Author Topic: Hollywood Heat Special (Solved)  (Read 2544 times)
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« on: June 30, 2012, 01:14:23 pm »
I'm hoping someone here can help me out. I've had this game for the last little while and I can't for the life of me figure out how to activate the top roll under special. I can get the lower roll under special lit by spelling out P-I-N-B-A-L-L but I have no idea about the top one. Worst part is I have the manual for the thing! All it says is awards special when lit.... no hints as to how to get it. I've tried a bunch of different combinations but I'm running out of ideas so hopefully someone that has played it before can point me in the right direction.
« Last Edit: July 09, 2012, 08:17:30 pm by brad808 »
brad808
Re: Hollywood Heat Special
« Reply #1 on: July 07, 2012, 09:23:01 pm »
OK bad news... apparently the top and bottom specials are supposed to both go off at the same time (says klov forum). This is scary because both the light and the switch work properly but the special never gets triggered. Here is a vid to illustrate
So are there any ideas what could be causing a problem like that?
brad808
« Reply #2 on: July 09, 2012, 08:17:16 pm »
Eureka! Finally figured it out when I was playing tonight. I saw the bottom special light up, then it alternated to the top one and then I lost my ball ;( But even seeing it work gave me hope so I started digging again and realized that it alternates each time one of the lower bumpers is hit.
The manual for this game is awful it really doesn't explain anything...
« Last Edit: July 09, 2012, 08:18:57 pm by brad808 »
