Author Topic: Galaxian Restore  (Read 20842 times)
SirPeale
  • Green Mountain Man
Galaxian Restore
« on: May 19, 2009, 08:54:22 pm »
I don't have any pictures of the cabinet yet, but it's dirty and rusty.  It was sitting in a barn for a number of years, just like all the other restos I'm doing right now.
I don't have any room @ my house currently for the cab, but I knew the board has issues.   Since the converted Galaxian cab in my boys room still has the factory harness I knew I could use that to at least display video.  We'll refer to this as BOARD 1
I'll doubly document the repairs on another Galaxian board I have.  I bought it several years ago from a BYOAC member.  We'll refer to this one as BOARD 2.
BOARD 1 had serious problems.  The corrosion I talked about?  Definitely on the board too.  The program ROMs I thought were just a bit rusty...nope.   Removed the ROMs to find legs missing and a lot of other legs just fell off.  Yikes.  Good news is that the ones on the other board are just fine.  So I've been swapping them back and forth between the boards when I try something.
Removed the old corroded sockets from BOARD 1 and replaced.  Now I have the beginning of the startup sequence come up for just a second, with a red lined screen.  I can make out "BAD RAM #1" in the flashes.  I know that means I have to replace the 2114 RAM.  I already replaced the 245s.  I don't have sockets or RAM on hand right now, so that'll have to wait until I get them.
BOARD 2 is also problematic.  It appears to not be able to sync correctly.  According to the Galaxian Troubleshooting guide I should check out the IC @ 6H.  I really need to learn how to use my logic probe correctly.  The first time I used it only the green light would flash, but not on all the legs.  The second time I got both red and green to flash on all the leads, but one set read completely different from the rest.  Theorizing that the chip was bunk I cut it out, replaced it with a socket and cannibalized a replacement from a junk board.  It comes up with exactly the same result, so my problems lie elsewhere.  :(
I've tried tracing it out on the schematics, but can only find three of the four addresses on the schematics.   Of course, this may not even be the problem!  I've attached a picture.
SirPeale
Re: Galaxian Restore
« Reply #1 on: May 27, 2009, 06:48:42 pm »
I cut out the 2114 on BOARD 1 and replaced with sockets. I popped in some 2114 I scavenged off a Pac-Man parts board (since it's all I have at the moment) and powered up. Came up with garbage, lots of flashing characters. I double checked my work, found an apparent solder bridge between two pins, and fixed that. I knew the Z80 had a broken pin (that I soldered on a temp replacement) and since I had a replacement I swapped it out.
This time it came up yet again with "BAD RAM #1". But no flashing "BAD RAM #2" in between.
I triple checked my work, making sure my solder joints were sound. They are.
I removed the 245 for giggles to see what it would do, and suddenly I had starfield generation with a garbage screen, but it kind of looked like it was running attract. Swapped that out with another and back to the "BAD RAM #1" screen. Humph. Now what?
SirPeale
« Reply #2 on: May 28, 2009, 04:00:54 pm »
Back to BOARD 2. Since I have a Galaxian board with working sync, I was able to swap back and forth a couple times to check difference.
Pin 6 on 6H is where the composite sync comes out. If I'm reading the schematics correctly it gets the VSYNC from pin 5 of 6F, a 7474. I can't tell where it's getting the HSYNC from. The schematics merely state that comes from the HRDWR CONTROL BUS, but I'm having trouble figuring that part out. Any nudges in the right direction?
channelmaniac
  • Last login:May 11, 2019, 12:36:18 am
    • Arcadecomponents.com
« Reply #3 on: May 31, 2009, 09:34:04 pm »
That pic doesn't look like a sync problem but more like a problem with one of the 74161 chips.
Call me a cheap bastard... I learned to fix things to save money... even surface mount soldering...
