Author Topic: Mortal Kombat 2 Jamma PCB - Error on boot - why?  (Read 2147 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« on: June 17, 2009, 02:16:52 pm »
I'm potentially purchasing a MK2 PCB from someone... however, he says that
it generates an error on booting but the Rom test and everything else is fine.
I remember in MAME, initial boots of MK2 would always generate an error
and any boot after that initial boot would be error-free... Can anyone fill me
in with what the error might be, what it effect it may have and also if there
is a fix for it and whether booting it again might solve the problem?
Cheers!
  • Last login:February 28, 2026, 04:55:22 pm
Re: Mortal Kombat 2 Jamma PCB - Error on boot - why?
« Reply #1 on: June 17, 2009, 02:40:55 pm »
So does it boot at all?  Is the game playable?
slapaham
« Reply #2 on: June 17, 2009, 02:55:40 pm »
Supposedly functions perfectly, no problems whatsoever and passes all Rom checks... and I trust the guy I'm purchasing off....
« Reply #3 on: June 18, 2009, 09:50:22 am »
prolly dead CMOS battery, change the dip to use switches instead of CMOS and see if the error goes away.
Kevin Mullins
    • Me on Myspace
« Reply #4 on: June 18, 2009, 12:53:41 pm »
Or just change the battery. Then you can still make adjustments and changes via the menu and it will save them in memory.
But I agree, without seeing what the specific error says..... that is probably the number one most common error.
It'll boot up, pop up the error and then continue on reverting back to default settings.
slapaham
« Reply #5 on: June 18, 2009, 01:42:14 pm »
Thanks guys... appreciate the feedback! :cheers:
