Author Topic: Tempest with Optipac problems...  (Read 3693 times)
newkillergenius
  • Last login:September 21, 2013, 03:48:35 pm
  • A mind is a terrible thing to taste.
    • The Mystery Revealed!
« on: August 13, 2012, 06:49:07 pm »
Added a CPU to a dead Tempest today.
Wired up the optipac to the original spinner...
nothing.
FYI, I did enable 'mouse input' in MAME...anyone have any idea what I might have missed?
Any assistance appreciated.
Don't ---steaming pile of meadow muffin--- where you eat, my friend.
mgb
  • Last login:March 25, 2026, 09:52:08 pm
  • North East, US
Re: Tempest with Optipac problems...
« Reply #1 on: August 13, 2012, 08:21:51 pm »
I think you'd be a lot better off to pot some pics of your wiring and explain a little more of what you did and all that good stuff.
newkillergenius
« Reply #2 on: August 13, 2012, 08:35:16 pm »
It sucks that I cant post pics at the moment-
Wired the Optipac up correctly as far as I can tell, even tested the board and verified 4.6v and ground, the 2 outside signal wires I put in the y1 & y2 ports, but can get no response.  I also flipped the signal wires and still nothing.  It's pretty clear which wires are G and 5v, and I've got that right, so I'm baffled as to what else it could be.
From what I've read, you pretty much wire it up and enable mouse input, though I can't seem to get anything out of it.  Is there something more specific that could be the issue?
newkillergenius
« Reply #3 on: August 13, 2012, 08:40:45 pm »
Okay, figured out a way.  (new phone) ;)
Here's the spinner, and the optipac.  (Ground wire black on spinner, but green to Optipac, jumped from harness.)  Anyone see anything wrong?
« Last Edit: August 13, 2012, 08:44:53 pm by newkillergenius »
spkywlnt73
  • Last login:February 18, 2020, 08:15:24 pm
« Reply #4 on: August 13, 2012, 09:20:10 pm »
Does the spinner work outside of mame? Like does the curser move side to side? If it does, than it could be as simple as going into the mame ini file, and changing a 0, to a 1, in one of the settings!
newkillergenius
« Reply #5 on: August 13, 2012, 09:27:19 pm »
No, the cursor does not move at any time-
mgb
  • North East, US
« Reply #6 on: August 13, 2012, 11:29:47 pm »
I wonder if the optical sensor could be bad. I don't suppose there's a way you can try it in a working Tempest?
With optical score switches on ticket games, I always use my cell phone camera in order to see if the light source is lit. I'm not sure how easy it would be to see it on a spinners sensor though.
« Last Edit: August 13, 2012, 11:36:23 pm by mgb »
newkillergenius
« Reply #7 on: August 14, 2012, 03:33:31 pm »
Unfortunately, the Tempest boards have seen their last repair, which is why I went ahead and decided
to run it in MAME.  I left the original boards in there for posterity though- but there's no way I can test the spinner.
It's been in storage so long I can't remember if the spinner was a problem before or not.  :dizzy:
Well, I'm running out of possibilities, and I guess the sensor being bad could be one.
If we were to assume that the optical board/sensor were bad, would I be able to theoretically
replace all of the components on it and expect it to work again?  I don't want to shell out over $50
for a used Tempest spinner...I've already got one!  (b/c who knows what 'untested' could really mean, right?)
newkillergenius
« Reply #8 on: August 22, 2012, 08:51:22 pm »
So, are we agreed that I guess I'll have to eat a spinner?
 :lol
mgb
  • North East, US
« Reply #9 on: August 22, 2012, 11:43:01 pm »
arcade shops has replacement optic boards
http://www.arcadeshop.com/pics/atari_tb_pcb_os.jpg
They're $14
Are you sure the optipac is good, how about trying a trackball with it or the spinner on another input.
« Last Edit: August 22, 2012, 11:45:32 pm by mgb »
newkillergenius
« Reply #10 on: August 24, 2012, 11:49:13 am »
mgb, I doubt the optipac is bad, I just received it new from Andy.  I wish I had another device to try with it.
Thanks for finding that information about the optic boards, this looks like a much less expensive solution, I think I'll give this a try.
mgb
  • North East, US
« Reply #11 on: August 24, 2012, 01:38:37 pm »
Yeah you're probably right, I wouldn't expect the optipac to be bad if its brand new. For the fun of it though, you still may wanna try it on another input of the optipac, if you haven't already.
newkillergenius
« Reply #12 on: August 29, 2012, 08:32:50 pm »
Well, update, bought a replacement optic board from AS, installed it, no change.
Verified 49.v at the solder side of the optic board.
