Author Topic: Turbotwist2 dimensions?  (Read 3628 times)
robertsig
  • Last login:April 14, 2025, 12:28:52 pm
« on: February 10, 2011, 06:35:12 am »
Does anyone know what the dimensions of the TT2 spinner are?  I'm mostly concerned about the depth needed to fit it below a metal panel.
Ambaratur
  • Last login:February 12, 2019, 08:55:13 am
Re: Turbotwist2 dimensions?
« Reply #1 on: February 10, 2011, 09:32:35 am »
I just bought 2, I measured one and it is 3 1/8 inches deep from the panel top.  This includes the extra weight attached to the bottom.  (I don't really want to remove the weight so if you want the measurement without it you will have to wait for someone else.)
VanillaGorilla
  • Coin detected in pocket
« Reply #2 on: February 10, 2011, 04:33:59 pm »
Who would use it without the weight? It fits fine below the metal panel on a Major Havok Conversion CP, and an Arkanoid panel....
robertsig
« Reply #3 on: February 10, 2011, 05:25:12 pm »
Well, I'm not using one of those panels.
VanillaGorilla
« Reply #4 on: February 10, 2011, 05:56:10 pm »
Ok, should I just keep guessing then?  :blowup:
robertsig
« Reply #5 on: February 10, 2011, 06:37:31 pm »
Sure, if you like.  I only asked for the dimensions.
dfmaverick
« Reply #6 on: February 10, 2011, 07:25:32 pm »
"If operation as a spinner is desired and a lightweight knob is to be used, it is strongly recommended that the optional Energy Storage Cylinder (ESC) is purchased."
"No ESC Required - The Energy Storage Cylinder is no longer required for prolonged spin when you use the TokenTop knob. Reduces the vertical footprint of the TurboTwist 2 to an amazing 1.5" below 3/4" wood panels with no spinner performance penalty!"
robertsig
« Reply #7 on: February 10, 2011, 09:05:37 pm »
Thanks, I did see that on their site.... although that statement is worded in a way that makes me think it would *not* be a mere 1.5" below a 3/4" wood panel without the Token knob.  I don't see how, so I'll have to buy one and take a chance.
HanoiBoi
« Reply #8 on: February 10, 2011, 11:25:22 pm »
Based on replies, sounds like its 2 1/4" without the weight and about 3 1/8" with.
I think your statement about the TokenTop knob is correct.  The point there, I believe, is that the TokenTop has some weight to it that would eliminate the need for the ESC.
Do you know your depth restriction?
If you've got about 3 1/2", then you're good either way.
robertsig
« Reply #9 on: February 11, 2011, 06:33:43 am »
For a small bartop I was thinking of buying, I believe I only have 2 inches below the panel.  I'll have to verify.
HanoiBoi
« Reply #10 on: February 11, 2011, 12:23:49 pm »
Depending on the build, there may be more clearance if you plan on mounting toward the back of the CP.
Just something to consider.
RandyT
  • Last login:April 16, 2026, 01:13:33 pm
    • GroovyGameGear.com
« Reply #11 on: February 11, 2011, 12:37:24 pm »
I can build a special, low profile unit, if you need one.  Depth from top of panel is about 1.75"
robertsig
« Reply #12 on: February 11, 2011, 12:56:51 pm »
Excellent!  That would be perfect.  I'll contact you when the time comes.
