Author Topic: Big Buttons, Small Holes  (Read 2548 times)
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
« on: November 30, 2011, 01:53:52 am »
Has anyone manage to get 30mm buttons into 1-1/8" control panel holes? I am looking to pick up some pink buttons and the only ones I've come across are the 30mm ones at Paradise Arcade.
I assume that this measurement is represents the outside of the button threads and was wondering if they can be screwed into conventional 1-1/8" sized holes, or necessitate the need to enlarge the holes.
Thanks.
Darren Harris
Staten Island, New York.
« Last Edit: December 11, 2011, 02:59:25 pm by D_Harris »
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
Re: Big Buittons, Small Holes
« Reply #2 on: November 30, 2011, 11:32:30 am »
No, the hole size of 1-1/8" is 28.58mm. A 30mm button will not fit in 28.58mm. The button dextercf linked will fit.
D_Harris
« Reply #3 on: December 11, 2011, 03:07:19 pm »
28mm ?
http://www.ebay.com/itm/ARCADE-BUTTON-PINK-BUILT-IN-SWITCH-PUSHBUTTON-/390301683634?pt=UK_Video_Games_Coin_Operated_MJ&hash=item5adfcb0fb2#ht_2178wt_1189
Thanks.
I may have to enlarge the Ms. Pac-man start button holes. These are the one s I was considering because of the shade of pink they are: http://www.paradisearcadeshop.com/en/pushbuttons/382-black-pink-30mm-sanwa-obsf-30-pushbutton.html
But another disadvantage is that they use micro switches.
If I could find the correct shade of pink in a button I can use leaf switches with all my problems would be over.
Darren Harris
dextercf
  • [thisispersonal]
« Reply #4 on: December 11, 2011, 05:08:35 pm »
#firstworldproblems
cigardude
  • Last login:December 20, 2017, 01:29:48 pm
Re: Big Buttons, Small Holes
« Reply #5 on: December 12, 2011, 11:59:21 am »
Enlarge the holes, they do make a 30mm drill bit. In fact I just picked on up from Amazon because I got some 30mm buttons with leaf switches.
http://www.amazon.com/CMT-537-300-31-30mm-Forstner-Bit/dp/B000P4LLFY/ref=sr_1_6?ie=UTF8&qid=1323709142&sr=8-6
D_Harris
« Reply #6 on: December 12, 2011, 12:58:56 pm »
Where did you get the buttons with leaf switches?
Thanks.
Darren Harris
D_Harris
« Reply #7 on: March 04, 2012, 05:34:24 pm »
I'm still searching for light pink buttons if anyone has come across any.
Thanks.
Darren Harris
cigardude
paigeoliver
  • Awesome face!
« Reply #9 on: March 06, 2012, 04:39:55 pm »
Silly question, but if you are using them for start buttons why would leaf vs. microswitch even matter?
D_Harris
« Reply #10 on: March 07, 2012, 02:26:55 pm »
You mentioned that you had gotten 30mm buttons with leaf switches.  The ones you linked to don't have leaf switches and are the same ones I mentioned were too large in my first post.
That's not a silly question. I may need the leaf buttons for "in-game" controls. (Long story).
Darren Harris
paigeoliver
  • Awesome face!
« Reply #11 on: March 07, 2012, 04:45:00 pm »
Now I totally understand. I have seen various kits and boards installed on Pac games that use the start buttons as play buttons.
