Author Topic: is there a jamma board with sd reader for mame?  (Read 6988 times)
Automark
  • Arcade in Spain ?
« on: September 02, 2014, 08:57:33 am »
Hi,
I just wondered. Is there a jamma board like the 60-1 but with no games build in. But with a usb or sd card reader.
I think it would be great just put a mame rom on that sdcard or usb stick, and that the game boots like an original game. So without any frontend whatsoever.
I've read somewhere that the 60in1 also runs on a mame version, so this should be possible.
The ArcadeSD works differently -I think-
Is there something like this? I think it would be great, and I would prefer something like this, no need for a power consuming pc etc etc.
  • Last login:Yesterday at 07:04:52 pm
Re: is there a jamma board with sd reader for mame?
« Reply #1 on: September 02, 2014, 10:32:43 am »
If you disable all but 1 game on the 60 in 1s, there's no front end.
  • Last login:April 15, 2026, 12:32:32 pm
« Reply #2 on: September 02, 2014, 10:35:49 am »
Hi,
For what I think you want, the ability to run like any game, no. The ArcadeSD is close, but it runs specific games. You might be able to hack one of the XXX-in-1 boards, according to KLOV, but you need to be a hardcore Linux code monkey, apparently.
DaveMMR
« Reply #3 on: September 02, 2014, 03:36:53 pm »
There was someone developing a Jamma board for just that purpose but I don't know whatever became of it.
IAmDotorg
  • Last login:April 27, 2015, 03:05:37 pm
« Reply #4 on: September 02, 2014, 03:49:36 pm »
Most of the boards are pretty lousy and underpowered. You'd probably get just as good (if not better) results using a Raspberry Pi, a J-PAC, and a $10 HDMI->VGA adapter.
You'd be looking at maybe $120 or something, all up. That's less than a lot of the xxx-in-1 JAMMA boards, and if the Pi is too slow someday, you can replace it with a $100 PC.
Generic Eric
« Reply #5 on: September 02, 2014, 04:59:12 pm »
openjamma.org
Their FAQ has a target release date of AUG2013.  I got the stickers.  It seemed like it was going to happen, at least to that point.
http://forum.arcadecontrols.com/index.php/topic,130172.0.html is the initial announcement.  The facebook page linked on the openjamma.org page doesn't load.  They have made no tweets.
« Last Edit: September 02, 2014, 05:05:39 pm by Generic Eric »
sharpfork
    • KADE
« Reply #6 on: September 02, 2014, 05:12:44 pm »
Automark - What kind of video output are you looking for.
I got the stickers.
Stickers?  I want stickers!
I called the openjamma vapourware on reddit and the guy who was posting about it got all pissed off at me and gave me a hard time via PM.
« Reply #7 on: September 02, 2014, 05:42:01 pm »
I hate to say it, but I think you're right on that one. I was looking forward to it, too.
jimmer
  • Last login:February 17, 2025, 02:48:38 pm
  • I want to play Defender like at the arcade.
« Reply #8 on: September 02, 2014, 07:21:29 pm »
What are you looking for that you can't do with a PC that autoruns a specific game in MAME ?
On forums jimmer speaks for himself as a Defender fan, not as proprietor of www.jbgaming.co.uk  << Is that advertising or disclosure ? or both ?
DaveMMR
« Reply #9 on: September 02, 2014, 08:35:28 pm »
openjamma.org
Thanks Generic Eric.   I got a little lax with the searching because I was at work.
Oh well - that looked like a fine idea.  I do know feature creep reared it's ugly head on that drawing board.
« Reply #10 on: September 02, 2014, 08:37:20 pm »
Just sticking once custom PCB in a JAMMA cabinet and having it work like that, without a separate computer or encoder, perhaps?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #11 on: September 03, 2014, 04:15:31 am »
Motherboards with JAMMA on-board are readily available in the coin-op trade. We have thought about reselling them a few times.
But we have not owing to various reasons: They are really expensive, and they are always a few years behind current PC technology and are low-powered units. Using a J-PAC and a standard micro-ATX board is much cheaper and more versatile.
matsadona
« Reply #12 on: September 04, 2014, 07:27:34 am »
I have two of these boards, that have a compact flash drive. It is based on a DOS frontend that can be tweaked to add other ROMs.
The hardware is really old and weak, but upgrading the CPU and RAM makes it a little better, but in reality it only runs the classics without flaws.
The concept is really great though, with a standard PC motherboard in the bottom, and then a Jamma I/O board on top.
IAmDotorg
« Reply #13 on: September 04, 2014, 09:27:38 am »
Here's a free product idea for you -- a mounting frame that has the J-PAC and mounts a Micro-ATX board. The USB headers are all standard on them, so in theory you'd be able to just screw the MicroATX board onto it, plug a jumper between the JPAC and the mobo's USB2 header, patch the VGA across and give it power. For bonus points, add an interface to the J-PAC that can be wired into the ATX power button connectors, too, so you can power on/shut-down with a shifted button combo or something.
nitrogen_widget
« Reply #14 on: September 04, 2014, 11:00:44 am »
Less than that.
depending on what game & how many inputs it needs.
you can wire the controls directly to the GPIO pins & you can fit a console only OS that autoboots one game on a 1gb sd card.
If you use an old crt TV pi has the RCA out.
If you use an LCD panel you can use an HDMI to DVI adaptor.
« Reply #15 on: September 04, 2014, 02:46:54 pm »
This man knows where it's at. Step two, legit-looking barcade.
