Author Topic: Glue vs Screws  (Read 6205 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
Glue vs Screws
« on: September 03, 2013, 03:36:08 pm »
I can imagine that this has been asked a billion times over, but can a newbie ask again? ;)  So I figure I'll use glue instead of screws to mount the furring strips on the inside panel.  Glue can be that strong to hold the weight of an LCD that will be mounted on a frame attached to the furring strips?
Just checking...
GoYouSalukis
  • Last login:March 18, 2020, 11:58:59 am
Re: Glue vs Screws
« Reply #1 on: September 03, 2013, 03:50:59 pm »
 What is the material? MDF, plywood, or particle board?
I recommend you use glue AND screws for two reasons.
1. Glue is strong, but screws provide a mechanical connection.
2. The screws help provide good clamping pressure while the glue drys.
The material is important, because MDF for example does not take screws well, or if you try to glue melamine coated particle board, it might not bond well.
Maximus
  • Plans are for fools!!!!
    • Arcade Icons
Re: Glue vs Screws
« Reply #2 on: September 03, 2013, 03:57:05 pm »
^^^^^This
paigeoliver
  • Awesome face!
Re: Glue vs Screws
« Reply #3 on: September 03, 2013, 06:01:51 pm »
I always glue and screw.
gamepimp
  • Last login:December 20, 2025, 10:42:56 pm
Re: Glue vs Screws
« Reply #4 on: September 03, 2013, 06:22:01 pm »
For some reason that just sounds "naughty". Lol!
konp
  • Last login:January 24, 2018, 04:51:18 am
Re: Glue vs Screws
« Reply #5 on: September 03, 2013, 09:16:06 pm »
Por que no los dos?
Maximus
    • Arcade Icons
Re: Glue vs Screws
« Reply #6 on: September 04, 2013, 11:55:16 am »
Should be screw then glue
zanna5910
  • Last login:August 05, 2024, 10:37:36 am
Re: Glue vs Screws
« Reply #7 on: September 04, 2013, 11:58:14 am »
I fear we've taken a turn for the worse...
mcseforsale
  • Creepy Mario Dude
Re: Glue vs Screws
« Reply #8 on: September 04, 2013, 12:16:04 pm »
Glue will actually set up stronger than the wood that you're gluing (especially Gorilla glue).  But with MDF, I'd use both.  Use the screws to do the layout and build up.  Then, glue and use the screws to hold it all together while the glue dries.
AJ
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
Re: Glue vs Screws
« Reply #9 on: September 06, 2013, 11:48:54 pm »
Why not go with construction adhesive? ;)
Glue will always be stronger than screws. Think the hand rails in your house. They're all glued. And they have to be safe to take the weight of a person.
stringbender
  • Last login:May 19, 2019, 02:22:46 am
  • I want to support custom home arcade building.
Re: Glue vs Screws
« Reply #10 on: September 07, 2013, 09:46:29 am »
definitely use both..
CoryBee
  • Bopity Boopy
Re: Glue vs Screws
« Reply #11 on: September 07, 2013, 09:57:24 am »
Yepp Yepp
I use both, then when the glue dries sometimes I reclaim my screws. Screws tend to work much better than clamps to hold everything down tight.
ppv
  • Last login:October 16, 2020, 03:08:56 pm
  • The cheap@ss gamer
Re: Re: Glue vs Screws
« Reply #12 on: September 07, 2013, 06:57:29 pm »
Yepp Yepp
i'll take that advice! Thanks!
Doing arcades, the cheap@ss way!
First Project : ttp://forum.arcadecontrols.com/index.php/topic,151071.0.html
Next one : The Token Muncher [urlhttp://forum.arcadecontrols.com/index.php/topic,135417.0.html[/url]
ark_ader
  • I glow in the dark.
Re: Glue vs Screws
« Reply #13 on: September 07, 2013, 07:12:29 pm »
Obviously I am going to be difficult and say glue and dowels.
Screws for the base but the rest can be glued if there isn't and load bearing supports, but you can reinforce those like a monitor cage or internal frame.
Screws is for novices.
Experts use glue and dowels, and lots of clamps with patience.
  • Last login:April 15, 2026, 12:32:32 pm
Re: Glue vs Screws
« Reply #14 on: September 08, 2013, 02:14:39 am »
You are, by far, the cheapest son of a ---smurfette--- I know.  :cheers:
CoryBee
  • Bopity Boopy
Re: Glue vs Screws
« Reply #15 on: September 08, 2013, 02:40:05 am »
Hockeyboy
  • Last login:April 17, 2022, 02:48:38 pm
Re: Glue vs Screws
« Reply #16 on: September 08, 2013, 08:02:08 am »
I've been doing glue AND screws on my cab -- I can't imagine doing just one or ther other. You don't want this thing falling apart as you are yanking on the joysticks and pounding the buttons. And I have to admit I  :laugh2: when I saw this:
boomerbrian
  • Last login:June 05, 2025, 10:43:25 am
Re: Glue vs Screws
« Reply #17 on: September 08, 2013, 09:54:43 am »
Pocket screws and glue for me. Makes for a super strong joint and is very clean. You can even buy wood plugs if for some reason you drilled your pocket holes in a visible area.
Garza
  • Last login:July 09, 2015, 10:53:29 am
Re: Glue vs Screws
« Reply #18 on: September 09, 2013, 02:55:25 pm »
Kinda late but Both the glue is strong and the screws hold it together until the glue dries....
Re: Glue vs Screws
« Reply #19 on: September 09, 2013, 03:37:33 pm »
Well, hand rails use finger joints, are made from real timber and joined with high pressure machinery. There are also enough point of support from the newel post and balusters that it really doesn't need to bear much of a load at all. Not making a case that glue is weak, but I don't think that there is an even comparison between a railing and a furring strip glued to the side of a sheet of wood.. A few years of warping, bending and temp changes, and I wouldn't be surprised to see glue give way here and there on furring. Especially if the wood was not great quality and did not sit completely flush to begin with.
kahlid74
  • Gaming for a better future!
    • GamersAnon
Glue vs Screws
« Reply #20 on: September 09, 2013, 04:58:18 pm »
It's already been said but I would use both.  The screws are really there to pull the parts together and the reaction the glue has is stronger than the wood.  Together it should be strong enough to last the test of time.
