Author Topic: Control Panel Overlay - Apply first, then drill?  (Read 2001 times)
newmantjn
  • Last login:June 16, 2016, 01:36:30 pm
« on: August 07, 2014, 07:45:38 pm »
I have a Stargate CP that I am ordering a Streetfigher overlay for.  I re-designed it a little and I have a paper mock up cut out and taped on.  It looks fine.
I have filled all the holes and primed the CP, so at this point, I have a blank slate to work with.
I have ordered a 1-1/8" Forstner Bit from MLCS.  I have a drill press to use it in.
My thought was to apply the CPO when it comes and then drill the holes through both the CPO and the wood at the same time, using the Forstner bits, which are known for their sharp edges etc.  This would ensure a perfect line up.
Thoughts?  Anybody ever do this?
  • Last login:April 15, 2026, 12:32:32 pm
Re: Control Panel Overlay - Apply first, then drill?
« Reply #1 on: August 07, 2014, 07:47:05 pm »
I wouldn't. I've seen overlays get ripped like that.
Slippyblade
« Reply #2 on: August 07, 2014, 07:54:01 pm »
I'm with Yots on this.  If you need to, lay the CPO on the CP and use a tiny drill to create some pilot holes in the centers of your button locations.  Then drill the wood bare.  Attach the CPO and use a razor to cut out the holes.
« Reply #3 on: August 07, 2014, 08:03:23 pm »
^^^^ listen to my homeboy Slippyblade
Louis Tully
« Reply #4 on: August 07, 2014, 08:21:49 pm »
« Last Edit: February 12, 2015, 05:21:40 pm by Louis Tully »
shponglefan
« Reply #5 on: August 08, 2014, 12:01:02 am »
+1
« Reply #6 on: August 08, 2014, 12:12:39 am »
Actually, this is the thread where I saw it happen, but unfortunately the photos aren't available anymore. But read the text to see what happened.
EMDB
  • Project RetroCade
« Reply #7 on: August 08, 2014, 04:37:58 am »
I first drilled the holes (using the drill template I ordered seperately), than applied the overlay (used a flashlight to light from below to position the overlay) and finale used a router to cut out the holes in the overlay:
newmantjn
« Reply #8 on: August 08, 2014, 07:04:46 am »
Thanks for the information guys.  Drill first it is.
@EMDB - Did you use a laminate trimmer for that?
Benzinbruder
  • Last login:January 10, 2016, 07:38:04 am
  • I want to build my own arcade cabinet!
newmantjn
« Reply #10 on: August 09, 2014, 11:58:29 am »
Very nice.  Thanks for the link.
