Author Topic: Going insane - arcade monitor and sides of screen.  (Read 4910 times)
hayaeti
  • Last login:March 19, 2020, 07:36:27 am
« on: July 07, 2012, 04:42:29 am »
Hi guys.
Quick backstory.  Had a power outage and my old mame machine died.
Got a new one put together and tried using one of the ArcadeVGA 3000 cards but wasn't quite happy.
Decided to go get a old radeon and use the calamity drivers and arcade monitor (which is either a D9200 or D9800)
Everything seemed to go well, but I have one of two problems... (which only seem to come into play with CPS2-esque res games.
With one set monitor spec settings I load up final fight and I see this...
with another I get the whole screen and everything looks PERFECT.... until I start playing and walk from left to right.
The moment the screen starts scrolling I am noticing that the sides are fatter than the middle of the screen and things stretch as I move, it makes everything look very funky! (and not in a good way)
What can I do to fix this?  this is with using '-nohwstretch' as if I don't use that, it all fits on the screen perfect but looks horrible.
tldr:  when I scroll, the sides of the screen stretch out and make the sprites bigger.
This wasn't a problem with my old pc hooked up to the same monitor with the original AGP arcadevga.  So I would like to think I could get this working.  At the moment I'm stuck with a perfect picture with no sides, or full screen with stretchy sides.
The problem isn't so much what's in the picture, but I figured I'd explain both my issues.  The one in the picture can be fixed by using different monitor spec lines as provided on this site, but how do I fix the stretchy-sides as it scrolls?  if I could fix this, my machine would be complete!
« Last Edit: July 07, 2012, 04:50:14 am by hayaeti »
Calamity
  • Moderator
  • Last login:Yesterday at 01:46:04 am
  • Quote me with care
Re: Going insane - arcade monitor and sides of screen.
« Reply #1 on: July 07, 2012, 05:21:05 am »
Hi hayaeti,
It sounds strange to me that a modeline could cause stretching on the sides of the monitor. Anyway, before we go any further, launch Arcade_OSD and set the resolution 384 x 224 @ 60 to full screen. You'll see a grid in the background, check if you notice the stretching here too.
Steps to create a log:
hayaeti
« Reply #2 on: July 07, 2012, 07:29:42 am »
Hi Calamity, thanks for the quick reply.  Unfortunately when I go into arcade_osd I can't find that resolution.
The closest I can find is 288 x 260 60vfreq 59.993hz 15.718khz
When I open that up, it looks fine, and when I manually change the y res to 244 it looks fine too.
I think it has something to do with the frequency? when I bring up my montors osd while playing final fight it says 17.8/59hz, which is what I think Final Fight is meant to be played at?
Calamity
  • Moderator
« Reply #3 on: July 07, 2012, 07:36:41 am »
The resolution must exist, otherwise GroovyMAME wouldn't be able to use it. Unless you're using magic resolutions ?
If you attach a log of the game I'll see what's your current setup:
groovymame.exe romname -v -md 4 >romname.txt
Did you run VMMaker with the same monitor_specs you're using in mame.ini? This is a required step.
« Last Edit: July 07, 2012, 07:40:07 am by Calamity »
hayaeti
« Reply #4 on: July 07, 2012, 07:51:33 am »
Now you understand why I'm going insane :P
ps.  did I say thanks for helping?
I'm running the commandline as such btw
C:\mame>mame ffight -nohwstretch
which says...
SwitchRes v0.013f: [ffight] (1) horizontal (384x224@59.61)->(384x224@59.61)->(384x224@59.61)
see here for my log :)
http://www.palgamer.com/ffight.txt
what have i broken? :)
Calamity
  • Moderator
« Reply #5 on: July 07, 2012, 08:10:54 am »
Ok, I'm seeing the issue now. That find_best_mode algorithm definitely needs a rewrite. Anyway, try this:
- In case you still don't have it, get the latest versions here: http://aburamushi.net/calamity/VMMaker_1.3c_Arcade_OSD_1.3b.rar
- Edit vmmaker.ini and set YResMin_XML = 224
- Set the same monitor settings as in mame.ini
- Run VMMaker and restart.
Now you should have the required 224 lines resolutions and everything should be fine.
hayaeti
« Reply #6 on: July 07, 2012, 08:36:14 am »
Yes!!! that fixed it up straight away!
You sir are a genius! and I'm so glad I haven't spent the last couple of days trying to get this to work only to find out I'm an idiot :D
Thanks so much for all the work you do for this scene :)
Calamity
  • Moderator
« Reply #7 on: July 07, 2012, 09:07:00 am »
Glad to see that it worked!  :)
