Author Topic: Question: Hacking a 4 button Mouse  (Read 2179 times)
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
« on: December 22, 2009, 11:38:13 pm »
Has anyone here ever hacked a four button mouse?
If so can I get the pros and cons? (USB or PS/2).
I need to make a CP that can be used to play Arkanoid  and Astro Blaster.
Any advice would be appreciated.
Thanks a lot.
Darren Harris
Staten Island, New York.
« Last Edit: December 23, 2009, 10:07:12 pm by D_Harris »
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
bkenobi
Re: Question: Hacking a 4-Way Mouse
« Reply #1 on: December 23, 2009, 02:18:11 am »
You can do it, but it can be a pain depending on your application.  I used a mouse to set up my dual 360° steering wheels.  This worked fine except that for some reason the mouse that I chose kept turning the scroll wheel too.  The front end I use didn't have an option at the time to fully disable the mouse, so it really messed with things.  After going through a handful of mice (mostly spare or found ones), I finally got one that worked correctly.
I could have just gotten a U-HID or one of the other cheap ones that RandyT or Andy sell and saved myself some time (but not money).  Ahhh, hindsight...
D_Harris
Re: Question: Hacking a 4 button Mouse
« Reply #2 on: December 23, 2009, 10:23:58 pm »
If anyone has the make and model number any 4 button mouse used in a successful hack, please let me know that info.(I need it for a CP that will have four buttons and one spinner).
Thanks.
Darren Harris
bkenobi
« Reply #3 on: December 24, 2009, 01:27:30 pm »
I have a few that I hacked and didn't use sitting around here somewhere.  If you want one, PM me.
D_Harris
« Reply #4 on: December 24, 2009, 08:45:06 pm »
Well, just the make and model info would be ok. (I need to have "right", "left", "fire" and "warp" on this control panel).
Thanks.
Darren Harris
bkenobi
« Reply #5 on: December 25, 2009, 11:57:56 am »
I have used several different ones that I had access to.  In the end, I bought a cheap one that was USB (all of the other ones I looked at were PS/2).  Pretty much any mouse can work, but some are better than others.
What really matters is how you are going to actually interface the mouse to the hardware.  I used the Atari PCBs that came with the steering wheels.  If you are planning on using the sensor on the mouse, you will need to be more discerning.  I would suggest looking at older mice over newer ones since the older stuff is less integrated and uses larger components and traces (thus making it easier to work with).  I just desoldered the optical components and the buttons and put leads on them.  Technically, you can do that with any mouse, so there's nothing special about any of them.
D_Harris
« Reply #6 on: January 02, 2010, 10:41:31 pm »
Ok, I guess I'm just going to have to go the trial and error route.
Thanks.
Darren Harris
