Author Topic: Picked up five more cabinets today!  (Read 2507 times)
Brian74
  • Yep... I built that!!
« on: November 18, 2013, 02:57:29 pm »
So today I went to see my guy to pickup my road blaster cab. As we walked around, he was pointing out what cabs were available. I end up getting the road blaster, megaforce 2003, area 51 with both guns, a 19" vert with two joys and 3 buttons and a target toss. None of which I got to test or really check over. Just the way he is, always in a hurry.  Been adding to this post as I pick them up. So all cabs are in my garage besides the target toss. I have test the other cabs thus far. Mega just beeps and test screen on the monitor. The vert booted right up, to my surprise, has a 60 to 1 board in it! The area 51 powers up, post beeps, a screen that says watchdog and nothing farther. Got target toss home and checked it over. They pulled the chassis but the nighthawk pc, jamma i/o board was still there. Fired it up, and I got audio. Pulled the ssb pc out and hooked up the target toss. Cant use the i/o board from the ssb, so now I gotta figure out how to use the same buttons and trackball for each game. He has a goldentee fore complete I am considering grabbing. I could have all three in the same cab!
Sent from my SGH-M919 using Tapatalk 2
Brian74
Re: Picked up five more cabinets today!
« Reply #1 on: November 18, 2013, 02:58:22 pm »
stigzler
    • Mago Arcade
« Reply #2 on: November 18, 2013, 04:14:49 pm »
My god... the work.... :o
Well Fed Games
  • Delicious!
« Reply #3 on: November 18, 2013, 04:25:50 pm »
Sweet! Look like some nice solid cabs from the pic.
DarakuTenshi
    • Card Fighters Project
« Reply #4 on: November 18, 2013, 04:36:39 pm »
About how much did that set you back?
  • Last login:April 15, 2026, 12:32:32 pm
« Reply #5 on: November 18, 2013, 04:40:43 pm »
Brian74
« Reply #6 on: November 18, 2013, 05:07:53 pm »
Area 51 $35
Target Toss $25
60 in 1 $25
MegaForce 2003 $25
RoadBlaster free
Slippyblade
« Reply #7 on: November 18, 2013, 06:30:26 pm »
Area 51 $35
Target Toss $25
60 in 1 $25
MegaForce 2003 $25
RoadBlaster free
Ok, you can just rot.  I hate you soooo much.  In my area I'm lucky to see an empty, gutted, beat-up cabinet for anything less than $75...
Fursphere
  • Last login:April 16, 2026, 04:31:49 pm
« Reply #8 on: November 18, 2013, 06:34:17 pm »
Same here in California.  $250 gets you garbage.  If it works they want $500+ for it
« Reply #9 on: November 18, 2013, 07:42:13 pm »
Tulsa OK sucks too. And I have a guy in my town that scoops up a ton then wants to sell dynamo cab with a monitor that needs flyback repair otherwise gutted for $150
Brian74
« Reply #10 on: November 18, 2013, 08:14:28 pm »
LOL, gf just put the end to buying cabs for now.. Tried to mess with the area 51, this is the screen I get then a big beep, then seems to reboot.
I don't feel any movement from the hard drive.
Brian74
« Reply #11 on: November 18, 2013, 08:15:23 pm »
I also dont see any service buttons or dip switches.
DarakuTenshi
« Reply #12 on: November 18, 2013, 10:22:39 pm »
Area 51 $35
Target Toss $25
60 in 1 $25
MegaForce 2003 $25
RoadBlaster free
Brian74
« Reply #13 on: November 18, 2013, 10:42:07 pm »
Got the mega force fired up, game freezes up, then runs fine.
ed12
« Reply #14 on: November 18, 2013, 11:03:27 pm »
on the mega
open it up
find the 8 pin dip switch
turn 4 and 7 from off to on
game should read restoring factory defaults..do not power unit off
that is the msg u will see
do it..then after it is done it will say turn 4@7 back off and power game on/off
do it..
game has re-built its self
ed
« Reply #15 on: November 18, 2013, 11:24:32 pm »
You just have to know the right people in the 602, bro.
Brian74
« Reply #16 on: November 19, 2013, 08:21:27 pm »
All I had to do to the area 51 was remove the power cab,e from the hard drive re install and it booted right up. I have a cf to ide adapter on the way to switch out that old hard drive. Messed with the Road Blaster, steering is off, the gas peddle dont work and the screen is all out of adjustment. Found the dip switch, rest all the controls. Played ok until the first curve, then went back to the way it was.
stigzler
    • Mago Arcade
« Reply #17 on: November 20, 2013, 03:02:25 am »
Jees - I spent £35 on a coin door alone - this guy got the door + a whole loada stuff around it for less!
wtg. :)
Brian74
« Reply #18 on: November 20, 2013, 03:07:40 am »
Yeah, I lucked out :))
