Author Topic: daemon (virtual cd) question  (Read 1481 times)
tony.silveira
  • Last login:February 18, 2026, 09:58:05 pm
    • my baby
« on: September 06, 2009, 01:42:39 am »
hi all,
i can't find this info anywhere and everyone on here has been extremely helpful so i thought i would ask...
i use daemon tools to mount cd's thru my front end (mamewah) for cd consoles.  when i select a game, the explorer window opens (as if i were on the desktop, put a cd in, the explorer window pops open to show the contents of the media) over the front end for a second or two before the emulator loads up.  when exiting the emu back to the front end, you can see the discs window again as daemon works on unmounting the image.  it goes away and i'm back to the front end.
i'm looking for any advice on how to keep the window from opening when inserting a disc or mounting a disc image.
the weird thing is that this window doesn't open every time and i'm not sure why.
any help is appreciated folks, tony
Epyx
  • "You're an oddity"
Re: daemon (virtual cd) question
« Reply #1 on: September 06, 2009, 04:18:54 am »
if you go to start->run-> gpedit.msc
then go to
computer configuration
administrative templates
system
Check here to ensure its turned off globally (assuming you have turned it off elsewhere.
Last Project
Epyx Tutorials:
Tutorials
tony.silveira
    • my baby
« Reply #2 on: September 06, 2009, 06:57:57 am »
that did her, thanks so much!  i had to hunt around a bit to find the 'auto start' disable but it did the trick.
thanks again man, tony
Epyx
« Reply #3 on: September 08, 2009, 07:39:09 pm »
No problem. Glad it helped :)
Last Project
Epyx Tutorials:
Tutorials
