Author Topic: New Jukebox build (Final Pics)  (Read 8064 times)
joey1207
  • Last login:February 17, 2021, 10:20:30 am
« on: May 18, 2009, 01:06:41 pm »
Hey all,
Havent put anything on here in quite a while, so thought I would post my latest jukebox. It is pretty basic, I am posting this pretty late in the build, so I will post pics from the beginning to date.
« Last Edit: July 22, 2009, 08:48:10 pm by joey1207 »
joey1207
Re: New Jukebox build
« Reply #1 on: May 18, 2009, 01:13:09 pm »
The beginning
joey1207
« Reply #2 on: May 18, 2009, 01:14:04 pm »
Trim taped in just to see how it looked
control panel cut out, buttons and controller in place just for the pic
« Last Edit: May 18, 2009, 01:16:14 pm by joey1207 »
joey1207
« Reply #3 on: May 18, 2009, 01:19:07 pm »
glued, nailed and bondo'd
after first sanding
after primer, first base coat
all base applied, flames laid out
joey1207
« Reply #4 on: May 18, 2009, 01:21:31 pm »
flames taped off, ready for paint
paint complete
close up of paint colors
speakers and buttons installed
sinkhead
  • Last login:November 08, 2009, 06:24:02 pm
« Reply #5 on: May 18, 2009, 02:06:45 pm »
Wow, that looks great! I love the design and the way the speakers fit right in. How loud is it?
May I ask where you got that little volume control panel on the front from? What else does it do?
joey1207
« Reply #6 on: May 18, 2009, 02:14:09 pm »
Well, to be honest, I havent played the speakers yet! They are 5.25 car audio speakers, and I just painted the grills to match. I stole the little control panel/amp out of some logitech X-140 speakers. According to the specs, it should push 11 watts (5.5 to each speaker), so it should sound pretty good. It is only a jukebox, it will be running SKJukebox. It is a gift for my nephew.
ratzz
« Reply #7 on: May 18, 2009, 02:40:25 pm »
Looks good ... although I do hope that chair you were using to paint on doesn't turn out to be some valuable antique!
Keep up the good work, I'd like to build one of these myself one day ...
joey1207
« Reply #8 on: May 18, 2009, 02:55:51 pm »
Thanks ratzz, no, not an antique!
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
« Reply #9 on: May 18, 2009, 03:42:14 pm »
Wow, Looks good to me!  :applaud:
I'm a little worried the 11watts wont sound good on the car speakers.
I think you need a t-amp or something like that.
Fordman
joey1207
« Reply #10 on: May 18, 2009, 03:46:40 pm »
I hope that is not the case. I tested the speakers on a cheap after market car radio that only put out 14 watts (7 per channel) and they sounded pretty good, and they werent in an enclosure. They are only 20 watt rms speakers, so I hope it will be okay.
Franco B
« Reply #11 on: May 18, 2009, 04:03:56 pm »
Looks great. I was a little worried about where the paint job was going but the final pics are really nice 8)  :applaud:
joey1207
« Reply #12 on: May 18, 2009, 04:23:41 pm »
Thanks Franco, I was pretty worried myself, first time ever for me to lay out flames freehand.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #13 on: May 19, 2009, 03:14:06 am »
Paint job is awsome looks sort of hot rod esq
orion
« Reply #14 on: May 19, 2009, 08:46:26 am »
I like the paint job as well, what kind of paint did you use to get that multi colored textured look? Looks good!
joey1207
« Reply #15 on: May 19, 2009, 08:49:21 am »
Thanks Barry and Orion.
Tha base is Duplicolor Metallic Black, 4 coats with wetsanding between each. The flames are Duplicolor Red, 4 coats, then I wetsanded the whole thing, sprayed a coat of Duplicolor Clear Effex, wetsanded and then another coat of the Clear Effex.
Gatsu
« Reply #16 on: May 19, 2009, 09:51:43 am »
now thats just friggin cool.
« Reply #17 on: May 19, 2009, 05:57:27 pm »
Great work! I too like the paint job. Very original!
 :applaud: :applaud: :applaud:
joey1207
« Reply #18 on: May 19, 2009, 09:43:51 pm »
Thanks Gatsu and Da, I appreciate it much! Didnt get much done today, had a ballgame and a practice to go to, got the terminal strip in, and all the ground wires from the buttons connected, will try to get some more accomplished tomorrow evening.
Kaytrim
  • I'm too nice a guy
« Reply #19 on: May 20, 2009, 09:46:24 am »
Joey,
that is one cool paint job.  I like the rainbow fleck.
Michael
joey1207
« Reply #20 on: May 20, 2009, 02:14:05 pm »
Thanks Kaytrim, I was really nervous about it at first, I am glad so far everyone thinks its okay.
joey1207
« Reply #21 on: May 23, 2009, 12:15:39 pm »
I havent gotten much done, ball games everyday. Got a few minutes in this morning and did a little bit of wiring, still have to clean it up, but its coming together.
joey1207
« Reply #22 on: May 26, 2009, 09:16:18 pm »
k, got the monitor in, and all the components. Plugged it all in for a quick test, this is just playing on media player for the test, but it was amazingly loud and clear with the car speakers and logitech amp, I was very pleased with the sound! Here are a few pics, sorry, not the best, but will post better pics after I clean up the wiring and have it closer to finished.
« Last Edit: May 26, 2009, 09:20:32 pm by joey1207 »
Chris
    • Chris's MAME Cabinet
« Reply #23 on: June 04, 2009, 04:48:01 pm »
Very nicely done!
--Chris
--Chris
orion
« Reply #24 on: June 06, 2009, 07:46:11 am »
Thanks for the info on the paint. I was thinking about trying some automotive paint for a jukebox I am currently working on to see if I like it, but I am unsure as to how well it will work on MDF, however after seeing the results you had with it, I think I'll give it a go. How durable of a finish is it on MDF? Did you have to prime or seal the wood or do anything special to get the paint to adhere correctly?
Tauntonlad
  • Newbie
  • Last login:October 12, 2009, 03:08:01 pm
« Reply #25 on: June 06, 2009, 05:24:28 pm »
How did you manage to wire up the car amp to make the car speakers work is there an easy way to do this via a pc sorry if this is a stupid question
joey1207
« Reply #26 on: June 16, 2009, 03:17:33 pm »
The finish seems to be very durable, I did prime and wetsand and prime again before painting, then just used the Duplicolor clear effex with a 2000 grit wetsand between the 4 coats.
joey1207
« Reply #27 on: June 16, 2009, 03:26:08 pm »
I took the amp and transformer out of a set of Logitech X-140 pc speakers, then wired the speakers directly to the two sets of leads coming off the amp board, and wired the power directly to the transformer. It is not a stupid question, I was very concerned that it either would not work, or would not be enough to push the speakers, but by going with the 20 watt rms speakers, the X-140 amp seems to push them nicely, and the auxillary input and the headphone jack between the volume and tone knobs on the little black panel was a great bonus! The amp and transformer are on the left side of the pic, the amp / volume controls are one piece. (had to use a dremel to remove them from the molded plastic speaker case they were in).
« Last Edit: June 16, 2009, 03:27:39 pm by joey1207 »
joey1207
Re: New Jukebox build (Final Pics)
« Reply #28 on: July 22, 2009, 08:46:54 pm »
well, here it is
jimto
  • Last login:October 06, 2019, 03:20:14 pm
« Reply #29 on: July 23, 2009, 10:55:26 am »
Nice!
Let us know your nephew's reaction when he sees it.
