Author Topic: Mini Trackballs? Possible?  (Read 17233 times)
transfan
  • Last login:April 07, 2011, 11:38:37 am
« on: July 13, 2010, 12:53:00 pm »
Is there anything stopping one from using an actual trackball mouse (like a trackman), removing the case, and mounting it to a control panel?
my CP does not have a lot of space, and I would love to have access to a mouse on the cp.
However, would it work well for trackball-based games?
If not, any other ideas?  I don't have much room for a 3" trackball
I've seen other hacks like deoderant balls to the same end.
jholman76
Re: Mini Trackballs? Possible?
« Reply #1 on: July 13, 2010, 01:17:12 pm »
I'm not stopping you, if you are asking...
go for it, try it out. post the details, etc etc etc
transfan
« Reply #2 on: July 13, 2010, 01:23:01 pm »
I was just wondering if anyone else had tried this before with successful results?  I would hate to waste the money buying a trackball for it not to work.
Silas (son of Silas)
« Reply #3 on: July 13, 2010, 01:26:48 pm »
I would imagine it would feel kinda weird for a while adjusting to playing with a smaller ball, but I see no reason why it wouldn't be possible. Give it a try and see how it goes.
My Project MAME clone
Who is Silas?
« Reply #4 on: July 13, 2010, 01:27:33 pm »
Yes, long before we had several trackball suppliers, people used trackball mice. There was a specific model designed for young kids that was especially useful. I believe it was made by Crayola. Once your done piddling around trying to get it to work, you'll see why no one does it anymore. Same for keyboard hacks.
transfan
« Reply #5 on: July 13, 2010, 02:09:46 pm »
I guess I will just omit the trackball, since I don't have room for a full-size one anyway.
z
  • Last login:September 09, 2022, 01:14:24 pm
  • there will always be one more thing to tweak
    • arcademic hall
« Reply #6 on: July 13, 2010, 02:23:03 pm »
On my first cab I decased the clear CompUSA trackball, leapinlew was right as I ended up disappointed with the results.  You can control things okay but the lighter trackball and lack of freespin change the feel for games like centipede and missile command.
Lifetime Student at   Arcademic Hall  (uprights with a minor in cocktails)
Ginsu Victim
  • Comanche, OK -- USA
« Reply #7 on: July 13, 2010, 02:29:02 pm »
I use a Logitech trackball that I pull out of the coin door when needed. I have a space in the center of my control panel with enough room to place it. Works quite well for most stuff I play. One day I'll get a real one.
Comtek
  • Last login:June 02, 2017, 07:17:42 am
« Reply #8 on: July 13, 2010, 03:43:07 pm »
I used the same track ball. I mounted it in the control panel and it worked fine other than the spin time is short but it works quite well
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #9 on: July 13, 2010, 04:16:44 pm »
I've used that same trackball as well. It's got a nice small footprint. As I recall I "overclocked" the USB port up to somewhere around 700Hz for less backspin.
Of course the ball isn't held in very tight. On at least one occasional I caused it to fly off into the screen.
I also found the downward sloping angle of the comfortable way to use the ball a little off-putting for game play.
Ginsu Victim
« Reply #10 on: July 13, 2010, 04:19:14 pm »
Mostly I just play stuff like Centipede or Missile Command with it. No Golden Tee for me.
transfan
« Reply #11 on: July 13, 2010, 05:30:01 pm »
Check out
You might even be able to use the "scroll ring" as a spinner...
z
    • arcademic hall
« Reply #12 on: July 13, 2010, 05:37:31 pm »
Nice find, only $30 w/free shipping.
http://www.amazon.com/Kensington-K72337US-Orbit-Trackball-Scroll/dp/B002OOWB3O/ref=sr_1_5?ie=UTF8&s=electronics&qid=1279056859&sr=8-5
That would be sweet for coming out of a coin door on a cocktail cab.
Ginsu Victim
« Reply #13 on: July 13, 2010, 05:47:51 pm »
Wow! Great price! I WANT!