Visit my website: http://www.arcadecomponents.com
My repair logs are kept at: http://newlifegames.net/nlg/index.php?board=19.0
SirPeale
« Reply #4 on: June 01, 2009, 08:54:36 am »
If I remove all the EPROMs I should get a solid white screen, but I get a screen that's out of sync.  Also if I compare the outputs of pin 6 of 6H on BOARD 1 and BOARD 2, they're completely different.  On BOARD 2, with the logic probe, both lights flash simultaneously.  On BOARD 1 the flashes alternate.
I guarantee there are other problems than just sync, but I'm trying to tackle one problem at a time.
SirPeale
« Reply #5 on: June 01, 2009, 05:25:43 pm »
Something weird is going on with BOARD 2.
Went to troubleshoot it with the logic probe, and as soon as I attach it to ground and +5VDC, the lights start flashing. That's WITHOUT touching the lead to anything.
I thought maybe I broke it somehow, but tested it on BOARD 1 and it works just fine.
So what would make the probe do that?
channelmaniac
« Reply #6 on: June 01, 2009, 05:36:34 pm »
Bad power supply fluctuations or noise from bad caps. Use a scope to see how much trash is on the 5v line.
SirPeale
« Reply #7 on: June 01, 2009, 06:07:49 pm »
Don't have one, but could certainly use one!
SirPeale
« Reply #8 on: July 03, 2009, 08:19:33 pm »
I swapped out my Centipede Mini into storage so I could start working on this cab.    Pictures when I take them.
I never did take a good look at the cab before now, wow it needs help.  Lots of rust (like all the other cabs from this haul).  Tiny bit of water damage on the bottom.  And FILTHY.  Man, it's gross.  Art needs a lot of touchup.  It won't take long to get this straightened out with concentrated effort.
Neverending Project
    • Arcade Fixer
« Reply #9 on: July 04, 2009, 03:32:15 pm »
How do plan on doing the aet touchup? Mine needs a lot too, and I was thinking about buying a cheap airgun to spray on some touchup, but that would require a lot of masking.
SirPeale
« Reply #10 on: July 04, 2009, 11:03:56 pm »
Acrylic paints and lots of trial and error.
SirPeale
« Reply #11 on: July 05, 2009, 09:04:11 pm »
Finally, some pictures.
Start off with left, front, right and rear shots before I've done anything to this unit.
SirPeale
« Reply #12 on: July 05, 2009, 09:09:09 pm »
A shot of the bezel and coin door/kickplate.
A shot after I stripped all the wiring and the wooden mounting plate from the bottom and before I sanded/cleaned/vacuumed.
I touched up the black paint on the upper part.  Instantly improved things 100%.  I have to go over it again, it's got tiger stripes.
SirPeale
« Reply #13 on: July 05, 2009, 09:14:39 pm »
A shot of the now cleaned wiring (it was disgusting) and the sanded/vacuumed/mopped insides.  Nothing in there is permanent, I just couldn't leave it lying around, so I just tacked it down inside the cab.
Finally, a shot of some of the artwork before cleaning.  I experimented in a couple places to see what kind of chemicals I could use without it melting the ink.  The glass cleaner I use from Auto Zone works very well.  Yes, there is some flaking, but that's not due to the cleaner, it's because it was flaking already.  It all needs to be touched up anyway.
And afterward.  I only did 1/2 of it to give a grasp of the difference.  Picture doesn't show it well, but it's much cleaner.
« Last Edit: July 05, 2009, 10:00:15 pm by SirPeale »
SirPeale
« Reply #14 on: July 05, 2009, 09:20:36 pm »
I've got a lot to do on this.  99.99% of it is cleaning.
  • strip down all metal parts of rust and refinish - done
  • clean the outside, esp the artwork
  • rebuild the CP
  • rewire harness for 4 way joystick
  • repair the wiring, it's been badly hacked in several places.
  • repair the board - sent off for repair
  • Hack the board for multigame
I'll add more as I can think of it, and cross off the list when I accomplish this task.
« Last Edit: September 08, 2009, 04:30:19 pm by SirPeale »
King Nerd
  • Last login:August 19, 2009, 12:12:04 pm
  • Putting the romance back into techromancer.
