Author Topic: Help ati radeon radeon 4350 (help calamity)  (Read 12161 times)
roccias
  • Last login:August 18, 2023, 08:44:09 am
« on: June 08, 2012, 03:15:06 am »
Hi everyone, this is my first post and sorry for my english. I have a question for calamity. I wrote you in other forum but i saw you are very involved in this forum (you are a moderator  ;D) and I preferred to write here. My problem was with Sapphire Ati Radeon 4350 hd Pci E 512 Mb and driver crt_emudriver_9.3_1.2a_xp32_multisync. When i try to install i have this error: " "Setup didn't find a driver compatible with your current hardware or operating system. Setup will now exit."
My Hardware ID is: ID hardware:PCI\VEN_1002&DEV_9552&SUBSYS_3000174B&REV_00
PCI\VEN_1002&DEV_9552&CC_030000
You already saw that 9552 is not in driver list and therefore you had to change tha archive. When you have a little time, may you pass me the new archive (already modified) please?Sorry for the insistence but I'm anxious to try this driver with my tv crt.   ;D. Thanks a lot
Calamity
  • Moderator
  • Last login:April 08, 2026, 02:30:14 am
  • Quote me with care
Re: Help ati radeon radeon 4350 (help calamity)
« Reply #1 on: June 08, 2012, 02:12:42 pm »
Hi roccias,
Use the files attached, make sure to place each file in the right place. Good luck!
Steps to create a log:
roccias
« Reply #2 on: June 08, 2012, 02:40:08 pm »
a BIG thanks
krick
  • Gotta have blue hair.
« Reply #3 on: June 14, 2012, 12:59:12 am »
This PCI string needs to be added to all the driver packages eventually, correct?
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Calamity
  • Moderator
« Reply #4 on: June 15, 2012, 05:24:02 pm »
Yes it should be applied to version 9.3 only, both 32 and 64 bit packages.
krick
« Reply #5 on: August 21, 2012, 01:27:22 pm »
I just wanted to make a note here so I could find it again in the future.
Here's another PCI string that needs to be added (along with the one above) whenever the drivers are touched again...
http://forum.arcadecontrols.com/index.php/topic,122039.0.html
PCI\VEN_1002&DEV_9553&SUBSYS_3092174B&REV_00
PCI\VEN_1002&DEV_9553&CC_030000
Hantarex Polo 15KHz
HDgaming42
  • Last login:March 28, 2019, 10:53:27 pm
« Reply #6 on: October 04, 2012, 02:21:07 am »
I just got an XFX HD 4350 1GB card that doesn't seem to like crt_emudriver_9.3_1.2a_x64.  At least, the lowest resolution available is 320 x 200, but when you choose it it is apparent it is actually outputting 31kHz.
I had a 3450 in there before that was working fine, but I wasn't happy with the need to double the frequency because of the dot clock.  I had hoped the 4350 would fix that...
I uninstalled in safe mode, ran the cat-uninstaller, rebooted in safe mode, installed the crt_emudriver_9.3_1.2a_x64.  Rebooted.  booted into windows and no go.  Reboot and still only 320 x 200 (that is running at 31kHz).
Is it possible my card has a device ID that isn't in your drivers?  I'd look it up right now but I managed to nuke my display by installing soft_15khz.  Now I can't see anything.  I can fix it by that will take time.
Is it worth me looking up my device ID string etc?  Shouldn't this have "just worked"?  What am I missing?
I can't tell you how excited I am by this.! I was so stoked to get a 3450, but then when I had it working I learned about the low dot clock issue.  =(
Then I bought a 4350 online.  Stupid ID doesn't work so I can't register it, and XFX won't let you into their support section without first registering.  Doh!  No new BIOS for me...
Any help is appreciated.  I can dig up any info you need--just tell me.  Not sure if its needed or I'm missing something obvious.  Thanks for any help!
HDgaming42
« Reply #7 on: October 04, 2012, 09:58:00 am »
I should mention I've tried both the VGA and DVI(to VGA) ports.
Windows gives me this device ID:
PCI\VEN_1002&DEV_954F&SUBSYS_29201682&REV_00\4&1603E009&0&0008
HDgaming42
« Reply #8 on: October 04, 2012, 09:12:33 pm »
I've chased down a number of threads to learn how to manually edit in my device ID into the proper files.  Turns out...they're already there.   ???
So the driver should see the card...what's the problem?  Every resolution I have outputs at 31kHz.  I'm at a loss and could use some direction guys/gals...
I'm running win XP 64bit SP2.  I have an XFX HD 4550 1GB card.  I've tried using both VGA and DVI (DVI is the correct one to use?).  I've tried both dual link and single link DVI to VGA adapters.  I'm outputting to both an LCD and a PVM via a VGA switchbox, so as to not blow the PVM.
I install quickrez and the calamity drivers.  Reboot.  The lowest resolution I have is 320 x 200 and it runs at 31kHz.
What am I doing wrong and how do I fix it?
« Last Edit: October 04, 2012, 09:27:39 pm by HDgaming42 »
HDgaming42
« Reply #9 on: October 04, 2012, 09:49:32 pm »
I'm moving my questions over here.  My card is (isn't?) an HD 4350.  Perhaps that's the problem?
