Author Topic: Running DOSCab/WinCab in Vista?  (Read 6553 times)
Johnny
  • Last login:Yesterday at 05:04:57 pm
  • I Want My Own Coctail Cabinet!!
« on: May 02, 2009, 11:16:56 pm »
Is this something of a problem or is it me doing something wrong.  :banghead:
I can start WinCab once in Vista. I start playing one song, then put it down on the taskbar. When trying to open it again, it goes back to the desktop. This continue whenever I try to to run WinCab.exe again.
This is the first time I try the program in Vista. Previously I have used XP.
Here is my debug log: (Part one)
0:00:00.00,1,DEBUGLOG_INIT,"DWJukebox for Windows Ver. 3.3.1 (Dec 22 2008 build) Started"
0:00:00.00,5,DEBUGLOG_INIT,"Debug log detail level: 5"
0:00:00.00,5,DEBUGLOG_INIT,"*****************************************************"
0:00:00.00,5,DEBUGLOG_INIT,"SYSTEM INFORMATION:"
0:00:00.00,5,DEBUGLOG_INIT,"OS version: 6.0"
0:00:00.00,5,DEBUGLOG_INIT,"Library version: Allegro 4.2.0, MSVC"
0:00:00.00,5,DEBUGLOG_INIT,"CPU Vendor: GenuineIntel"
0:00:00.00,5,DEBUGLOG_INIT,"MAX_PATH: 260"
0:00:00.00,1,MAIN,"Running `D:\Jukebox\wincab.exe'"
0:00:00.00,1,MAIN,"Using initialization file: jukebox.ini"
0:00:00.00,2,MAIN,"Initializing sound driver..."
0:00:00.00,2,MAIN,"Initializing TrueType font engine..."
0:00:00.00,2,MAIN,"Setting up cleanup functions..."
0:00:00.00,2,MAIN,"Loading display configuration..."
0:00:00.00,3,GET_CONFIG_SYMBOL,"[Settings] KeyboardLEDsOff is set to False."
0:00:00.00,1,MAIN,"Installing timers..."
0:00:00.00,3,GET_CONFIG_SYMBOL,"[Controls] KeyRepeatRate is set to 5."
0:00:00.00,3,GET_CONFIG_SYMBOL,"[Display] Width is set to Auto."
0:00:00.00,3,GET_CONFIG_SYMBOL,"[Display] Height is set to Auto."
0:00:00.00,2,MAIN,"Using existing desktop resolution of 1400x1050"
0:00:00.00,3,GET_CONFIG_SYMBOL,"[Display] ColorDepth is set to Auto."
0:00:00.00,2,MAIN,"No specific color depth requested"
0:00:00.00,2,MAIN,"Using existing desktop colordepth of 32bpp"
0:00:00.00,2,MAIN,"Initializing graphics mode..."
0:00:00.00,4,MAIN,"Trying graphics mode: 1400x1050, 32bpp"
0:00:00.27,1,MAIN,"Initialized graphics mode: 1400x1050, 32bpp"
0:00:00.27,3,GET_CONFIG_SYMBOL,"[Settings] FileSystemEncoding is set to ASCII."
0:00:00.27,2,PATH_ENCODING_SET,"Database character encoding: UTF-8"
0:00:00.27,2,PATH_ENCODING_SET,"File system character encoding: ASCII"
0:00:00.27,1,GUI_INIT,"Initializing GUI..."
0:00:00.27,3,GET_CONFIG_SYMBOL,"[Settings] PlayStimulatorDelay is set to Disabled."
0:00:00.27,3,GET_CONFIG_SYMBOL,"[Settings] RadioMode is set to Disabled."
0:00:00.27,3,GET_CONFIG_SYMBOL,"[Settings] LoopMode is set to Disabled."
0:00:00.27,3,GET_CONFIG_INT,"[Settings] CPUUsage is set to 10."