« Reply #15 on: July 05, 2009, 09:57:55 pm »
It's filthy, but it looks like it's in pretty good shape.
I'd say that the picture doesn't show it well because they're the exact same picture. Check the URLs. ;)
Lookin' for: Neo-Geo MVS x4 board, memory card reader, memory card, credit LEDs
MVS wants: Metal Slug (any), King of Fighters 2002, Puzzle Bobble (any), Rage of the Dragons, SNK vs Capcom, Magical Drop  (any).
SirPeale
« Reply #16 on: July 05, 2009, 10:01:16 pm »
Fixed!  Thanks.
Structurally, it's sound.  Definitely needs love.
King Nerd
« Reply #17 on: July 05, 2009, 10:14:03 pm »
Fixed!  Thanks.
Definitely needs love, but looks like a great base to start with. Wood looks in great shape, no water damage or anything.
Just dirt and artwork, really. Looks a heck of a lot cleaner already, though.
I dunno where you guys find all of these, or find the money for all of these.
I'll be keeping my eye on the progress of this. Good luck.
SirPeale
« Reply #18 on: July 06, 2009, 03:34:52 pm »
Going to start working on the coin door today.  I'll use electrolysis to strip it down.  I'm curious how quickly it'll strip this down.
SirPeale
« Reply #19 on: July 06, 2009, 07:14:17 pm »
Okay, I haven't been feeling well, so I figured to start small.  So instead of the coin door I'm stripping the marquee brackets.  I added several more negative leads to the setup for a larger piece (aquarium stand) and as such now I can do multiple pieces at once now.  I need to get a new sacrificial piece of steel as the one I have in there has since swiss cheesed very badly.
SirPeale
« Reply #20 on: July 08, 2009, 08:25:52 pm »
The labels for the fuses were brown after 30 years.  So I scanned them in and cleaned up the images.
Looked really good, and I printed them out.  Unfortunately my printer missed a couple dots here and there and needed to be reprinted.
For some odd reason, I closed the program instead of saving my work.   :badmood:  So an hour of image cleaning, down the drain.
Unless someone knows the temp file that Paint Shop Pro 4 uses, and I could use that to recover...
RobinHolland
  • Last login:March 13, 2013, 04:07:23 pm
« Reply #21 on: July 09, 2009, 11:12:04 am »
i miss the fuses labels :-\
Have you a scan for me ?  :notworthy:
SirPeale
« Reply #22 on: July 09, 2009, 03:03:10 pm »
I rescanned them, but I'm cleaning them up.  I'll post here the images when I finish.
RobinHolland
« Reply #23 on: July 09, 2009, 03:33:17 pm »
Mimatt
  • Last login:February 13, 2011, 11:59:28 pm
« Reply #24 on: July 10, 2009, 12:26:00 am »
I'm getting all antsy to see the artwork restoration process.
Galaxian's artwork looks so complicated. Even with stencils - repainting that looks like you'd need the patience of a saint. The white backround makes it even more tricky.
« Last Edit: July 10, 2009, 12:28:03 am by Mimatt »
SirPeale
« Reply #25 on: July 10, 2009, 07:43:26 am »
I'm just going to do some touchup.  If it turns out looking too bad I'll probably stop.
Spyridon
  • Last login:April 30, 2021, 02:47:05 pm
« Reply #26 on: July 10, 2009, 11:15:12 am »
Mamemarquees does have the side art available.  2 big drawbacks - 1. Price  and 2. Inkjet
Edit :  Just checked the price and it's not as bad as I thought.  Only $63 for the sideart
For inkjet side art, it doesn't look too bad.  Here is a cab (not mine) done using it:
I know Rich at thisoldgame was planning on doing this eventually, but who knows when that will be?
Neverending Project
    • Arcade Fixer
« Reply #27 on: July 10, 2009, 11:56:58 am »
I saw that and did one of these:  :o  And then I double-checked, since I have priced it out before and did one of these:  :(. The $63 is for tp to 26"x18". If you want the original size (full-size) you need to add $115, which makes it $178 for the side art set. Add in another $40 for the kickplate, and it adds up quick.
