Author Topic: Refurbed 4:3 20" LCD from Dell $110 - SOLD OUT  (Read 2611 times)
« on: April 25, 2013, 11:38:53 am »
THEY ARE NOW SOLD OUT.  :dunno
Model 2007FP 1600x1200
Sure you can get them cheaper from Craigslist and Ebay, but it's direct from Dell and has a 100 day warranty.
Thought maybe somebody on here might be tired of waiting for a used one.
http://www.dfsdirectsales.com/StoreCatalog/ctl641/cp57138/si6359605/cl1/dell_ultrasharp_2007fp_20inch_flat_panel_monitor?offset=0&isLaptop=N
They also have basic model 19" ones for $69.
« Last Edit: April 25, 2013, 11:46:09 am by BadMouth »
DHTech
  • Last login:November 29, 2014, 03:48:36 pm
  • Arcade Flashback
    • Arcade Flashback - Hand Made Custom Arcade Machines UK
Re: Refurbed 4:3 20" LCD from Dell $110
« Reply #1 on: April 25, 2013, 11:45:15 am »
I got a lovely 20" 4:3 Viewsonic LCD monitor off eBay for £22 ($34), looking forward to installing it once my cabinet is built.  8)
Gray_Area
  • -Banned-
  • -Banned-
Re: Refurbed 4:3 20" LCD from Dell $110 - SOLD OUT
« Reply #2 on: April 26, 2013, 07:01:17 pm »
Looks like they're back in.
-Banned-
ark_ader
  • I glow in the dark.
« Reply #3 on: April 27, 2013, 09:11:49 am »
Wow $110?
Pays to keep old monitors.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: April 28, 2013, 07:06:17 pm »
Wow $110?
Yeah, looks like all the bitin's done.
-Banned-
Lilwolf
« Reply #5 on: April 29, 2013, 03:43:35 pm »
Don't these rotate?  the 19" one that looks like this does (I have one at work).
If so, then it might be worth it for some.
« Reply #6 on: April 29, 2013, 04:37:25 pm »
I have this monitor at work, and it does rotate.  178 deg X 178 deg viewing angles, plus plenty of inputs, DVI, VGA, S-Vid, and Composite.
erictrumpet
  • Last login:February 17, 2016, 11:59:23 am
« Reply #7 on: May 02, 2013, 07:22:49 pm »
Anyone know the exact exterior dimensions of this thing?
If so, thanks :)
Edit: found it... FYI, height 21.6", width 17.5"
Eric.
« Last Edit: May 02, 2013, 07:35:52 pm by erictrumpet »
Thurman
  • Last login:March 12, 2018, 09:15:33 pm
  • The suspense is terrible . . . I hope it'll last.
« Reply #8 on: May 04, 2013, 11:19:30 pm »
If so, thanks :)
Eric.
The stand is adjustable so do you know if 21.6" is the minimum height?  On a related note, is it possible to remove the stand?
erictrumpet
« Reply #9 on: May 04, 2013, 11:22:23 pm »
I'm sure the stand is removable - even if you have to destroy it to remove it (for a cab installation, that'd be fine) :)
Being 4:3 aspect ratio, I'd expect the 17.5" width to correspond to probably a 15" or so screen height. That's a guess.
Perhaps someone here actually owns this monitor and can give more exact answers...
Eric.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #10 on: May 04, 2013, 11:42:34 pm »
Na, ain't no monitors these days aren't detachable from the stand. Actually, I don't think any CRTs were either. None o mine are non-detachable. Anyways, I have a 17-incher with apparently the same stand. Feature rich - rotates, slides up and down, tilts.
-Banned-
ramos8414
  • Last login:January 09, 2019, 08:27:24 pm
« Reply #11 on: May 09, 2013, 01:13:41 am »
I have this monitor and it is detachable from the stand.
