Author Topic: What's the best button to use for new I-Pac Volume Control?  (Read 3702 times)
mark shaker
  • Last login:March 04, 2022, 09:27:06 pm
  • Oh Crikey!
    • Mark's Basement Arcade
I'm thinking some sort of DPDT self centering rocker switch.
The Happ Up-Down Shifter would be a bit much.
I'm looking for a dedicated switch (not using the shift function).
Any suggestions?
   - Mark
DashRendar
Re: What's the best button to use for new I-Pac Volume Control?
« Reply #1 on: July 22, 2010, 11:37:06 am »
If it's for the IPAC, then it's controlled by keystrokes.  I assume you'd have one button for Volume Up and another button for Volume Down.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: July 22, 2010, 11:48:25 am »
Right, but he's asking the best alternative to that. I think the rocker switch sounds like a good idea.
EVEGames
  • Last login:December 03, 2025, 10:06:10 pm
« Reply #3 on: July 22, 2010, 06:00:11 pm »
Any suggestions?
   - Mark
Not trying to complicate a seemingly simple question, but are you committed one way or the other to a software solution vs. a hardware solution?
In other words, it sounds like you are going the route of controlling the Windows volume via some kind of switch or switches, through the IPac, with kind of software such as ahofle's CabVol app(http://forum.arcadecontrols.com/index.php?topic=69901.msg714459#msg714459).  In this case yeah, a self-centering DPDT rocker switch sounds like a good choice.
The alternative being, keep the Windows volume always at Max, extend the wires on your amplifier's volume pot, and mount the pot on top of the cab, beneath the CP, behind the coin door, etc.
Ginsu Victim
« Reply #4 on: July 22, 2010, 08:14:04 pm »
With the new ipac firmware, he doesn't need cabvol.
EVEGames
« Reply #5 on: July 23, 2010, 10:33:26 am »
All of a sudden Mark's subject line for this thread makes perfect sense - just saw Andy's thread this morning, somehow missed it yesterday.  Please ignore my ramblings above.  ;D
-EVEGames
Blanka
« Reply #6 on: July 23, 2010, 10:35:50 am »
Best way would be shift+spinner. But that is very difficult to code I guess. So now shift up/down is excellent too.
Ginsu Victim
« Reply #7 on: July 23, 2010, 12:12:36 pm »
bkenobi
« Reply #8 on: July 23, 2010, 02:35:54 pm »
How about this?
http://www.radioshack.com/product/index.jsp?productId=2062530
You should do a search with the following terms if you want more selection:
spdt center off momentary
Alternately, do a search for "power window momentary switch".  I found the following one that looked like a possibility (second from the bottom).
http://www.wiringproducts.com/contents/en-us/d88.html
« Last Edit: July 23, 2010, 02:46:00 pm by bkenobi »
EVEGames
« Reply #9 on: July 23, 2010, 03:01:11 pm »
Correct me if I'm wrong, Mark, but I think you only need a SPDT self-centering rocker switch for your purposes, such as this:
http://www.radioshack.com/product/index.jsp?productId=2062532
DPDT could be used as well, but why bother with the extra terminals (and cost)?  :cheers:
-EVEGames
EDIT: Or would the common Ground terminal present a potential problem??
« Last Edit: July 23, 2010, 03:02:59 pm by EVEGames »
Ginsu Victim
« Reply #10 on: July 23, 2010, 03:05:31 pm »
Power window one is the exact style I was thinking.
Blanka
« Reply #11 on: July 23, 2010, 04:09:57 pm »
He asks the best way. Not for himself but as a general question. IMO my suggestion would be the best solution for volume control.
Ginsu Victim
« Reply #12 on: July 23, 2010, 04:14:30 pm »
But he asked specifically:
Then stated he wanted dedicated functions, not shifted.