Rich once gave me a quote for doing the Galaxian side-art on his solvent inkjet (I think it is the same as mamemarquees?), wihch would be plotter cut to the sideart shape so you wouldn't need to do the entire side. But it wasn't much less expensive than mamemarquees. He also said that the design is too detailed for stencils, and even if you did try it would be far too cost prohibitive.
Spyridon
« Reply #28 on: July 10, 2009, 12:39:04 pm »
Okay, that makes more sense.  I remembered it being $180.  That's a lot for ink jet.  Rich did sell the front kick plate, but I don't know if he has it in stock.  He was looking for the correct vinyl to do the side art.  That was the hold up.
Level42
« Reply #29 on: July 10, 2009, 05:20:26 pm »
Rich sold out the kickplate. Quarterarcade still has them at higher prices......which is why I didn't buy it. That plust the vinyl is just not exactly right. If I spend 60 bucks (without shipping !) for just a kickplate I want it to be 100%.
So I will live with the scratches and stuff......
« Last Edit: July 10, 2009, 05:52:37 pm by Level42 »
SirPeale
« Reply #30 on: July 10, 2009, 07:43:01 pm »
I'm just trying to fix the machine up.  It won't be factory, but it will be nice when I'm done.
Rebuilt the K4600 today after my Mouser order showed up.  Box was mangled, and I was pissed, but the contents were fine.  It was thrashed - broken solder joints on the card connectors, dirty, rusty and of course original caps, I was surprised it actually worked.  I haven't fired it back up yet but will do that this weekend.
I also went to the hardware store and bought new screws.  The originals were quite rusty.   Two boxes (for the different sizes) cost me $14 and change, but I'm sure I'll use the extras on the next project - probably Burger Time.
I need to start working on the coin door.  I already started on the frame, but wanted to wait until I could properly photograph the rest of it.  I've done a dozen Midway coin doors, but on this one I want to try and duplicate the color of the Galaxian as closely as possible.  I've got an idea I think will work, I'll post here if it does.
With my Mouser order I got the one thing that's been holding me up: sockets.  So I'll start tackling the board issues again very soon.
Mauzy
« Reply #31 on: July 10, 2009, 10:54:10 pm »
You sir are a madman.
Anyway, am I the only one who thinks that Galaxian with inkjet sideart looks TOO nice? Its lost all its character! I like my machines to look a damn sight better than they were when I bought them, but I also want people to know its a 20+ year old game that had a commercial life. For example, My DK3 has quarter scratched entries in the coin door. Sure those are relatively cheap to replace, but they add a little flavor. I think making a machine look nice is great, but absolute perfection seems a little over board unless the machine is something really rare or a grail I suppose...
orion
« Reply #32 on: July 10, 2009, 11:57:13 pm »
I remember seeing somewhere that he had found a match for the vinyl but the deal was that it didn't have an adhesive backing. I wish he would make that available as its not that hard to get good results with spay adhesive.
SirPeale, If you are able to get decent results with acrylic paints could you share with all the other Galaxian owners all the info on the brand, mix ratios... ect that you used. In looking at mine it seems to me that testors model paint might be a good paint to start experimenting with. It looks closer to the consistency of the die that they used to me than anything else I can think of. Silk screen ink might be something to look at as well I suppose.
Level42
« Reply #33 on: July 11, 2009, 03:03:46 am »
Mmmm, it depends on many factors. First of all, it's a personal thing. Everyone should judge for themselves. I was just very lucky that my Galaxian was still in such nice shape. Sure it has it's wear here and there and some scratches, but overall, and compared to many Galaxians I've seen, it looks very nice.
If it would have been as bad as Peale's I would have definitely gone the inkjet way. It looks like the colors are a complete match and Mamemarquees printing is as good as you can get inkjet-wise.
I have no problem using injets when it turns a completely shot piece of artwork to brand-new looking. If there are tiny details that are not perfect in the repro, I will live with it. Only I (and other collectors) will notice.
