Author Topic: Marquee Install  (Read 2659 times)
brihyn
Marquee Install
« on: November 04, 2012, 11:14:20 am »
I'm getting to the point on my build that I need to figure out some finish elements. The biggest one in my head this week is...how does everyone mount the marquee? what kind of retainers are used?
I went through looking at a lot of the build pictures, but I couldn't really find the best answer. I considered using a small strip of wood (1/4x1/4) all the way around on the outside, mount the marquee, and then quarter-round on the inside to keep it in place, but that doesn't sound like it'll be near as nice as others are showing.
ark_ader
  • I glow in the dark.
Re: Marquee Install
« Reply #1 on: November 04, 2012, 04:47:13 pm »
Can you not make a slot for the facia?
It is not that difficult.   ::)
mgb
  • Last login:March 25, 2026, 09:52:08 pm
  • North East, US
Marquee Install
« Reply #2 on: November 04, 2012, 07:13:50 pm »
Why not just use marquee retainers. There are good number of sources including twisted quarter and arcade boneyard.
Some machines have a small route out for the marquee and then retainers.
Re: Marquee Install
« Reply #3 on: November 04, 2012, 08:11:28 pm »
Check out what mcseforsale did with his cab.  Very cheap solution.  Perhaps you can do the same to yours?
http://forum.arcadecontrols.com/index.php/topic,117977.msg1268459.html#msg1268459
DeLuSioNaL29
paigeoliver
  • Awesome face!
Re: Marquee Install
« Reply #4 on: November 04, 2012, 09:36:53 pm »
Yeah, I normally use whatever I can find at Home Depot and paint black whenever I am in need of a retainer, both for original and scratchbuilt cabinets.
Automark
  • Arcade in Spain ?
Re: Marquee Install
« Reply #5 on: November 09, 2012, 07:13:57 am »
This is how it's done on my old jamma cabinet. A simple and pretty cheap solution
brihyn
Re: Marquee Install
« Reply #6 on: November 11, 2012, 09:16:23 pm »
DeLuSioNaL29
Thanks for the link to this. Just pulled the tape off of my corner protector and it looks absolutely amazing. Not bad for 1.80!
brihyn
Re: Marquee Install
« Reply #7 on: November 11, 2012, 09:17:32 pm »
If I ever build a second cabinet, I may have to design it for this...I really like the simplicity of this design!
Automark
  • Arcade in Spain ?
Re: Marquee Install
« Reply #8 on: November 12, 2012, 02:02:24 pm »
It is indeed a pretty nice and simply way to fix this. 2 screws and you can open it to fix the light or put another marquee in.
mcseforsale
  • Creepy Mario Dude
Re: Marquee Install
« Reply #9 on: November 16, 2012, 11:53:56 pm »
Luv this..
 :jerry
Dammit...I just built a cab and this would be prime.  Especially on the Kneivel evolution!  You can get to the speakers/install them, after the cab is built.  This is the way to go!!
Screw that buck eighty eight.  I'm on this!!
AJ
mcseforsale
  • Creepy Mario Dude
Re: Marquee Install
« Reply #10 on: November 16, 2012, 11:55:00 pm »
OK...maybe a buck eighty eight for the bottom!!!
AJ
