Author Topic: kortek 2914 vga adapter  (Read 1720 times)
tcleary
  • Last login:October 12, 2021, 12:30:19 am
« on: May 23, 2009, 06:31:26 pm »
I got one of these but it didn't have the vga adapter.  anyone know where I could obtain one or a work around for getting from the board to vga?
here is the service manual:
http://www.retroblast.com/files/KT-XX14X-SM.pdf
it looks like I can wire something myself, ultimarc has a vga breakout cable, I ordered one, and I'm guessing I can line up the 6 pins with the associated wire from the vga breakout cable according to page 7 of the manual above. that only leaves me with the question what does "ring wire" mean on the chart. it lines up with rgb grounds and another ground on the d sub 15 pin side. do I need to do anything for those?
thanks for any help.
« Last Edit: May 23, 2009, 06:48:43 pm by tcleary »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: kortek 2914 vga adapter
« Reply #1 on: May 23, 2009, 11:00:39 pm »
ring wire refers to the gnd braid on the connecting cable.
this may be the cable u need :  44-180101800 15P*1800mm KORTEK SIGNAL KT-2914
qrz
MonMotha
« Reply #2 on: May 24, 2009, 03:22:36 am »
You don't need to worry about that "ring" if you don't have a shielded cable.  I seem to recall that it didn't even attach to anything metal on the monitor anyway (weird).
If you wish to make a harness yourself, the cable side connector for PC level signals (0.7Vpp into 75 ohms) is a 6 position Molex SPOX 2.5mm connector p/n 50-37-5063 (housing) 08-70-1040 (crimp terminal).  You can buy these parts at Digi-Key or Mouser easily.
tcleary
« Reply #3 on: May 24, 2009, 03:49:58 pm »
you guys are awesome, I'm sure I'll be able to get it working now.  I ordered a vga breakout cable, so that should do it if I line up the pins.  thanks.
