Author Topic: Ambient Arcade Sounds  (Read 2982 times)
GadgetBoySI
  • Last login:September 19, 2010, 06:42:32 am
    • Lazy Automation
« on: September 04, 2010, 08:22:43 pm »
I had found some online a while ago, but due to a hard drive failure I lost them. Anyone know where to find them?
My second question is, Do you play ambient arcade music (to simulate being in an arcade) while you are playing games?
I have seen videos of people's setups with it playing in the background.
Also, if you are playing it, are you playing it on the same PC or are you playing it on something different?
Thanks for the thoughts
GB
LazyAutomation - www.lazyautomation.com
la·zy [ley-zee] - Resistant to work or exertion; disposed to idleness.
au·to·ma·tion [aw-tuh-mey-shuh n] – The automatic operation or control of equipment, a process, or a system.
WhereEaglesDare
    • My HomePage
Re: Ambient Arcade Sounds
« Reply #1 on: September 04, 2010, 08:31:53 pm »
http://tinyurl.com/24lkpmo
and I dont use the ambient sounds, id rather have music playing.  Its really neat for about 20 minutes then it gets to where I cant bare it any longer and I want to slam my stool through the machine just to get it to stop making that noise!!
« Last Edit: September 05, 2010, 08:34:11 am by WhereEaglesDare »
Hoopz
  • Last login:April 14, 2026, 11:47:32 pm
  • Intellivision Rocks!
« Reply #2 on: September 04, 2010, 08:37:41 pm »
Here's the link.
http://arcade.hofle.com/
The developer is a member here (ahofle).
Hoopz
« Reply #3 on: September 04, 2010, 08:38:53 pm »
And I didn't see the other question.  I think almost everyone plays it on the same PC.
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
« Reply #4 on: September 04, 2010, 09:37:40 pm »
Thats too cool!
I could easily go to sleep listening to that    :laugh:
When my game room is complete im going to turn on the blacklights and pump that music up
My MAME Build:
GadgetBoySI
    • Lazy Automation
« Reply #5 on: September 04, 2010, 09:57:57 pm »
How do you run it concurrently with the game sound f/x?
Ginsu Victim
  • Comanche, OK -- USA
« Reply #6 on: September 04, 2010, 10:10:21 pm »
A really good gameroom makes those sounds already ;)
GadgetBoySI
    • Lazy Automation
« Reply #7 on: September 04, 2010, 10:13:26 pm »
Rub it in - Trust me - if I had the space I would have the games... Limited to one, and that's MAME...
Ginsu Victim
« Reply #8 on: September 04, 2010, 10:40:59 pm »
That's all I have.
Smeghead
    • MY MAME BUILDS
« Reply #9 on: September 05, 2010, 02:39:24 am »
Run winamp looping it in the background!
My MAME Build:
SlayerAlex
  • Last login:September 17, 2011, 09:19:27 pm
« Reply #10 on: September 05, 2010, 03:35:34 am »
i use mala as a front end and it allows you to play a song in the background. i imagine most other frontends would do that too. its pretty sweet.
i usualy play the ambient sounds or play a rockin 80's sound track.
GadgetBoySI
    • Lazy Automation
« Reply #11 on: September 06, 2010, 12:04:16 pm »
Is there an easy way to launch a media player via a batch file?
Smeghead
    • MY MAME BUILDS
« Reply #12 on: September 06, 2010, 07:30:42 pm »
"C:\Program Files\Windows Media Player\wmplayer.exe" c:\filename.mp3
My MAME Build:
GadgetBoySI
    • Lazy Automation
« Reply #13 on: September 06, 2010, 07:55:40 pm »
Ok, that was easy (and I feel dumb)...
However, is there a way to run a batch file to stop the music?
Then I could have 4 batch files to start each mp3, and a fifth to stop the background music.
Smeghead
    • MY MAME BUILDS
« Reply #14 on: September 06, 2010, 10:07:56 pm »
You could run a batch file to kill the process that mplayer is using I guess like the 'kill' command
maybe theres some media player with CLI
EDIT - yeah theres a winamp plugin that gives you command line control called CLAMP
« Last Edit: September 06, 2010, 10:25:44 pm by Smeghead »
My MAME Build:
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #15 on: September 07, 2010, 02:11:55 pm »
You can always add a 2nd sound card and play the audio in external speakers away from your mame cabinet. That's what I did before I started collecting arcade games. It gives a much better immersive effect IMO. See my sig for software specifically designed to do that (can also be used to play the sounds on your primary sound card if your front end doesn't do it).
Ginsu Victim
« Reply #16 on: September 07, 2010, 02:34:18 pm »
I'd planned on trying your software back when you first released it, but never got around to it. Now my cabinet is in the living room and there's no way I could it.
