Author Topic: .  (Read 2970 times)
ChanceKJ
« on: December 14, 2013, 11:46:29 pm »
« Last Edit: March 18, 2021, 11:50:59 pm by ChanceKJ »
brad808
  • Last login:May 22, 2023, 08:18:15 pm
Re: Power button wiring question.
« Reply #1 on: December 15, 2013, 09:13:26 am »
use a double pole momentary switch so that they are each on their own and not touching each other just to be safe.
DarakuTenshi
    • Card Fighters Project
« Reply #2 on: December 15, 2013, 09:13:57 am »
My question is what grade of wire would you use for something like that.
« Reply #3 on: December 15, 2013, 09:40:00 am »
Yeah, it would need to be a DPST switch, you don't want those circuits connected to each other. Wire size... I'd say anything down to 26 gauge should be fine.
  • Last login:Today at 07:23:14 am
« Reply #4 on: December 15, 2013, 12:16:41 pm »
The only possible downside to this 2-in-1 switch design is when one is on and the other is off -- if you push the button, it will toggle both of them leaving one off and the other on.
One way this could happen is if the TV or computer powers up automatically when power is applied. (You did test them and check BIOS/menu settings already, right?)
ChanceKJ
« Reply #5 on: December 15, 2013, 02:33:14 pm »
« Last Edit: March 18, 2021, 11:51:05 pm by ChanceKJ »
« Reply #6 on: December 15, 2013, 02:37:50 pm »
Easiest solution... Smart strip.
ChanceKJ
« Reply #7 on: December 15, 2013, 03:33:24 pm »
« Last Edit: March 18, 2021, 11:51:11 pm by ChanceKJ »
« Reply #8 on: December 15, 2013, 06:34:24 pm »
I don't think them make those LED light ring buttons in a double pole config.
The search terms to use are "dpst" or "dpdt" and "vandal switch" -- Digi-Key has pretty good prices on them.
Pretty sure this one in blue will fit your needs -- datasheet here and schematic here.
« Last Edit: December 15, 2013, 07:00:12 pm by PL1 »
ChanceKJ
« Reply #9 on: December 16, 2013, 02:14:57 am »
« Last Edit: March 18, 2021, 11:51:16 pm by ChanceKJ »
mgb
  • Last login:March 25, 2026, 09:52:08 pm
  • North East, US
« Reply #10 on: December 16, 2013, 11:01:59 am »
If you find the switch you really want to use but its single pole,
You can always use a dpdt relay to split the two
ChanceKJ
« Reply #11 on: December 17, 2013, 04:12:06 am »
« Last Edit: March 18, 2021, 11:51:21 pm by ChanceKJ »
« Reply #12 on: December 17, 2013, 11:57:31 am »
White wire is neutral -- in plumbing terms, it's like a drain.
Black wire is hot -- in plumbing terms, it's like a faucet.
To turn the faucet on and off, put your latching switch on the black wire. (just like the two black wires on the rocker switch -- 3rd white wire is the return for the rocker switch LED)
« Last Edit: December 17, 2013, 12:06:09 pm by PL1 »
ChanceKJ
« Reply #13 on: December 17, 2013, 11:59:26 am »
« Last Edit: March 18, 2021, 11:51:26 pm by ChanceKJ »
ChanceKJ
« Reply #14 on: December 27, 2013, 01:37:01 am »
« Last Edit: March 18, 2021, 11:51:32 pm by ChanceKJ »
« Reply #15 on: December 27, 2013, 02:37:07 am »
Will I need/want to put a fuse before the button?
Probably not -- it's definitely not needed if the surge suppressor strip has a built-in circuit breaker.
Has this reduced the effectiveness of the surge protection?
No.
ChanceKJ
« Reply #16 on: December 27, 2013, 02:38:19 am »
« Last Edit: March 18, 2021, 11:51:36 pm by ChanceKJ »
Bambam1963
  • Last login:March 09, 2024, 11:46:07 pm
  • I love this stuff man!-
« Reply #17 on: December 27, 2013, 07:16:30 pm »
That's the ticket!
I am an oldie, who used to troll here years ago.  Now I am back to tweak my machine and help a friend build his.
