Author Topic: Any way to add shift key functinality to a gamepad hack?  (Read 2011 times)
Hoagie_one
  • Um....whats a cabinet
« on: July 08, 2003, 03:13:39 pm »
I'm hacking a sidewinder and I th ink Im gonna be a couple buttons short to what I want to do.  Any way to add shift functionality.
Does the mode button work for the sidewinder for this purpose.
Any info on this would be great
SirPoonga
  • Puck'em Up
  • Last login:July 20, 2025, 03:37:24 pm
  • The Bears Still Suck!
Re:Any way to add shift key functinality to a gamepad hack?
« Reply #1 on: July 08, 2003, 03:25:15 pm »
For just mame, yes.  Just configure the inputs in mame to except two inputs at the same time.
Hoagie_one
« Reply #2 on: July 08, 2003, 03:26:31 pm »
I dont understand.  Mame will interpret this as a different key if you do this?
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: July 08, 2003, 03:38:18 pm »
No it will work but it's dangerous.  Say you need a Pause button,
Set MAME so UI cancel is "P or J1Button1 and J1Button2".  Now whenever you press J1Button1 and J1Button2 at the same time (or if you wired a button to both these inputs) MAME will pause.
Of course this can be bad if you pressed these keys together accidentally, so you need to be careful which inputs you choose.
A safe one is UP and Down together, but almost all gamepads block this, so it won't work.
Also, unless your gamepad has a common ground for the buttons you want to combine, this is very complicated to wire.
Hoagie_one
« Reply #4 on: July 08, 2003, 03:49:45 pm »
gonna use teh sidewinder gamepad
SirPeale
  • Green Mountain Man
« Reply #5 on: July 08, 2003, 04:50:51 pm »
I've seen this mentioned in a KeyWiz thread.  How, exactly, do you do an up and down the same time to do this move?
freppa
  • Last login:September 30, 2004, 08:45:31 am
« Reply #6 on: July 08, 2003, 05:00:41 pm »
I think what he means is that you wire up ONE button to TWO inputs which use a common ground.
You get the extra "input" but still use a separate button.
/Freppa
SirPoonga
  • Puck'em Up
« Reply #7 on: July 08, 2003, 05:01:14 pm »
Dangerous?  No different than setting up shift through an IPAC.
Anyway, just make sure the combination is something that probably won't happen.  On my cabinet, even though Ihave na IPAC, I have a dedicated pause button which is also my shift button.  I have shift+player1 button 1 as tab.  In your case without an ipac you would go into mame's input general menu (or better yet use ctrlr files) and setup so pushing a dedicated button (or say player 1 coin button) and player 1 button 1 as tab.
The advantage of having shift outside of mame is just for a few emulators, like emulators that don't allow remapping of some buttons.
Hoagie_one
« Reply #8 on: July 08, 2003, 05:04:42 pm »
this is gonna be a Mame dedicated cab, so it'll work great
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
« Reply #9 on: July 08, 2003, 05:47:03 pm »
I can't think of a way to wire that setup without making both buttons fire together all the time, even when you're not pressing your specially wired button.
If you wire the N-O terminal of your pushbutton to two different pads on the gamepad, then you've wired their terminals together - pressing one button will always trigger both.
Unless you use a double-pole switch, which pushbuttons aren't....   or I'm missing something.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
Tiger-Heli
    • Tiger-Heli
« Reply #10 on: July 08, 2003, 05:48:55 pm »
/Freppa
Exactly, thanks.
Tiger-Heli
    • Tiger-Heli
« Reply #11 on: July 08, 2003, 05:55:54 pm »
True!!!
>Anyway, just make sure the combination is something that probably >won't happen.  On my cabinet, even though Ihave na IPAC, I have a >dedicated pause button which is also my shift button.  I have >shift+player1 button 1 as tab.  In your case without an ipac you >would go into mame's input general menu (or better yet use ctrlr >files) and setup so pushing a dedicated button (or say player 1 coin >button) and player 1 button 1 as tab.
There is a slight difference, but almost not worth mentioning.  Using your example, let's say I set MAME up using a keyboard so TAB is "P and L Ctrl".  On the I-PAC (without changing MAME) pressing the key combination will bring up the TAB menu.  On the keyboard, pressing the key combination will either pause the game, activate P1B1, or both, and THEN bring up the TAB command.  Not that it would make much difference in most games.
Hoagie_one
« Reply #12 on: July 08, 2003, 08:22:15 pm »
This is for my minicab.
I'm gonna have a street fighter setup with 1 stick and 6 buttons.  I'm gonna have two buttons up top, one for coin1, one for start1.  But I need esc, and tab, so I figure that I'll make it so to activate esc, you need to hit coin1 and start1 at the same time and to do tab, ill do coin1 and first attack button
not too worried about a pause but i may go ahead and do them as well
