Author Topic: Bartop cabinets without marquee  (Read 3815 times)
emb
  • Last login:September 14, 2018, 02:01:19 pm
    • Don Honerbrink
« on: March 19, 2012, 03:18:32 pm »
Has anyone built a bartop cabinet without a marquee? If so, what does yours look like? I'm building a bartop for a relative and was trying to cut corners on cost for him. I figured marquee and backlight would add an extra $40 to the entire system.
Green Giant
Re: Bartop cabinets without marquee
« Reply #1 on: March 19, 2012, 03:32:57 pm »
If you print it yourself you can cut that cost by a ton.  All you would need is a ten dollar light and a small piece of plexi.
Toxic Arcade, my first build
BobA
  • What Me Worry?
« Reply #2 on: March 19, 2012, 03:54:12 pm »
I remember seeing one that had the shape for a marquee but had solid wood or mdf there so a marquee was added later by glueing in place.  No light, no plexi and no special printing needed. An added advantage is the shape still allows speakers to be mounted in the area.  If you do away with the marquee area all together it makes speaker placement difficult.
« Last Edit: March 19, 2012, 03:55:46 pm by BobA »
emb
    • Don Honerbrink
« Reply #3 on: March 19, 2012, 05:06:38 pm »
Good points. Thanks.
« Reply #4 on: March 19, 2012, 10:49:53 pm »
Haven't built it yet, but the MiniBeast is marqueeless. But I also consider it a table top machine vs a bartop...
404
« Reply #5 on: March 19, 2012, 11:20:01 pm »
wizkid32
  • Last login:August 30, 2013, 07:27:03 pm
  • Portland Trailblazers, FTW!
« Reply #6 on: March 19, 2012, 11:31:04 pm »
a few of them here
http://bartoparcade.katorlegaz.com/
Wow, those are pretty good plans.  I built one without a marquee (I should stop being lazy and take some pics.), but I figure it will only cost me $20 to add on on so...
(\__/)
(='.'=) This is Bunny. Copy and paste him into your
(")_(") signature and help him on his quest for world domination.
Best,
Wizkid32
Unstupid
« Reply #7 on: March 21, 2012, 03:37:16 am »
I saw one.... I think they called it an icade...
Lilwolf
« Reply #8 on: March 21, 2012, 07:33:19 am »
I've been considering building one with my gtablet.  I just haven't figured out the best ways to handle the encoder.
But I love the idea of a touchscreen bartop... and a joystick bartop... just not sure if they go well together.
That and if any of the android mame ports are good enough.
404
« Reply #9 on: March 21, 2012, 08:25:14 am »
if your tablet has an ice cream sandwich upgrade available, I suggest you use that. It supports connecting xbox360, wii, bluetooth (and ps3 i think) controllers natively...still, games need to add support using the controller libraries.
ark_ader
  • I glow in the dark.
« Reply #10 on: March 22, 2012, 06:05:39 am »
Froyo supports this via USB.