0:00:00.27,2,GUI_INIT,"CPU Usage is set at 10"
0:00:00.27,2,GUI_INIT,"Loading mouse pointers..."
0:00:00.27,3,GET_CONFIG_SYMBOL,"[Display] IconFocusBoxThickness is set to 0."
0:00:00.27,3,GET_CONFIG_SYMBOL,"[Display] TrackFocusBoxThickness is set to 0."
0:00:00.27,2,GUI_INIT,"Setting up blank mouse pointer..."
0:00:00.27,2,GUI_INIT,"Loading mouse setting..."
0:00:00.27,3,GET_CONFIG_SYMBOL,"[Controls] Mouse is set to Enabled."
0:00:00.28,5,MOUSE,"Set mouse to pointer ARROW (0)"
0:00:00.28,2,GUI_INIT,"Mouse enabled and visible, reporting 8 buttons"
0:00:00.28,3,GET_CONFIG_SYMBOL,"[Controls] AutoSelect is set to False."
0:00:00.28,3,GET_CONFIG_SYMBOL,"[Controls] AlphaToggle is set to False."
0:00:00.28,3,GET_CONFIG_SYMBOL,"[Settings] AllowSelectFullCD is set to False."
0:00:00.28,4,GET_CONFIG_SYMBOL,"[Settings] ShowSelectFullCDMessage is set to the default value (1)."
0:00:00.28,3,GET_CONFIG_SYMBOL,"[Settings] RequireCredits is set to False."
0:00:00.28,3,GET_CONFIG_INT,"[Settings] SongDelay is set to 0."
0:00:00.28,3,GET_CONFIG_INT,"[Settings] FirstAutoFlipTimer is set to 0."
0:00:00.28,3,GET_CONFIG_INT,"[Settings] AutoFlipTimer is set to 0."
0:00:00.28,3,GET_CONFIG_INT,"[Settings] SkipLastTimeLimit is set to 15."
0:00:00.28,3,GET_CONFIG_SYMBOL,"[Controls] ShowKeys is set to False."
0:00:00.28,3,GET_CONFIG_INT,"[Settings] Coin1Credit is set to 3."
0:00:00.28,3,GET_CONFIG_INT,"[Settings] Coin2Credit is set to 3."
0:00:00.28,3,GET_CONFIG_INT,"[Settings] Coin3Credit is set to 3."
0:00:00.28,3,GET_CONFIG_INT,"[Settings] Coin4Credit is set to 3."
0:00:00.28,3,GET_CONFIG_INT,"[Settings] MostPopularDisplayTime is set to 5."
0:00:00.28,3,GET_CONFIG_SYMBOL,"[Display] AnimationSpeed is set to 30."
0:00:00.28,3,MAIN,"Animation speed set at 30"
0:00:00.28,3,GET_CONFIG_SYMBOL,"[Settings] SystemShutdownEnabled is set to False."
0:00:00.28,3,GET_CONFIG_SYMBOL,"[Display] Rotation is set to 0."
0:00:00.28,3,GET_CONFIG_SYMBOL,"[Display] FixedDimension is set to Auto."
0:00:00.28,3,GET_CONFIG_SYMBOL,"[VolumeControl] SetSystemVolume is set to False."
0:00:00.28,3,GET_CONFIG_INT,"[VolumeControl] Volume is set to 100."
0:00:00.28,3,GET_CONFIG_INT,"[VolumeControl] VolumeIncrement is set to 10."
0:00:00.28,3,GET_CONFIG_SYMBOL,"[VolumeControl] SoundEffectsVolume is set to 50."
0:00:00.28,3,GET_CONFIG_SYMBOL,"[VolumeControl] SoundEffectsVolumeWhenPlaying is set to 0."
0:00:00.29,1,QUEUE_INIT,"Initializing song queue..."
0:00:00.29,3,GET_CONFIG_INT,"[Settings] MaxQueueSize is set to 250."
