »
Hi Calamity
I've changed the option in mame.ini and now everything is ok.
I had this option set in switchres.ini.
# Physical aspect ratio of the target monitor. Used to compensate aspect ratio when the target monitor is not 4:3
   aspect                    4:3
So didn't care about changing it in mame.ini too.
flybynight
  • Last login:September 19, 2026, 07:07:20 pm
« Reply #531 on: September 19, 2026, 07:04:29 pm »
Holy smokes. The .286 release that introduced emusync is amazing!!
Studying the documentation here:
https://github.com/antonioginer/GroovyMAME/blob/groovymame0286/docs/groovymame/real-time.md#configuring-part-the-real-time-audio-backend
I am using Windows. To avail of the best low latency new features do I need to run groovymame with these parameters or are they set in the mame.ini file?
-sound part
-audio_latency 0
-video d3d11 *
-framedelay 0
-autoframedelay
-nosleep
-tearbar
e.g.
groovymame -sound part -audio_latency 0 -video d3d11 -framedelay 0 -autoframedelay -nosleep -tearbar
* On -video d3d11 the docs read:
"Unfortunately, it was later discovered that this backend adds a full frame of latency on older ATI GPUs —confirmed at least on the HD 5000 series, likely due to legacy drivers"
I'm on R9 380X. does that suffer the frame of latency with d3d11? (If so, what is the best recommendation instead of d3d11?)
Thank you!!
« Last Edit: September 19, 2026, 07:07:44 pm by flybynight »
Calamity
  • Moderator
« Reply #532 on: September 24, 2026, 04:44:27 am »
Hi flybynight,
Like anything else, the params can be passed either through the ini or from command line, up to you.
The R9 380X should have no lag issues with d3d11.
