Author Topic: Computer Case or mount pieces seperately?  (Read 2432 times)
ThePaul
  • Last login:August 07, 2008, 02:57:16 pm
  • The Second to The Last Star Fighter
« on: February 13, 2004, 11:34:12 am »
Do most people just toss a computer in a regular computer case in their cab or is it common to mount the mother board, power suply, drives etc.. to the cab?
Stingray
Re:Computer Case or mount pieces seperately?
« Reply #1 on: February 13, 2004, 11:37:23 am »
I belive it's commonly done both ways. I chose to gut a computer and mount the bits inside the cab, myself. Just 'cause I'm a geek.
-S
Lilwolf
« Reply #2 on: February 13, 2004, 12:18:21 pm »
I started mounting mine directly...
Then added a case at one point
Now I have the case outside my cabinet (so I can access it a little faster.
The trougble I had with direct mounting was space and accessing it from the from.  The way the insides where... I didn't have a place for the powersupply on the shelf near the coin doors... (where I wanted my computer / cdrom for easy access)...
I also hit things kinds often when reaching inside to unflick the control panel.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #3 on: February 13, 2004, 12:42:15 pm »
Probably depends on what is more important for you - authenticity or convenience.
I wanted MameNation to look and feel like an arcade machine inside and out, so my 'guts' are mounted to the inside walls.   It can also be moved without having to remove or secure  the PC first.
If I intended on working on the PC a lot, I would probably have opted for a case inside the cab.
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #4 on: February 13, 2004, 12:56:11 pm »
i plan on mounting mine on wood inside, it will look cooler and more arcade machine like
"Owens is the ringleader in the ass hat circus"  D K
hyiu
    • www
« Reply #5 on: February 13, 2004, 01:51:10 pm »
if it matters... I have my computer inside the case inside the cab...
I think if you have enough space... just put the computer (with case in there...) less work.... and in case something went wrong / upgrade / ... etc and you need to pull the computer out... all you need is unplug and pull the whole computer out....
well... my cab has enough space inside and I'm just lazy....
 ;) ;D
fredster
  • It's all good!
« Reply #6 on: February 13, 2004, 01:53:22 pm »
I'd go with the case.  It keeps the parts together and dust off the components to protect it.
I had to take the case off on a cocktail, and it has given me nothing but problems.  It looks cool, but it doesn't move very well.  Any cards sticking off the motherboard giggle around and come loose. Plus there is a layer of dust on everything.
Plus, you can pull it and put a whole new unit in fast if it's in one piece.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #7 on: February 13, 2004, 01:53:35 pm »
Won't you get problems with cooling if you mount the pieces inside the cab? For instance, when I leave my computer case open the harddrives go very hot. They will die a lot sooner if they don't have the cooling airflow of a fan over them.
Chris
    • Chris's MAME Cabinet
« Reply #8 on: February 13, 2004, 01:59:07 pm »
In the first version, I put it in a case, but working inside the cab became a major pain with the case in the way.
So when I upgraded my PC, I went to direct mounting:
The problem with direct mounting is it's difficult to secure add-on cards, so I have an all-in-one motherboard.  This severely limits your audio and video options; probably not a problem for emulation, but could be an issue if you want to play PC games as well.
I notice that some newer cases have the entire back panel mounted to the motherboard tray, and they come off the case as a unit.  If you could get your hands on one of these trays, you could just mount the motherboard and cards in the tray and mount the tray to the wall.
--Chris
nipsmg
  • Last login:Today at 10:35:57 am
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #9 on: February 13, 2004, 02:05:42 pm »
At work, we were scrapping a really crappy case, in which the entire frame (Back piece, hard drive trays, motherboard tray) came out as one unit..
so I'm using that.. ;D makes life easier..
Stingray
« Reply #10 on: February 13, 2004, 02:09:11 pm »
I added a couple of additional, strategicly-placed fans inside my cab to address the cooling issue.
-S
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #11 on: February 13, 2004, 03:14:35 pm »
hey chris do you have any more pics of your monitor supports? i need to do something like that trying to get ideas. whats holding that up in the middle/front?
Chris
« Reply #12 on: February 13, 2004, 03:25:45 pm »
The monitor is just sitting on a shelf that was there when I got the cabinet; there is a 2x4 underneath the shelf for stength, and another 2x4 behind the monitor to keep it from moving backwards.  Both 2x4's are mounted with joist hangers.
That monitor is actually on my desk now; it was replaced by a Wells-Gardner D9100.  It is currently just sitting on the same shelf; eventually I'll screw it down to the shelf and add side supports so the cabinet can be moved without removing the monitor.
--Chris
--Chris
krick
  • Gotta have blue hair.
« Reply #13 on: February 13, 2004, 04:11:38 pm »
Wico has a PCB mounting bracket that screws to the inside of the cab adjusts to accomodate different sized boards.  I'm thinking about getting one...
http://www.wicothesource.com/new2/pages/page15.htm
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
« Reply #14 on: February 13, 2004, 04:48:39 pm »
I totally agree with the above statement and have followed it.
I initially started by mounting the motherboard directly to the inside of the machine, but then changed my mind and went with only the frame.  There are many advantages of using a frame over a direct mount:
- All points on the motherboard are grounded.  Some motherboards require that!  By direct mount, you are not connected the ground!
- There is no chance of PCI cards coming out of the motherboard in the future as you move the cab! (i.e. my SBLive or NIC!)
- Much easier to mount and much less stress on the MB! The metal frame makes the MB more solid and doesn't bend during install (which can brake it!)
But I'd suggest again putting a complete case inside the machine.. You're restricting free air flow around the components by putting the cover on!
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #15 on: February 13, 2004, 09:00:36 pm »
I leave mine in the case.  If I'm staging the machine or doing any major overhauling to it, I find it easier to just take it out of the cabinet and hook it up to a regular keyboard / monitor / mouse.
« Reply #16 on: February 14, 2004, 10:46:13 am »
I have mounted my PC stuff on a removable board, so I get arcade-looks, but it can be easily removed for maintenance etc:
« Reply #17 on: February 14, 2004, 10:48:34 am »
It just slides into the left-hand side thru the front door:
I have holes cut out of the rear panel which line up with the PSU fan + chassis fan.  I *think* it will remain cool enough, although I haven't actually had it running inside the cab yet.  I picked a P4 so that cooling isn't so much of a problem, and I can have slower/quieter fans :)
« Last Edit: February 14, 2004, 10:50:50 am by Minwah »
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
« Reply #18 on: February 14, 2004, 11:16:06 am »
This is how I did it I mounted the pc on a shelf that pulls out. The pc is a rack mount pc so not to take too much space up.
Gary