On the other hand, if (when?) Rich will finish the SW cockpit side-art I will definitely order it. From a distance, and on pictures, it still looks pretty nice on my machine, but when you're closer.....
A very big plus is that this will of course be 100% like the originals because he has the original films.
It will also give it the nicer American blue color which I like much better than the Irish one which is more pale.
Anyway, I have no problems if it is possible to have a cab look like factory new at all, in fact it's what I will always try to  reach, but I won't loose sleep over it when it's simply impossible...
So, I will follow Peale's touching up with much interest as would really want to give it a try too :)
Peale, how does Mouser ship their stuff ? USPS ? UPS ?
« Last Edit: July 11, 2009, 03:06:42 am by Level42 »
SirPeale
« Reply #34 on: July 11, 2009, 08:28:23 am »
Pick one - FedEX, UPS, USPS.
I'll post what I'm going to use - regular acrylic paints from Wal-Mart from their craft section.   Mix ratios are useless because I'll be making such small amounts, and the difference between paint lots would toss that out the water.  It's going to be lots of trial and error.
SirPeale
« Reply #35 on: July 12, 2009, 08:47:59 pm »
Another day of work on the beastie.  The electrolysis made the rust come off very easily, so I was able to strip down both marquee retainers, the coin door frame and whatever that metal piece is that sits in the back of the cab in no time flat.  Primed and painted everything but the frame.  Now waiting for it to dry/cure.
More work on cleaning the outside.  Very tedious, working in 6"x6" squares, but it's getting there.  I need to pick up a Magic Eraser.  I've heard they're good on cleaning up the white areas, we'll see.
Had to buy a tool, a "die" - what you would use to thread a hole, except I was using this to open the leg leveler threads back up.  The cab now has levelers again for the first time in a long time.
Got to work replacing the old rusty worn-out screws with the new zinc plated ones.
Started investigating the wiring.  Oddly hacked in a few places, I'll have to see what's what.
Last night I stayed up until 4am capping, cleaning and adjusting the K4600.  It didn't want to work correctly.  Turns out I put two caps in the wrong spots.  Reversed them and now I couldn't get it to sync.  Okay, well...I have another K4600, let's see if the cards from that one can get it to display correctly...yes.  Okay, now we've narrowed it down.  XY card is fine on this, but the other, a P307 card, only accepts positive sync.  Crap.  Well, on Galaxian it should be okay, but I couldn't get it to display a proper picture without the one from the other game.
Placed a florescent fixture in the marquee area that I picked up from the thrift store.  It was one of those that didn't have a starter but you hold the on button down it comes on.  So I removed the button and soldered in a starter.  If I had a starter socket I would have installed that, but I didn't.
I think that's it.  More later.
SirPeale
« Reply #36 on: July 15, 2009, 06:32:52 am »
Worked on BOARD 1 a bit yesterday.  Replaced the sockets on 7H and 7J again because I did a crappy job last time around.  Found a combo of problems ranging from missing traces to missing pads.  Rebuilt the traces as best I could.  Back to getting the BAD RAM #1 error (it had stopped before).  I've got to be more careful in the future.
I also converted the board to be able to use a DC switcher.  Easy conversion, as per here: http://www.arcades.plus.com/galjamm2.htm
SirPeale
« Reply #37 on: July 15, 2009, 06:33:31 am »
I really need to burn a Galaxian Test ROM.  One of those things to save up for.
SirPeale
« Reply #38 on: July 15, 2009, 07:53:49 pm »
I got BOARD 2 to boot!  I converted it to DC and it booted right up.  Dirty power is a nasty thing.  It has graphics glitches, but I'm sure I can sort that.
SirPeale
« Reply #39 on: July 16, 2009, 04:33:06 pm »
I just found something interesting under the logo plate on the coin door: black textured paint.  Like what's found on later coin door styles.  In fact, this door definitely resembles the later doors more than most Galaxian doors I've come across.  Plastic entry slot (though chromed, weird).  Black instead of grey colour.
