Author Topic: GroovyMAME/ARCADE32/64 custom build  (Read 429646 times)
albmm
  • Last login:April 30, 2025, 07:39:06 am
  • Weche OK Baby user
Re: GroovyMAME/ARCADE32/64 custom build
« Reply #440 on: December 12, 2024, 04:54:28 am »
I'll try to fix this. Maybe it won't be hard to do.
Thanks! I will be pending of future releases.
haynor666
  • Last login:June 12, 2026, 12:46:32 am
  • retro maniac
« Reply #441 on: December 15, 2024, 03:13:01 pm »
Just like I mentioned on discord channel - nothing needs to be fixed. My build has no nag but patches are without no nag.
Version 272 is out.
haynor666
  • retro maniac
« Reply #442 on: December 30, 2024, 09:23:20 am »
Looks like code for neogep patch needs update from august. Nobody realized that some games are missing first two vertical lines from left :)
Fix will be with version 273.
haynor666
  • retro maniac
« Reply #443 on: January 02, 2025, 12:20:10 pm »
Version 273 is out.
Lots of changes in neogeo and system1.
xyzhz
  • Last login:June 24, 2026, 07:58:47 am
« Reply #444 on: January 10, 2025, 07:06:29 pm »
patches_273
273_03_various_fixes.diff
273_04_various_changes.diff
GroovyMAME-gm0273sr221d source code Mame-0273 is as follows
« Last Edit: January 12, 2025, 08:41:56 pm by xyzhz »
haynor666
  • retro maniac
« Reply #445 on: January 19, 2025, 09:27:40 am »
Try patch -p0 -E for my patches
patch -p1 is for only groovymame patch
sean_skroht
  • Last login:March 06, 2025, 02:05:36 am
« Reply #446 on: February 12, 2025, 12:20:47 am »
Hi haynor666,
Thanks for maintaining your custom version of Groovymame.
I had been using 0.272 and I am now using 0.273. Unfortunately, both versions (and possibly earlier versions but I haven't used them) display an error when running Galaxian.
The error is as follows:
Driver jumpbugbc (file galaxian.cpp): 2 errors, 0 warnings
Errors:
   Zilog Z80 device 'maincpu': program space memory map entry writes to nonexistent device ':cust'
Driver jumpbugbrf (file galaxian.cpp): 2 errors, 0 warnings
Errors:
This error doesn't appear in mainline MAME nor in Calamity's Groovymame. Galaxian still runs but the error box is annoying.
Thanks mate.   :D
haynor666
  • retro maniac
« Reply #447 on: February 13, 2025, 02:43:07 pm »
That's because this game uses extra sound for jump. It's imported from ARCADE32/64. Perhaps I did this wrong or it's just work like this :/
haynor666
  • retro maniac
« Reply #448 on: February 15, 2025, 07:22:00 am »
Version 274 is out.
albmm
« Reply #449 on: March 18, 2025, 09:06:12 am »
- visible area modifications for many games in neogeo driver (mostly from 320x224 to 304x224 but for four games even to 288x224 - Zed Blade, Goal!Goal!Goal!, Gururin, Zupapa)
Hi friend. Take acount that there are some 312x224 neogeo games:
- Ninja Combat
- 2020 Super Baseball
- Last Resort
- Panic Bomber
I have tested Last Resort and your patch cuts some lines of the ingame area.
Besides this, a fix for Gradius 4 would be great.
Thanks for your work!
« Last Edit: March 26, 2025, 09:05:38 am by albmm »
Endprodukt
  • Last login:June 22, 2026, 03:47:40 pm
« Reply #450 on: March 21, 2025, 08:17:53 pm »
Are we going to see .275 by any chance? That mame version has some major fixes to some drivers :)
haynor666
  • retro maniac
« Reply #451 on: March 26, 2025, 03:56:03 pm »
In the works ;)
- Ninja Combat
- Last Resort
- Panic Bomber
Should be fine for most games in version 275.
« Last Edit: March 26, 2025, 03:57:48 pm by haynor666 »
haynor666
  • retro maniac
« Reply #452 on: March 27, 2025, 11:44:21 am »
Version 275 is out.
Endprodukt
« Reply #453 on: April 04, 2025, 02:54:19 am »
haynor666
  • retro maniac
« Reply #454 on: April 20, 2025, 01:00:05 pm »
Version 276 is out.
haynor666
  • retro maniac
« Reply #455 on: May 04, 2025, 05:59:42 am »
Version 277 is out. This time almost instantly :)
Endprodukt
« Reply #456 on: August 19, 2025, 10:36:28 am »
278 and 279 are out! :applaud:
haynor666
  • retro maniac
« Reply #457 on: August 22, 2025, 03:30:55 am »
Version 278 is out.
Version 279 will be available soon ;)
Endprodukt
« Reply #458 on: August 22, 2025, 03:42:04 am »
Thank you very very much
haynor666
  • retro maniac
« Reply #459 on: August 22, 2025, 09:45:52 am »
And version 279 is out ;)
Endprodukt
« Reply #460 on: October 05, 2025, 09:17:45 am »
281 pretty please 🥺?
