Author Topic: Braniac required  (Read 1095 times)
Apollo
    • Eight Bells
Braniac required
« on: July 23, 2003, 07:11:27 am »
 have just bought a cab with a 26" monitor. I had always planned to buy a cab with a 15Khz monitor and use an ArcadeVGA card. I have just realised that I have no idea what the res of this monitor is. It is a Toshiba monitor and on the tube is a sticker that says A66JLH90X01 (zw) and then just underneath 8935. Does anyone have any ideas? Or do you need more info. How do I find out what res it is?
Thankyou.
paigeoliver
  • Awesome face!
Re:Braniac required
« Reply #1 on: July 23, 2003, 08:16:10 am »
Does it have a VGA plug? If not, then you can rule out VGA res.
That leaves standard res, and mid res. Roughly 95-97 percent of all titles ever produced were standard res, and roughly 90 percent of all mid res games came in dedicated cabinets (no one really made many mid res conversion kits, because there is only a teeny install base of mid res monitors).
Do you have a dedicated cab for a mid res game? If not, then you almost certainly have a standard res monitor.
Mid res ones truly are rare beasts, I have owned over 40 games to date (and nearly 100 boardsets), and never had a mid res game. You are more likely to encounter a vector or B&W monitor than you are a mid res one.
A quick search of Klov.com only showed a handful of mid res games that were not dedicated units, and the majority of those were either incorrectly labeled, or had a dip switch to use standard res.
« Last Edit: July 23, 2003, 08:20:28 am by paigeoliver »
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
Re:Braniac required
« Reply #2 on: July 23, 2003, 08:32:37 am »
I believe you said earlier the cabinet had Bomberman and/or Street Fighter in it. Since I believe those are both STD res games you can pretty much bet that the monitor does STD. It may however ALSO do MED res as some monitors do both.
Coming Soon
Hoagie_one
  • Um....whats a cabinet
Re:Braniac required
« Reply #3 on: July 23, 2003, 10:24:22 am »
Braniac?
Apollo
    • Eight Bells
Re:Braniac required
« Reply #4 on: July 23, 2003, 05:02:52 pm »
Cool thanks for your help.
