Author Topic: Looking for an Image for crt using Vga666 for cga resolution  (Read 8900 times)
mamemaniac
  • Last login:March 24, 2026, 08:49:58 am
« on: September 05, 2020, 08:24:30 pm »
Looking to run mame on my arcade machine. Anyone have a lead on a crt image for cga and the vga666 without roms of course?
mahuti
Re: Looking for an Image for crt using Vga666 for cga resolution
« Reply #1 on: September 06, 2020, 10:57:52 pm »
I don't know of an image. And you probably already have the settings figured out, but if not, find an image and add the Gert settings to the boot code.
Code: [Select]
sudo nano /boot/config.txt
For the Gert VGA 666 to work correctly you will need SPI and I2C to be disabled. Verify that by looking in the config.txt for the following two lines:
Code: [Select]
dtparam=spi=off
dtparam=i2c_arm=off
Then add these lines at the bottom of the file
Code: [Select]
dtoverlay=vga666
enable_dpi_lcd=1
display_default_lcd=1
You also need to specify your screen resolution. After the lines you added above you will also have to then add one of the following configurations:
Code: [Select]
#For 1920x1080 60Hz
dpi_group=2
dpi_mode=82
#For 1280x1024 60Hz
dpi_group=2
dpi_mode=35
#For 1024x768 60Hz
dpi_group=2
dpi_mode=16
#For 800x600 60Hz
dpi_group=2
dpi_mode=9
#For 320x240 try these settings
#hdmi_timings=<h_active_pixels> <h_sync_polarity> <h_front_porch> <h_sync_pulse> <h_back_porch> <v_active_lines> <v_sync_polarity> <v_front_porch> <v_sync_pulse> <v_back_porch> <v_sync_offset_a> <v_sync_offset_b> <pixel_rep> <frame_rate> <interlaced> <pixel_freq> <aspect_ratio>
#<h_active_pixels> = horizontal pixels (width)
#<h_sync_polarity> = invert hsync polarity
#<h_front_porch>   = horizontal forward padding from DE acitve edge
#<h_sync_pulse>    = hsync pulse width in pixel clocks
#<h_back_porch>    = vertical back padding from DE active edge
#<v_active_lines>  = vertical pixels height (lines)
#<v_sync_polarity> = invert vsync polarity
#<v_front_porch>   = vertical forward padding from DE active edge
#<v_sync_pulse>    = vsync pulse width in pixel clocks
#<v_back_porch>    = vertical back padding from DE active edge
#<v_sync_offset_a> = leave at zero
#<v_sync_offset_b> = leave at zero
#<pixel_rep>       = leave at zero
#<frame_rate>      = screen refresh rate in Hz
#<interlaced>      = leave at zero
#<pixel_freq>      = clock frequency (width*height*framerate)
#<aspect_ratio>
dpi_group=2
dpi_mode=87
hdmi_timings=320 1 16 30 34 240 1 2 3 22 0 0 0 60 0 6400000 1
If the resolution that you are looking for is not among these then you can check this link.
I have a CGA running at 320 x 240 (not through Gert666) and I'm not doing much fancy to it. I just made a layout for AttractMode to read the text easier.
« Last Edit: September 08, 2020, 09:06:12 am by mahuti »
mamemaniac
« Reply #2 on: September 08, 2020, 06:55:15 am »
Thanks Mahuti !!! I'll check it out.
thomashenry
  • Last login:October 11, 2022, 03:55:21 am
mamemaniac
« Reply #4 on: October 08, 2020, 01:47:38 pm »
The link is dead for the image minus the roms
thomashenry
« Reply #5 on: October 12, 2020, 06:57:14 am »
Same user regularly posts updates, have a look at his posts and I'mn sure there's a version 3.x or higher of the same thing.
