Author Topic: Are there any games that specifically require a Player 2 coin insert command?  (Read 4291 times)
Dcpmark
  • Last login:February 23, 2026, 10:00:46 pm
I currently have Player 1 Coin Insert and Player 2 Coin Insert commands mapped to pinball buttons on the outside of my cab. I'm designing my new CP, and I was wondering if I really only need one Coin Insert button. Or do some games need a dedicated Coin Insert button for Player 2?
TIA!
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
The only one that comes to mind are  Gauntlet and Rampage.
Dcpmark
Wow, two important games......thanks!
Most 4 player games require a coin insert for each player.
Dcpmark
Thanks, but I have a 2-player CP so I don't even worry about the 4-player games. But that was my concern for certain 2-player games.
JDFan
If using MAME it is easy enough to just reset the coin2 button to the same as coin1 for the specific games that require separate slots -- that way you press the coin button and both player 1 and player 2 get a coin inserted - then use separate start buttons to start the games in case you only want to play single player -- Nice thing about doing it this way is you can also keep track of which player is using more coins since each time the button is pressed to coin up each player gets a credit so at the end of game you can see if player 1 has 20 credits left you need a new player 2 since they died a lot more often !!!
Dcpmark
Great idea! Thanks!!!
McHale
  • Last login:June 27, 2023, 03:42:17 am
  • For Duty and Humanity!
The Simpsons is a good example of a 4 player cab where each coin slot is dedicated to a specific player.
FALSE
  • Last login:February 25, 2024, 08:13:59 pm
But there's a 2 player version where you can select what character you want.
SegaOutrun
  • Last login:March 28, 2019, 03:02:05 am
  • Brakes are overrated
[/quote]
Mind Blown. I did not know that. I had to map the coins to other buttons on the cp and then try to remember which one was which. Time to update the XML.
  • Last login:Today at 03:56:07 am
Same for Gauntlet (Gauntlet2p), Gauntlet 2 (gaunt22p), TMNT (tmnt2po), TMNT2 (tmnt22pu) and X-Men (xmen2pa).
Fursphere
  • Last login:Today at 01:05:56 am
[/quote]
Pretty sure its a DIP switch setting.  So its the same ROM file - you just have to set the cabinet type too.   I think TMNT and X-Men work this way too?
The games listed in this thread that do have dip switches don't have a 2-player option -- you need to run the child ROM.
No DIP switches in Simpsons -- "simpsons2p" is the child ROM (contains only the ROMS that are different from the parent) and "simpsons" is the parent ROM. (contains the ROMs required for the default 4-player version of the game)
When you run the child ROM, it will access the common files from the parent ROM.
The child ROMs listed in my previous post also have parent ROMs that you will need to have in the "roms" folder. (gauntlet, gaunt2, tmnt, tmnt2, and xmen)
« Last Edit: July 21, 2013, 04:33:56 pm by PL1 »
Fursphere
Ok then.