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #14 on: July 13, 2010, 06:42:09 pm »
Randy's supposed to make one that fits in a button hole.    ;) (big wink to Randy)
Yeah you can use a track mouse, but the balls in those tend to be light, yes? So you don't get much spin. That certainly affects many trackball games that depend on getting some good ball inertia going.
NO MORE!!
« Reply #15 on: July 13, 2010, 07:04:29 pm »
I use this on my computer and (in my opinion) it's not great for MAME or gaming (Hamsterball).  You can control it, but fast movements like that on an arcade machine will not work great.  Poorly in fact.  My trackball is night and day compared to the Logitech.
DeLuSioNaL29
BobA
  • What Me Worry?
« Reply #16 on: July 13, 2010, 07:23:36 pm »
It has all been tried before but nothing beats are real arcade trackball.
Ginsu Victim
« Reply #17 on: July 13, 2010, 11:31:40 pm »
DeLuSioNaL29
That's why I said it "works quite well for most stuff I play," which means not every trackball game, only the ones I find decently playable with it.
newmanfamilyvlogs
« Reply #18 on: July 14, 2010, 06:29:12 am »
While we're discussing PC trackballs, in my last 'scavenge parts from wherever' cab, I ended up with this:
The ball is reasonably large and worked quite well for almost all games that I played with it.
It is far from small however.
For scale:
edit: And for comparison, the prior trackball:
bkenobi
« Reply #19 on: July 14, 2010, 11:10:34 am »
There are smaller arcade trackballs available.  The standard 3" one is rather large, but I recall there being several from 1-1/2" up to 3".  The case will be bigger than a standard PC trackball (probably), but it will include mounting hardware that the PC unit won't have.
1-1/2":
http://www.happcontrols.com/trackballs/56020000.htm
2-1/4":
http://www.happcontrols.com/trackballs/565500xx.htm
3":
http://www.happcontrols.com/trackballs/560100xx.htm
FWIW, I have that Kensington trackball.  I played around with it at the store and thought it would work well so I bought it (off ebay of course).  I never ended up doing anything with it, though.  Some day I'll get around to configuring it and giving it a try!
« Last Edit: July 14, 2010, 11:14:53 am by bkenobi »
RayB
  • There's my post
    • RayB.com
« Reply #20 on: July 14, 2010, 11:22:10 am »
Too bad Happ's pricing on the small one is *INSANE*
NO MORE!!
bkenobi
« Reply #21 on: July 14, 2010, 11:24:28 am »
Logitech mini trackball = $30
Happ 1-1/2" trackball = $250
Gosh, that's nearly a wash.   :o
DashRendar
« Reply #22 on: July 14, 2010, 01:13:45 pm »
The smaller the trackball, the more spinning it will take to move in a game.
Unless you change the poll rate.  But I think you would have less control than with a 3" trackball.
BobA
  • What Me Worry?
« Reply #23 on: July 14, 2010, 01:58:29 pm »
Here are alot of different trackball/mice.   Most under $20
DX link
RandyT
  • Last login:April 16, 2026, 01:13:33 pm
    • GroovyGameGear.com
« Reply #24 on: July 14, 2010, 02:09:59 pm »
"Poll rate" has nothing to do with this issue.  It's geometry+encoder resolution.
In fact, it's not difficult to compete with a standard 3" Arcade Trackball.  The actual resolution of the normal 3" trackball (not our Electric ICE-TB...it has upgraded encoders), given a standard roller diameter of about .435", and a modern "mouse-style" interface, is 662.07 positions per revolution.  The formula is ((Ball Diameter * pi) / (Roller Diameter *pi)) * (Encoder Resolution *4).  Assuming the same size roller (which they aren't, but for the sake of argument), a 2.25" trackball would need an encoder having only a resolution of 32 to equal it.
Now consider dividing the size of the roller in half, and that effectively doubles the resolution given the same size ball.  Therefore, you can scale the whole thing accordingly and have a ball that is 1.5" and a roller that is .2175" and the resolution would still be the same as the standard 3" without changing the encoder resolution.
