Author Topic: Which is the better MAME version?  (Read 6144 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: November 08, 2013, 04:19:34 pm »
I am using Window 7 64bit. And am evaluating my choices of MAME versions. I tried the latest 1.51 but the interface isn't easy like the others I've seen. MAME UI seems most friendly.  Any recommendations for a MAME thats easy to configure and nice interface?
I think Maximus Arcade will be used as the front end. I like the simplicity of it.
Thanks.
« Last Edit: November 08, 2013, 04:41:24 pm by Richardgregory »
EMDB
  • Project RetroCade
Re: Which is the better MAME version?
« Reply #1 on: November 08, 2013, 04:34:21 pm »
If you use a frontend the plain command line MAME 64 bits, preferable compiled with no-nags and hi-score support (http://forum.arcadecontrols.com/index.php/topic,64298.0.html) is your best choice...
Wade007
  • Last login:April 06, 2017, 01:33:35 pm
  • A MAME cabinet at home is heaven
    • bit.ly/1cWnoIC
    • Cheapskategamer.com
« Reply #2 on: November 08, 2013, 06:09:26 pm »
I like MAME UI as a configurable MAME program.
I used Mala as my frontend and MAMEUI (64bit no-nag version) as my "back-end". Works great.
The nice thing about MAME UI is that it has the graphical user interface. Fairly easy to configure. No command line nonsense. Just point your Frontend to the MAME UI executable after you have set it up how you like and you should be good to go.
My Super Arcade cabinet project:
Software blog article: http://bit.ly/1cWnoIC
Hardware blog article: http://bit.ly/1dWxjvP
YouTube video: http://bit.ly/1N818Xm
Super Arcade Cabinet Progress thread (Now Complete):
http://forum.arcadecontrols.com/index.php/topic,123292.0.html
Frontend Video Intro: http://bit.ly/1P9HPDN
B2K24
  • Last login:June 10, 2025, 10:17:56 am
« Reply #3 on: November 08, 2013, 06:10:33 pm »
I enjoy using the official binary along side GameEX --> http://www.gameex.com/
« Reply #4 on: November 08, 2013, 08:36:51 pm »
I use MAMEPlus or MAME UI for testing and making adjustments to single games.
My front end uses the official MAME binary when it launches games.
They can both live in one folder and utilize the same files.
I've had issues with rapid fire screw with the joystick directions on the last version of MAMEPlus I tried (.146 I think)
MAME UI: http://www.mameui.info/
ark_ader
  • I glow in the dark.
« Reply #5 on: November 08, 2013, 10:46:30 pm »
.84
paigeoliver
  • Awesome face!
« Reply #6 on: November 08, 2013, 11:48:17 pm »
.55 because it works and no major titles are broken in that release.
However I normally have multiple versions installed.
  • Last login:Today at 07:23:14 am
« Reply #7 on: November 09, 2013, 12:52:03 am »
Since you like MAMEUI, check out MAMEUIFX.
I wouldn't use it in a dedicated cab, but it works great on the living room big screen with a portable CP.  ;D
For a vertical widescreen cab or widescreen cocktail, look into MameLayPlus.
danny_galaga
  • Last login:April 17, 2026, 10:06:35 pm
    • dans cocktail lounge
« Reply #8 on: November 09, 2013, 03:41:34 am »
.78 for me.
Almost every person is going to say a different one when you ask that question  ;D
Richardgregory
« Reply #9 on: November 09, 2013, 08:44:01 am »
I checked out MAMEUI64 - and yup, it's much easier with the GUI - I might just use this as my backend and stick with Maximus Arcade as the Frontend.
I have to evaluate the other Frontends out there as well, but not sure if they are as nice looking as Maximus?
Richardgregory
« Reply #10 on: November 09, 2013, 08:57:48 am »
Thanks!  I checked out MAMEUIFX - I think it's better than the MAMEUI64.  Maybe I'll switch over to this for the back end.
Richardgregory
« Reply #11 on: November 09, 2013, 08:59:02 am »
By the way, why would the command line be preferred over to a MAME application that offers a Graphical User Interface, which one can selection the game options from there?  Maybe I'm missing something.
Haze
    • MAME Development Blog
« Reply #12 on: November 09, 2013, 10:12:13 am »
because the command line version is the official more stable version..
the UI code has been falling apart for years now and you'd be best avoiding it.  There will almost certainly come a day when you can't even launch half the games from it, so moving away now is wise.
If you're running a frontend you'll be doing the configuration etc. from the frontend anyway so I can't understand why you'd even want a UI build.
There are fancy frontends like the ones mentioned then more powerful ones like QMC2 that aren't as pretty but expose all the options.
« Reply #13 on: November 09, 2013, 10:40:31 am »
Like Haze mentioned, the official release is more stable and usually several days to several weeks ahead of the GUI releases which have to be at least recompiled and some parts may need to be rewritten.
That said, I haven't noticed any instability problems with MAMEUIFX.   :dunno
For now, I like it because it is so easy to search for a game mentioned on the forum, view the related history/screenshot/cab/marquee/CP on the right, copy the ROM (and parent) from the archive folder up to the roms folder, right-click on game title to audit, and launch.
If you're changing your game list often, a GUI version makes it a bit easier -- otherwise the official release is your best bet.
Richardgregory
« Reply #14 on: November 09, 2013, 08:04:40 pm »
My thought was that a backend such as a GUI would allow me and easier way to configure each game as necessary. Ie.  control keys, etc.  no?
« Reply #15 on: November 10, 2013, 01:49:26 pm »
Key configuration, whether MAME defaults or per-game, is still handled by the same MAME menus.
Not sure if any of the other settings are easier to tweak in the GUI version.   :dunno
IMHO the main advantages of MAMEUIFX are the search function and the right-click to audit.
matt4949
« Reply #16 on: November 10, 2013, 02:02:09 pm »
just checked out your link
 MameLayPlus.
flippin awsome. thanks
tron84
  • Last login:November 15, 2017, 06:45:56 am
« Reply #17 on: November 10, 2013, 02:24:10 pm »
+1   GameEx, I really like using this one also for the FE.
Then I use this Mame build, EMU 0151 ("cv1k.c" & nonag) (32 & 64Bit) [w / support new dump]
Cave SH-3, no nag, hi score build.  So I can play the cave games :)
It is the "C" in the Emu part.
http://translate.google.com/translate?hl=en&sl=fr&u=http://www.systempixel.fr/&prev=/search%3Fq%3DSystem%2BPixel%2BMAME%2BPlus%26biw%3D668%26bih%3D380
EDIT:  More Mame 0151 r5097 (Cave SH-3 & nonag) is the one I use.  The one above is the UME build. Not enough JaVa  :P in me. The is in the "C" emu part also.
Whats up B2K24  :cheers: Hope all is well brother, its been a minute. Glad to see ya on here. :D
« Last Edit: November 10, 2013, 02:44:35 pm by tron84 »