0:00:00.29,3,GET_CONFIG_SYMBOL,"[Settings] AllowDuplicatesInQueue is set to False."
0:00:00.29,2,QUEUE_INIT,"Song queue allocated for 250 songs."
0:00:00.29,3,GET_CONFIG_INT,"[Settings] MaxRandomSongLength is set to 6."
0:00:00.29,3,GET_CONFIG_SYMBOL,"[Settings] RandomSongPopularityPreference is set to 2."
0:00:00.29,1,LOAD_SKIN,"*****************************************************"
0:00:00.29,1,LOAD_SKIN,"Loading skin: default"
0:00:00.29,1,LOAD_SKIN,"Parameters: rot=0, fixedside=0, aspect=1.333333"
0:00:00.29,5,LOAD_SKIN,"Path encoding set"
0:00:00.29,1,LOAD_SKIN,"Alternate global resource paths:"
0:00:00.29,1,LOAD_SKIN,"   skins"
0:00:00.29,1,LOAD_SKIN,"   skins\labels"
0:00:00.29,1,LOAD_SKIN,"   skins\bgrounds"
0:00:00.29,1,LOAD_SKIN,"   skins\icons"
0:00:00.29,1,LOAD_SKIN,"   skins\fonts"
0:00:00.29,1,LOAD_SKIN,"   skins\sounds"
0:00:00.29,3,LOAD_SKIN->PATH_EXISTS,"File 'default.skn' found in path: skins\default.skn"
0:00:00.29,1,LOAD_SKIN,"Found skin file: skins\default.skn"
0:00:00.29,3,GET_CONFIG_SYMBOL,"[Display] fontsmoothing is set to True."
0:00:00.29,1,LOAD_SKIN,"Skin path: skins\"
0:00:00.29,1,LOAD_SKIN,"Skin alternate path: skins\default"
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Skin] FlipText is set to the default value (0)."
0:00:00.29,3,GET_CONFIG_SYMBOL,"[TitleStrips] Animation is set to SlideHorizontal."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[TitleStrips] CDHeader is set to the default value (-1)."
0:00:00.29,3,GET_CONFIG_SYMBOL,"[Selection] SelectionMethod is set to AlphaNumeric."
0:00:00.29,3,GET_CONFIG_SYMBOL,"[Selection] UseZero is set to False."
0:00:00.29,3,GET_CONFIG_SYMBOL,"[Selection] HighLetter is set to D."
0:00:00.29,3,GET_CONFIG_INT,"[Selection] HighNumber is set to 4."
0:00:00.29,3,LOAD_SKIN,"Loading selection letters and numbers to skip..."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Selection] SkipLetterA is set to the default value (0)."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Selection] SkipLetterB is set to the default value (0)."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Selection] SkipLetterC is set to the default value (0)."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Selection] SkipLetterD is set to the default value (0)."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Selection] SkipNumber1 is set to the default value (0)."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Selection] SkipNumber2 is set to the default value (0)."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Selection] SkipNumber3 is set to the default value (0)."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Selection] SkipNumber4 is set to the default value (0)."
0:00:00.29,3,LOAD_SKIN,"No letters or numbers will be skipped."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Selection] DiscAddress is set to the default value (0)."
0:00:00.29,3,GET_CONFIG_SYMBOL,"[TitleStrips] SongsPerStrip is set to Double."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Selection] ShowSelectionAddress is set to the default value (-1)."
0:00:00.29,3,GET_CONFIG_SYMBOL,"[Timers] PreSongDelay is set to 200."
0:00:00.29,3,GET_CONFIG_SYMBOL,"[Timers] PostSongDelay is set to 100."
0:00:00.29,3,GET_CONFIG_SYMBOL,"[Timers] InterSongDelay is set to 0."
0:00:00.29,4,GET_CONFIG_SYMBOL,"[Timers] IncrementalCreditDelay is set to the default value (20)."
