Author Topic: A detachable power plug for a scratch built cabinet  (Read 1187 times)
pmowry
  • Last login:September 06, 2016, 11:57:00 am
« on: May 29, 2009, 03:16:59 pm »
Hello,
  Instead of having the cable for my power strip sticking out if the cabinet,  I wanted to add a plug on the back that I could just connect a normal PC power cord so I can use longer or shorter cords, and just look cleaner.  But I can't find a plug and a faceplate to put on the back of the cabinet.  I believe the inlet would be an IEC-320-C14.  Could someone confirm this for me and perhaps suggest a US distributor?
  My local electrical stores were unable to help.
Thank you,
-Patrick
1UP
  • Token Junkie
    • 1UPArcade
Re: A detachable power plug for a scratch built cabinet
« Reply #1 on: May 29, 2009, 03:19:30 pm »
Check Mouser.com and click the Catalog tab.  Search function is useless.
My other job...
1UP
  • Token Junkie
    • 1UPArcade
« Reply #2 on: May 29, 2009, 03:27:22 pm »
Actually scratch that--search is only useful if you have a part number.   :)
See if any of these fit the bill.
http://mouser.com/Search/Refine.aspx?Keyword=IEC-320-C14
My other job...
pmowry
« Reply #3 on: May 29, 2009, 03:31:31 pm »
Wow, thanks.  Now I just have to decide what will look best.  So many options on how to control power on a cab.
Thanks again, especially for such a quick response.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #4 on: May 29, 2009, 03:38:55 pm »
No problem.  A DIYer's two best friends: Mouser.com and Mcmaster.com
My other job...
shardian
« Reply #5 on: May 29, 2009, 04:44:16 pm »
Do you have a junker old pc case to strip? I thought all of us had at least 4-5 of those sitting around?  ;)
bkenobi
« Reply #6 on: May 29, 2009, 06:47:31 pm »
I got mine at Fry's.  If you have one nearby, you can save the shipping.  They were ~$4 as I recall.  I think Mouser and Digikey charge more than that for shipping, so...
