April 21, 2026, 06:44:10 am
I'm in ontario canada and it cuts out quite a bit on me, I try connecting through a proxy and it always works. So for whatever reason hyperpin servers are blocking certain ip addresses. I should add emumovies is the same
Quote from: brad808 on March 09, 2011, 07:10:36 amI'm in ontario canada and it cuts out quite a bit on me, I try connecting through a proxy and it always works. So for whatever reason hyperpin servers are blocking certain ip addresses. I should add emumovies is the sameHyperSpin and Emumovies are hosted on the same server. I have checked and we don't have any ip's blocked.
Hey Dazz,While I have your ear, is there any control layout view in HS for each game? or any plans to add that feature? I am still a noob with HS. Thanks, D
No, nothing built in and nothing planned for now. CPWizard does a good job when setup correctly.
Quote from: Dazz on March 11, 2011, 07:27:06 pmNo, nothing built in and nothing planned for now. CPWizard does a good job when setup correctly.Not user CPs, what I meant was the view of the game's original controls. So when you play you know what the buttons for the game were. I know I can access this in the mame settings, but other FE show screenshots of the original panel. Is this possible in HS?
Actually, we think this may be fixed.
