Author Topic: KEYBOARD HACK  (Read 1810 times)
MameMaster!
  • Engage number one!
    • Mame Invaders!
KEYBOARD HACK
« on: July 18, 2003, 04:58:32 pm »
GREETS ALL.
I'm trying to figure out if there's a way to take my keyboard (which I'm presently accessing through my coin door on my arcade cab); and access the all important:
Escape, Tab and Pause buttons
from some sort of external buttons I can rig up.
Any suggestions?....does anyone know if I can literally take a key off and wire it with an arcade button?
I've thought about externally mounting a mini keyboard as a drawer on my machine is not an option.
The Mame Master!
AlanS17
    • AlanS17
Re:KEYBOARD HACK
« Reply #1 on: July 18, 2003, 05:10:22 pm »
What's the objection to leaving it in your coin door? Inconvenience? Plus, do you have have any buttons at all left over from your encoder (keywiz, ipac, jpac, etc) that you haven't used? (assuming you're using an encoder)
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 08:40:02 pm
Re:KEYBOARD HACK
« Reply #2 on: July 18, 2003, 05:13:25 pm »
why not assign let say ESC in MAME (general) to be one of the buttons on player along with another button like the p1 start. So in order for you to ESC, you must push both button. Chose which buttons you want ( acombination of 2 buttons).
Free VGA Breakout Cable
Zeitgeist
  • Last login:June 05, 2013, 05:57:51 pm
Re:KEYBOARD HACK
« Reply #3 on: July 19, 2003, 01:03:49 pm »
Thenasty has your answer.
Just configure two buttons that you will not push at the same time to do this for you.
Or if you have one button left over, use it like a shift key.
Good luck.
Z
« Last Edit: July 19, 2003, 01:04:20 pm by Zeitgeist »
There is a theory which states that if ever anyone discovers what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
Re:KEYBOARD HACK
« Reply #4 on: July 20, 2003, 07:26:09 pm »
In answer to your question, you can do that, but you don't want to.  Even if you don't have a keyboard encoder like the IPac, you'd save yourself time and probably also money just buying one and using it instead.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
MameMaster!
    • Mame Invaders!
Re:KEYBOARD HACK
« Reply #5 on: July 21, 2003, 10:04:21 am »
The Nasty--- you da' man.
That's so simple and straight forward. I sometimes always make these things more complicated than necessary.
thanks for an excellent suggestion.....
....oh by the way, regarding the "why not just open the coin door".....it "break" the experience for me.....you don't open a coin door in the arcade.... ;D  (OK....so I'm trying to keep it real!  :P
Thanks for all of the suggestions!!!
The MameMaster
Thenasty
Re:KEYBOARD HACK
« Reply #6 on: July 21, 2003, 11:18:53 am »
glad you got what ya looking for. :) ;D
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:KEYBOARD HACK
« Reply #7 on: July 21, 2003, 01:39:42 pm »
Assuming you only use mame :)  You may find more emulators you like.  Just a heads up.
