Author Topic: Looking for stainable veneer - super thin!  (Read 6521 times)
  • Last login:April 18, 2026, 05:46:43 pm
« on: May 10, 2011, 08:36:19 pm »
Anyone know where I can get some wicked thin stainable veneer?  I need to match the grain of cabinet grade birch plywood.  I need a fairly large piece - big enough to cover the side off a cocktail cabinet.  Any leads would be appreciated!
Re: Looking for stainable veneer - super thin!
« Reply #1 on: May 10, 2011, 09:31:54 pm »
Finally getting around to covering up that 3rd panel?
scream1973
  • Last login:July 25, 2014, 10:28:46 am
« Reply #2 on: May 11, 2011, 09:26:35 am »
You can pick up veneer at most big box stores or lumber yards. I know home depot carries it in widths up to 24 inches.
« Reply #3 on: May 11, 2011, 02:34:20 pm »
Yup.  I need to:
- cut out the CP and remove the coin door on that one side.
- cut out pieces of plywood to fill in the holes.
- bondo and sand
- add the veneer
- cut a new hole for the coin door (it needs to be higher now).
- stain and poly
That's doable in a weekend I think except for the stain and poly which will likely be spread out over a few nights to allow for drying.
Really?  I haven't noticed... I'll have to check the Home Depot and see what they've got.
« Reply #4 on: May 11, 2011, 04:17:29 pm »
Yup.  I need to:
- bondo and sand
- add the veneer
- stain and poly
Good luck... I think a decent option might be laminating over whats already there. It still might only take a weekend... but it'll be a full weekend.
« Reply #5 on: May 11, 2011, 04:32:42 pm »
yeah - it won't be easy but I think it is completely doable.  I don't think Home Depot sells veneers either - they have edge banding but that's obviously not what I'm going for.
I found THIS site online and it looks like they sell what I will need but it will be expensive.
Also, I may have to make a separate thread but what are people using for cocktail monitors these days?  I had a Happs Vision Pro but I moved it to my DK so I need to replace it.  I might just go for a 19" CRT monitor but maybe there is a better solution?  I'm worried about using an LCD due to viewing angles...
scream1973
« Reply #6 on: May 11, 2011, 08:58:14 pm »
Really our Home Depots and Rona and such sell large rolls of veneer in the same place where the edge banding.
Bender
« Reply #7 on: May 11, 2011, 09:05:44 pm »
You can try Woodcraft or Rockler too
« Reply #8 on: May 12, 2011, 12:19:11 pm »
Thanks Bender.  Check THIS out.  I assume "pre-sanded and ready to finish" means I can apply stain and poly on this veneer, right?
$70 is steep but I have no option...
scream1973
« Reply #9 on: May 12, 2011, 08:59:53 pm »
Yes that would mean that.. Its basically ready to roll ..
Nimbus
  • Last login:December 21, 2019, 08:08:57 pm
« Reply #10 on: May 13, 2011, 12:41:41 am »
Don't go to Rockler or Woodcraft for veneer. They are super expensive.
Go here:
http://tapeease.com/10_mil_%20veneer.htm
You can get a 4 x 8 sheet of rotary cut Birch veneer for about 30 bucks. It will also be higher quality than the stuff you get from Woodcraft or Rockler. Their website is terrible, but their prices, service and product can't be beat.
Hope that helps!
« Reply #11 on: May 13, 2011, 09:55:47 am »
Wow awesome - $30 is a no-brainer!
