Author Topic: How to play rotary joystick games without a rotary joystick?  (Read 21236 times)
fleskebacon
  • Last login:November 22, 2024, 01:58:55 pm
« on: February 08, 2014, 06:11:53 am »
How do you play rotary joystick games like Ikari, Midnight Resistance, Heavy Barrel etc. without a proper rotary joystick? I know there are joystick hacks for a couple of these, but that's beyond the point. I have a six button layout, and one spinner.
It's not gonna be optimal in any case, but what is, in your opinion, the best way to make this work with a regular joystick, buttons and a spinner?
I've tried using buttons for turning, works ok, but not great. Kept tinkering with the sensitivity settings without really finding a setting that worked well.
Using a spinner in addition to buttons and joystick requires either three hands(!) or incredible dexterity.
What do you prefer, and what settings do you use?
  • Last login:Today at 03:56:07 am
Re: How to play rotary joystick games without a rotary joystick?
« Reply #1 on: February 08, 2014, 06:54:47 am »
Here's one approach that works great for Xybots.
(I know . . . not a true mechanical rotary game, but same principle applies)
With a 6-button layout like this . . .
123
456
 . . . map the buttons this way:
1. Turn left
2. Fire
3. Turn right
4. Zapper/Start
IIRC 3 is the largest number of player buttons on rotary joystick games. (list here)
EDIT: You may also need to change these MAME settings.
« Last Edit: February 08, 2014, 07:05:18 am by PL1 »
fleskebacon
« Reply #2 on: February 08, 2014, 08:15:58 am »
Hey!
Positional Digital Speed = 0
Positional Sensitivity = 100
This made my day. Cannot believe I haven't tried this! Thanks! :)
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
« Reply #3 on: February 08, 2014, 09:05:52 am »
Though far from ideal, I've used a spinner and a flight stick together.
Brian74
  • Yep... I built that!!
« Reply #4 on: February 08, 2014, 11:18:44 am »
I just use my rotary's connected to two kades!
« Reply #5 on: February 08, 2014, 04:41:40 pm »
Hey!
That's exactly how I felt when Degenatrons pointed these settings out.   ;D
GeoMan
  • Last login:April 05, 2026, 04:11:59 pm
« Reply #6 on: February 08, 2014, 07:30:09 pm »
I am using one of the controllers i built for these games:
ark_ader
  • I glow in the dark.
« Reply #7 on: February 08, 2014, 11:14:40 pm »
I use a cheap PC USB Flight joystick like the one below.
Then map the dial left and right to the buttons on the joystick.  Plays great and you can pack away easily when finished.
DOT needs a spinner but this joy works as good as the DOT joy.
Might look a bit tacky but this is BYOAC after all.   ;D
clok
  • Last login:April 03, 2018, 10:58:39 pm
  • I can play PacMan till the screen splits!
« Reply #8 on: February 11, 2014, 03:28:37 pm »
Have not tried it, but couldn't you map it somehow like a Smash TV? second stick rotates? I spose its stepping so there is no way to make it point the dir the stick is.. it would just step through the clicks.
« Reply #9 on: February 11, 2014, 03:39:00 pm »
The only problem with using the "two stick" method for rotary games is pressing the player buttons to shoot, throw grenades, etc. while your hands are on the sticks.
clok
« Reply #10 on: February 12, 2014, 10:15:51 am »
I was thinking that too. but there was a post here about making  button top sticks.. I myslef would like it for Battlezone and the few games where 2 sticks (my CP is 4 player so I can play 2 player SMASH TV) work for that. But again, since its a once click 1 rotation click, could it be mapped to one?  it would seem any click would just rotate it one spot?  I like the idea, but can it be done?  Ikari Warriors, Front Line.. heck some good way to play Forgotten Worlds would be cool.. I have mine mapped to 2 joysticks.. but the precision that spinner gave.. hard to give that up.
« Reply #11 on: February 12, 2014, 11:07:48 am »
Try Ikari Warriors with this map for two sticks.
The first (left) stick controls up/down/left/right motion.
The second (right) stick controls:
*Left - turn left
*Right - turn right
*Up - fire
*Down - grenade
Usng the MAME default settings for Positional Digital Speed and Positional Sensitivity appears to work well for a setup without a rotary joystick. (I wondered why they used those settings. :P) If you press and hold, you'll continue to turn.
If you use the Positional Digital Speed =0 and Positional Sensitivity =100 settings mentioned earlier, one press right will turn you clockwise one position. Another press will turn you clockwise another position. You'll have to press/release for each position you want to turn.
For Fogotten Worlds, you can use either an 8-way joystick and a TurboTwist High-Low or a top-fire joystick and a spinner.
The thought of playing it with 2 joysticks . . .   :dizzy:
ckovanda
  • Newbie
  • Last login:August 05, 2014, 02:19:36 pm
« Reply #12 on: March 05, 2014, 03:42:36 pm »
I have a joystick/spinner setup and what I do for Forgotten worlds and other spinner games where you only have one fire button is go into the mame controls for the game and set the fire button to "up, down, left, right, right/up, right/down, left/up, left/down, mouse_x"  so essentially every movement action via the joystick or the spinner fires.  then it's only a matter of dialing in the spinner sensitivity to where I like it.
I also use a similar technique with Assault, a game with double firing joysticks.  I just set the fire button to all possible joystick positions.
