Author Topic: anyone make their own bezel before ?  (Read 2595 times)
Kangum
  • Last login:February 25, 2018, 07:46:20 am
« on: March 10, 2010, 12:17:41 am »
anyone make their own bezel before ? what material did you use, something like poster board or picture mat ?
« Last Edit: March 10, 2010, 03:49:13 am by Kangum »
RobbyMac
  • Last login:November 17, 2025, 02:31:58 pm
  • My New years Resolution is 1400 x 900.
    • My cabinet build
Re: anyone make their own bezel before ?
« Reply #1 on: March 10, 2010, 07:46:24 am »
There is a detailed post/instructions here on making a bezel from poseterboard/foamboard. try searching 'make your own bezel' or something.
I used those instructions as a guideline to making my own. But I made a framework of it to compensate for the curve on my tv face.
check my project in my sig for pics.
  • Last login:Yesterday at 05:46:43 pm
« Reply #2 on: March 10, 2010, 09:22:14 am »
Pixelhugger did.  His instructions are HERE.  It should be pretty easy to duplicate.
ark_ader
  • I glow in the dark.
« Reply #3 on: March 10, 2010, 09:56:08 am »
You could use black gator-board.
Nice and easy to cut.  :cheers:
Kangum
« Reply #4 on: March 10, 2010, 08:40:22 pm »
cant use gator-board. it has to be thin enough to fit between a piece of glass. The obvious solutions like a piece of poster board is not the correct shade of black.
today I went to michaels and had them cut me 2 pieces of black Mat frame. it looks just ok. I wanted it to completely blend in with the underlay. but unfortunately its a different shade of black then my underlay. The only thing I can think of is to have someone cut me whatever material that is that goes under the cocktail glass. I need 2 strips. I wonder if i could buy Just a black blank sheet of it.
I will look up those links also and see what others have used.
« Last Edit: March 10, 2010, 08:48:48 pm by Kangum »
FrizzleFried
    • Idaho Garagecade
« Reply #5 on: March 11, 2010, 09:22:04 am »
Just paint what you have.  If you have a gloss black underlay,  paint the bezel gloss black.  If you have a matte black underlay... paint the bezel matte black... seems pretty easy to me.
Neverending Project
    • Arcade Fixer
« Reply #6 on: March 11, 2010, 01:33:28 pm »
If you want/need a non-flat bezel, the instructions here work great. I used them as an example and made one. Then I used my own to make a second one a little more precise. A bit of gloss black spray paint it is great!
Edit: I missed that you want a flat bezel. But the instructions above are great for non-flat, for sure.
Pixelhugger
  • Last login:April 15, 2026, 10:01:57 am
« Reply #7 on: March 11, 2010, 01:51:45 pm »
 :P
Project mega thread HERE
« Reply #8 on: March 11, 2010, 02:12:57 pm »
 :P
 :laugh2:  Obviously I was joking since you probably thought about your bezel more than most people think about their entire cabs (and the result speaks for itself).   :cheers:
TOK
  • The Game Always Wins
« Reply #9 on: March 11, 2010, 02:26:33 pm »
I used foam board and painted it. Its rigid enough to stand on its own.
The only thing you have to be careful about is choosing a paint with propellant that won't eat the foam on the cut edges. I used Testors spray in the little 4oz can, it will not eat foam.
Sledgehammer
  • Last login:March 30, 2017, 04:48:08 pm
  • "Trust me, I know what I'm doing..."
« Reply #10 on: March 12, 2010, 03:14:37 pm »
+1 on foamboard. I have used black foamboard on my 2 cab builds and my Visual Pinball cab and it works out great. Very easy to cut and it's stiff enough to hold itself up with just tape or velcro.
Epyx
  • "You're an oddity"
« Reply #11 on: March 12, 2010, 04:36:10 pm »
Foamboard shade (of black) doesn't matter if you have tinted glass, you won't notice the difference in shade.
If you are looking to make a non-artwork based bezel...you can do a number of things:
- 1/2" MDF with laminate (my current method)
- Painted plexi/glass
- Posterboard between glass
etc etc
« Last Edit: March 12, 2010, 08:46:35 pm by Epyx »
Last Project
Epyx Tutorials:
Tutorials
