Author Topic: GroovyMAME Install order  (Read 6071 times)
rawbe
  • Last login:February 28, 2026, 06:19:09 pm
« on: February 07, 2013, 09:31:49 am »
Hello-
To get Groovymame working what order do I install the packages (CRT EMU, Groovymame, Mame)? Do I still use soft 15 or does the ATI hack force my pc to output 15khz? I have my Sony PVM working with Soft 15 but after messing with the settings through Mame32 (galaga, frogger) I can not the games to fit my screen properly. Do native resolutions fit monitors without using Mame's hardware sctretch? The colors look amazing though!
I know I just asked many loaded questions so any help with the first steps would be great?
rawbe
Re: GroovyMAME Install order
« Reply #1 on: February 07, 2013, 10:48:17 am »
Most important: Do I install soft 15 for my display or do I install CRT_EmuDriver?
THANKS
Calamity
  • Moderator
  • Last login:May 21, 2026, 01:14:24 pm
  • Quote me with care
« Reply #2 on: February 07, 2013, 12:27:28 pm »
Hi rawbe,
I think this post will help clarifying some of your doubts on Soft-15kHz and CRT Emudriver:
http://forum.arcadecontrols.com/index.php?topic=119768.0
You didn't tell us the card you intend to use.
Steps to create a log:
rawbe
« Reply #3 on: February 07, 2013, 12:41:31 pm »
I have a ATI Radeon 9600. I will check out the link. Thanks!
rawbe
« Reply #4 on: February 07, 2013, 12:45:29 pm »
I will try the uninstalling everything and starting from scratch. I like the sound of CRT Emudriver so that will be step 1.
Calamity
  • Moderator
« Reply #5 on: February 07, 2013, 01:19:10 pm »
Then version 6.5 will be good for your card.
When you have the drivers up and running, just create a new folder and place the GroovyMAME executable inside. Go to command line and into the folder you just created, type 'groovymame -cc' to create a fresh mame.ini, and edit it with your roms path. Default settings should be good already.
rawbe
« Reply #6 on: February 07, 2013, 02:16:34 pm »
Calamity-
Thank you for your reply!!
« Last Edit: February 07, 2013, 03:15:10 pm by rawbe »
rawbe
« Reply #7 on: February 07, 2013, 05:22:59 pm »
How do I create the mame.ini? 'do 'i put groovymame in my mame32 folder?
rawbe
« Reply #8 on: February 07, 2013, 10:11:26 pm »
I have followed every direction I have found online about creating the groovymame's mame.ini file and nothing is working
rawbe
« Reply #9 on: February 07, 2013, 10:53:39 pm »
I am using windows xp 32 bit, mame32, groovymame, emu driver, Sony PVM.
epicfatigue
  • Last login:May 15, 2016, 08:16:08 pm
    • http://www.retromods.com.au
« Reply #10 on: February 07, 2013, 11:13:33 pm »
What error are you getting what heppens when you double click groovy?
start run cmd
cd to where groovy is located
C:\Emulators\mame64\mame64.exe -v >log.txt
then copy the log file so we can see what happens
