Author Topic: remember last selected game list and game  (Read 3562 times)
Jimbo
    • Wood Finishes Direct
« on: August 25, 2009, 04:27:39 pm »
Hi
Maybe I'm stupid, or maybe I just missed it, but how do I get MaLa to remember my last selected gamelist and game whenever I start it?
For example, I have a "Favourites" gamelist setup, which I'm always using, but whenever MaLa loads, it always starts at the top of the tree and I have to manually navigate there every time.
I tried the "track selected game list and game" in GUI->Options->Game Lists, but this doesn't solve it.
I'm using v 1.04.
Cheers  :cheers:
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: remember last selected game list and game
« Reply #1 on: August 25, 2009, 08:33:04 pm »
how are you closing mala, if you close by just pressing the power button to shut your cab down or right click and exit it wont save where you are, if you use malas shutdown method it will save where you were
Jimbo
« Reply #2 on: August 26, 2009, 03:41:45 am »
Hi
Yes I'm closing using the exit button on my CP (assigned to ESC), which asks me if i'm sure I want to quit, then takes me back to the desktop - so I guess it *should* be saving, but it isn't. :(
Any ideas?  Have I got the wrong setting? I couldn't find another related setting...
cheers
dungbeetle46
« Reply #3 on: August 26, 2009, 05:06:05 am »
under
gui
options
gamelists
put a tick in track selected game and gamelist
see if that helps
Jimbo
« Reply #4 on: August 26, 2009, 07:35:08 am »
Hi,
Already tried that (see first post).
dungbeetle46
« Reply #5 on: August 26, 2009, 07:42:24 am »
PM sent
« Reply #6 on: August 26, 2009, 08:17:31 am »
You don't have any files in the MALA dir set to read only do you?
That might prevent it saving state....
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #7 on: August 26, 2009, 02:49:39 pm »
He's using the Tree type layout.   I don't use that; does it definitely normally save your last position when using the Tree layout?
Jimbo
« Reply #8 on: August 26, 2009, 06:42:54 pm »
Hi guys... ok I figured it out...   seems the quit button is the same as the "go to parent menu in the tree" button... so there's no way to quit from MaLa unless you first go back to the top of the tree.  Am I right?
