Author Topic: .  (Read 2954 times)
ChanceKJ
« on: February 26, 2014, 02:42:15 pm »
« Last Edit: March 18, 2021, 11:39:04 pm by ChanceKJ »
JDFan
Re: Serial Number Plate Dimentions?
« Reply #1 on: February 26, 2014, 05:40:53 pm »
Depends on what size material is obtainable at the best pricing  -- and how many plates can be made from a single sheet of material. (ie. if using full sheet 8.5x11" sheets of stickers and 1 foot x 2 foot aluminum sheets ) might as well size them to get the best layout to use the sheets of material with minimum waste and get the most plates.) :dunno
The one I won from Corybee for my bartop is 3 3\4" x 1 3\4"
« Last Edit: February 26, 2014, 05:44:43 pm by JDFan »
« Reply #2 on: February 27, 2014, 12:21:37 am »
Did CoryBee die?
ChanceKJ
« Reply #3 on: February 27, 2014, 12:45:31 am »
« Last Edit: March 18, 2021, 11:39:09 pm by ChanceKJ »
ChanceKJ
« Reply #4 on: February 27, 2014, 01:06:59 am »
« Last Edit: March 18, 2021, 11:39:20 pm by ChanceKJ »
  • Last login:April 15, 2026, 12:32:32 pm
« Reply #5 on: February 27, 2014, 09:36:16 am »
Daaaaaammmmm..... that IS big. Looks nice, but big.
I made the same mistake myself early in the process of designing my own. Through trial and error, I've found that anything wider than 3 inches starts to look too big. I design my plates at a 3"w x 2"h ratio, and that looks normal.
jdbailey1206
« Reply #6 on: February 27, 2014, 09:37:47 am »
Did CoryBee die?
Yeah I haven't seen his antics around here in a while.  The forum says he was last active two days ago but I haven't really seen anything posted from him since Christmas.
Chance - That plate seems really big.   :o  As you can see below mine is laying on a cutting mat with 1x1" squares and mine only measures to be 2x4".  Your's looks to be close to 6x4.  Which is the size of a normal photograph.  I personally would size it down but that's me.
« Last Edit: February 27, 2014, 09:44:01 am by jdbailey1206 »
ChanceKJ
« Reply #7 on: March 02, 2014, 02:20:50 am »
« Last Edit: March 18, 2021, 11:39:27 pm by ChanceKJ »
CoryBee
  • Bopity Boopy
« Reply #8 on: March 04, 2014, 08:37:12 am »
Did CoryBee die?
---fudgesicle--- man.....Couldn't start with "Maybe he is on vacation"
« Reply #9 on: March 04, 2014, 09:15:08 am »
Did CoryBee die?
He lives!!! :cheers:
jdbailey1206
« Reply #10 on: March 04, 2014, 09:43:21 am »
yeah, it's big, it's 3x7"  but really i don't mind it.
