Author Topic: UAII - Anyone improved the keyboard tray?  (Read 1454 times)
Endaar
  • Last login:December 31, 2024, 05:51:19 pm
« on: October 12, 2009, 03:00:06 pm »
Hi All,
Subject pretty much says it all. I've got a UAII kit, and as anyone with one knows, the keyboard tray is impossible to use with the front outside panel installed. It would be great if there was a neat way to hinge the front panel so that it could be easily folded out of the way. Since the tray mounts mid-way in the outer panel, I can't think of a good way to do this.
Thoughts?
Thanks,
Endaar
jeffremiller
  • Last login:January 03, 2011, 05:55:16 pm
  • No matter where you go... There you are...
Re: UAII - Anyone improved the keyboard tray?
« Reply #1 on: October 12, 2009, 03:59:53 pm »
I used a long brass hinge instead of the cam locks on mine.  I added a magnetic latch so it would be held vertical when closed and added a wrist rest velcro'd to the front piece.
When I release the mag latch, by giving it a gentle push, the front flips down to reveal the wrist rest, keyboard and mouse.
about $10 and an hour and I now have a usable solution.
"If all wishes were gratified, many dreams would be destroyed." - B. Banzai
ahofle
    • Arcade Ambience Project
« Reply #2 on: October 12, 2009, 04:06:20 pm »
I also used a piano hinge that flips the panel down 180 degrees instead of sliding it out with the tray.  The tray and keyboard then slide out with nothing in the way.  I also added a lock to keep it shut.
Endaar
« Reply #3 on: October 12, 2009, 04:40:51 pm »
That sounds like it would be perfect. Can I pester you for a pic or two?
Thanks, Endaar
ahofle
« Reply #4 on: October 13, 2009, 09:44:21 pm »
Not the best pics, but you get the idea...
Endaar
« Reply #5 on: October 14, 2009, 10:07:02 pm »
Thanks much, that's very helpful. :)