Before I keep bothering you, can I compile this myself?
haynor666
  • retro maniac
« Reply #461 on: October 19, 2025, 09:17:58 am »
Version 280 is out. Re-create diffs and compile version 281 will take probably 3 or 4 hours.
Endprodukt
« Reply #462 on: October 19, 2025, 09:57:28 am »
It's very much appreciated!
haynor666
  • retro maniac
« Reply #463 on: October 19, 2025, 02:01:19 pm »
Version 281 is out.
Endprodukt
« Reply #464 on: October 19, 2025, 02:22:03 pm »
You are the best, thank you so much!
haynor666
  • retro maniac
« Reply #465 on: December 31, 2025, 08:28:41 pm »
Versions 282 and 283 are out.
haynor666
  • retro maniac
« Reply #466 on: January 09, 2026, 02:33:24 pm »
Version 284 is out.
smeatr0n
  • Last login:June 06, 2026, 05:14:24 pm
« Reply #467 on: January 17, 2026, 10:12:39 am »
Upgrading my Mame cabinet with the latest releases (I'm a couple years behind). All fresh new Romset, everything configured and working BUT 0.284 gives me a driver error message for karnovr.cpp when opening neogeo games. Something about non-sequential bios. This message does not appear when launching from the OG Mame exe. Any ideas?
Edit: For whatever reason, if I launch through a front end this message doesn't appear. So for my use this is not a deal breaker. Still seems to work just fine.
« Last Edit: January 17, 2026, 10:52:03 am by smeatr0n »
Recapnation
  • Last login:May 03, 2026, 05:29:57 am
    • Eiusdemmodi
« Reply #468 on: February 23, 2026, 12:07:29 pm »
Not sure if this falls within the scope of this build, but there's someone working on fixes for CV-1000 slowdowns which are being added to unofficial builds as they indeed seem to improve the current emulation (despite not being an ultimate solution):
https://github.com/CoffeePope/mame-sh34/
haynor666
  • retro maniac
« Reply #469 on: April 17, 2026, 03:59:27 pm »
I'm sorry for lack of updates and communication. I'll compile all previous versions at the beginning of may.
Sh4 iprove is interesting. Is HBMAME or ARCADE32/64 has this code implemented ?
Recapnation
    • Eiusdemmodi
« Reply #470 on: April 26, 2026, 12:45:25 pm »
I think the fixes were meant to be added to official MAME, supposedly for 0.287, but I've been a bit out of the loop lately. Give me some time to check it out and I'll post back.
Recapnation
    • Eiusdemmodi
« Reply #471 on: April 26, 2026, 06:25:47 pm »
So it seems they were:
https://git.redump.net/mame/commit/?id=b7c814a4a35fa22a07950a9a29dd2a75bd237b35
Found out MAME's not supporting Windows 7 anymore, though?
https://www.mamedev.org/?p=563
  • Last login:Yesterday at 11:27:36 pm
« Reply #472 on: April 26, 2026, 10:20:22 pm »
Robbbert found a workaround.  Not sure what it is, though.   :dunno
I did try out the possibility of fixing the windows 7 problem and it turned out to be quite simple. So the solution exists should anyone be interested.
Anyone interested should reply to his post in that other thread since he has opted to disable PMs and emails via his BYOAC account.
https://forum.arcadecontrols.com/index.php/topic,170214.msg1780927.html#msg1780927
haynor666
  • retro maniac
« Reply #473 on: April 27, 2026, 11:26:39 am »
Version 285 is out.
Sources for version 286 are also out but give half an hour to compile executable.
EDIT. Executable is uploaded.
« Last Edit: April 27, 2026, 12:17:06 pm by haynor666 »
haynor666
  • retro maniac
« Reply #474 on: April 27, 2026, 04:04:11 pm »
And version 287 is finally out.
I added Pleiads shoot sample support, imported as always from ARCADE32/64 :)
Recapnation
    • Eiusdemmodi
« Reply #475 on: April 27, 2026, 05:27:29 pm »
Ah, missed the thread. Thank you!
haynor666
  • retro maniac
« Reply #476 on: May 19, 2026, 02:21:02 pm »
For a long time I applied patch to fix Windows XP. These seems to be obsolete.
I don't know how many people need but is it's easy to implement and it will not break any functionality I may use it in my build as well.
I have Arcade PC with Windows 10x64 si I cannot test it personally.
smeatr0n
« Reply #477 on: June 06, 2026, 08:41:26 am »
Will there be a 0.288 release? I'm starting the process of a new build :)
haynor666
  • retro maniac
« Reply #478 on: June 06, 2026, 12:29:56 pm »
So far official groovymame 288 is not yet released. We will have to wait :)
haynor666
  • retro maniac
« Reply #479 on: June 10, 2026, 02:45:19 pm »
Version 288 is out.