What does end up different with a smaller ball is your interaction with it.  A small ball with the same final resolution will be "touchier", as the surface you interact with will be smaller.  So even though 1 revolution on each of the balls moves the same amount of distance "on-screen", you don't need to physically roll your whole hand across the ball to get a half-revolution on a tiny ball, rather just a fingertip.
There are many possibilities for small trackballs, but a lot of factors need to be taken into consideration for "feel" of the control.  If it doesn't feel right, it's going to make a poor substitute for the normal "Arcade-Style" control.
RandyT
newmanfamilyvlogs
RayB
  • There's my post
    • RayB.com
« Reply #26 on: July 15, 2010, 11:50:26 am »
$31.50 to ship an item that measures less than 2 inches...   ???
NO MORE!!
newmanfamilyvlogs
« Reply #27 on: July 15, 2010, 11:53:36 am »
Code: [Select]
"US $5.44
United States
US Postal Service Priority MailŪ
4-5 business days"
Where did you get your figure from?
RayB
  • There's my post
    • RayB.com
« Reply #28 on: July 15, 2010, 11:57:43 am »
Code: [Select]
"US $5.44
United States
4-5 business days"
Ah yes, I'm in Canada, so once again screwed by paranoid american sellers.  :(
NO MORE!!
bkenobi
« Reply #29 on: July 15, 2010, 12:02:05 pm »
I shipped an item to a board member a few months back.  If I shipped to the US, it would have been ~$10USD.  Since it was going to Canada, USPS doubled the price to $20.  Apparently there is a mountain that the truck has to get over when crossing the boarder which adds considerably to the cost of gas.  Otoh, maybe it's a head wind...is it less expensive to ship from Canada to the US?
RayB
  • There's my post
    • RayB.com
« Reply #30 on: July 15, 2010, 12:18:19 pm »
No, we Canadians enjoy higher postal services costs, and no mail delivery on weekends. I recently got 2 Xbox games in a padded envelope shipped from California. Cost to the shipper? $4.10 us.  Received in about 7-10 days.
I sent the same guy 3 xbox games, padded envelope: Cost me about $9 cad. Took almost 2 weeks for the package to get to the guy. Do you Americans pay taxes on top of your postage costs? We do.
NO MORE!!
bkenobi
« Reply #31 on: July 16, 2010, 12:42:56 pm »
Ok, well that's one difference then.  I sent a small and light box which required priority mail.  If you used a jiffy mailer, then that can still be 1st class mail (I think) which is MUCH cheaper.  $4 shipping for a couple xbox games seems about right.  $9 for 3 seems a bit excessive, but maybe there was insurance on your end?
IIRC, tax is built into the postage already.
zallax
  • Last login:July 26, 2017, 10:02:28 am
  • It's the challenge of the build
« Reply #32 on: July 16, 2010, 03:57:10 pm »
Thank all of you for not bidding on the Tracksys 38mm trackball on E-Bay.  It made my purchase super cheap for my WIP bartop.
Ginsu Victim
« Reply #33 on: July 16, 2010, 03:59:24 pm »
You're welcome. I almost pulled the trigger several times, but held off.
z
    • arcademic hall
« Reply #34 on: July 16, 2010, 04:22:45 pm »
Apparently Amazon noticed us looking, since I posted on Tuesday the price has gone up from $30 to $33.
Nice find, only $30 now $33 w/free shipping.
Ginsu Victim
« Reply #35 on: July 16, 2010, 04:27:38 pm »
---Deutsche Frankfurters---.
Bender
« Reply #36 on: July 16, 2010, 06:45:33 pm »
I just had to try one out
got a "buy it now" from the same seller for for $30 shipped
RayB
  • There's my post
    • RayB.com
« Reply #37 on: July 16, 2010, 11:11:55 pm »
The seller made it easy by charging too much for shipping to Canada.
NO MORE!!
I/O
  • Last login:June 06, 2011, 01:33:10 am
« Reply #38 on: July 17, 2010, 01:03:17 am »
For some games, I use a combination of stick and trackball. Hamsterball is one of them. Marble Madness I might use a stick instead of my trackball.
« Reply #39 on: July 17, 2010, 11:48:42 am »
WHAT?! That truly is Madness.
