Author Topic: Tracball trouble!  (Read 1468 times)
numbnutz48
  • Last login:October 19, 2017, 04:30:39 pm
Tracball trouble!
« on: October 28, 2009, 09:47:00 pm »
I have a HAPPS tracball that works with my maximus frontend, but not with the games? I can use it to scroll through my game list but i cannot use it once the game starts? Can anyone help me fix this issue??
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: Tracball trouble!
« Reply #1 on: October 29, 2009, 05:20:11 am »
If it's MAME you're talking about, MOUSE needs to be set to 1 in the mame.ini.
numbnutz48
« Reply #2 on: October 30, 2009, 11:02:39 pm »
Still pretty new at this...Yes it is MAME. What and where is the mame.ini and what exactly do i need to do to remedy this issue?
I really appreciate the help
maddags
  • Last login:March 02, 2011, 03:29:06 pm
« Reply #3 on: October 30, 2009, 11:09:30 pm »
The MAME ini file is located in the MAME directory, just open it with note pad and the entry where it says MOUSE =0 to a 1. then save the file.
numbnutz48
« Reply #4 on: October 30, 2009, 11:29:07 pm »
there are 2 seperate mouse settings it looks like. i have a setting for MOUSE which is set to 1 alread, and then there is a setting for TRACBALL MOUSE which i just set to 1 also, will that work
maddags
« Reply #5 on: October 30, 2009, 11:33:20 pm »
I'm not at home right now to check, give a try and see
numbnutz48
« Reply #6 on: October 30, 2009, 11:34:37 pm »
still not working???? :angry:
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: November 02, 2009, 02:23:30 pm »
What version number?
(Current and recent mames don't have that second option.)
Robin
Knowledge is Power
numbnutz48
« Reply #8 on: November 03, 2009, 10:07:50 pm »
MAME32
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: November 04, 2009, 12:09:33 pm »
Okay, which mame32 number?
Mame32 was a variant of official mame, and shared the same version number as the matching mame it was built from.  It shares the same changes, features, and settings, too.  Version numbers is zero dot something, such as 0.135 (the current version number) or 0.99 (released 06 Aug 2005).
Robin
Knowledge is Power
numbnutz48
Re: Tracball trouble! FIXED!!!
« Reply #10 on: November 04, 2009, 11:27:54 pm »
I downloaded the current version of MAME and it seems to have fixed the issue, although for some reason i can't seem to load some games like asteroids and a few others? Oh well, the main thing is that the tracball issue seems to have been solved at this point.
Thanks to all who pointed me in the right direction to fix this problem, and i appreciate your patience for my unintentional "double post" on the subject!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #11 on: November 05, 2009, 12:25:40 pm »
Sometimes, especially if you jump a large number of versions of mame, a romset may have been fixed (aka changed), so that the old romset doesn't match what the new mame is looking for.  (mameFAQ)  If you look up a game in MAWS, it will list which versions of mame the romset changed.
Which is why again I ask, "what version of mame32 were you using?"  (Help menu & click About.)  Trackballs worked in older versions also, but the causes could have been different, and thus the how to fix is different, too.
Or you can update your romsets and forget the old mame32.
Robin
Knowledge is Power