0:00:00.29,3,LOAD_SKIN->PATH_EXISTS,"File 'bgmain.jpg' found in path: skins\bgrounds\bgmain.jpg"
0:00:00.35,2,LOAD_SKIN,"Background bitmap loaded: skins\bgrounds\bgmain.jpg (w=1024, h=1024)"
0:00:00.35,2,LOAD_SKIN,"Loading fonts..."
0:00:00.35,3,GET_CONFIG_SYMBOL,"[Fonts] TitleFontCase is set to UpperCase."
0:00:00.35,3,GET_CONFIG_SYMBOL,"[Fonts] TitleFontAddQuotes is set to True."
0:00:00.35,3,GET_CONFIG_INT,"[Fonts] TitleFontSize is set to 18."
0:00:00.35,3,FONT_INIT,"Font TitleFontSize: bluehigh.ttf"
0:00:00.35,3,FONT_LOAD->PATH_EXISTS,"File 'bluehigh.ttf' found in path: skins\fonts\bluehigh.ttf"
0:00:00.35,3,FONT_LOAD,"Loading font skins\fonts\bluehigh.ttf"
0:00:00.35,3,FONT_LOAD,"Setting font size for bluehigh.ttf to 36 points..."
0:00:00.35,3,FONT_INIT,"Font Address: 226f968"
0:00:00.35,3,GET_CONFIG_INT,"[Fonts] TitleFontCondensedSize is set to 18."
0:00:00.35,3,FONT_INIT,"Font TitleFontCondensedSize: bluecond.ttf"
0:00:00.35,3,FONT_LOAD->PATH_EXISTS,"File 'bluecond.ttf' found in path: skins\fonts\bluecond.ttf"
0:00:00.35,3,FONT_LOAD,"Loading font skins\fonts\bluecond.ttf"
0:00:00.35,3,FONT_LOAD,"Setting font size for bluecond.ttf to 33 points..."
0:00:00.35,3,FONT_INIT,"Font Address: 226fa28"
0:00:00.35,3,GET_CONFIG_INT,"[Fonts] TitleFontSmallSize is set to 18."
0:00:00.35,3,FONT_INIT,"Font TitleFontSmallSize: bluecond.ttf"
0:00:00.36,3,FONT_LOAD->PATH_EXISTS,"File 'bluecond.ttf' found in path: skins\fonts\bluecond.ttf"
0:00:00.36,3,FONT_LOAD,"Loading font skins\fonts\bluecond.ttf"
0:00:00.36,3,FONT_LOAD,"Setting font size for bluecond.ttf to 18 points..."
0:00:00.36,3,FONT_INIT,"Font Address: 226fae8"
0:00:00.36,4,GET_CONFIG_SYMBOL,"[Fonts] ArtistFontCase is set to the default value (0)."
0:00:00.36,4,GET_CONFIG_SYMBOL,"[Fonts] ArtistFontAddQuotes is set to the default value (0)."
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] ArtistFontSize is set to 18."
0:00:00.36,3,FONT_INIT,"Font ArtistFontSize not specified, setting to TitleFont"
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] ArtistFontCondensedSize is set to 18."
0:00:00.36,3,FONT_INIT,"Font ArtistFontCondensedSize not specified, setting to match previous size and font"
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] ArtistFontSmallSize is set to 18."
0:00:00.36,3,FONT_INIT,"Font ArtistFontSmallSize not specified, setting to match previous size and font"
0:00:00.36,4,GET_CONFIG_SYMBOL,"[Fonts] AlbumFontCase is set to the default value (0)."
0:00:00.36,4,GET_CONFIG_SYMBOL,"[Fonts] AlbumFontAddQuotes is set to the default value (0)."
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] AlbumFontSize is set to 18."
Johnny Andersen
 Oslo - Norway
Johnny
Re: Running DOSCab/WinCab in Vista?
« Reply #1 on: May 02, 2009, 11:18:19 pm »
Here is my debug log: (Part two)
0:00:00.36,3,FONT_INIT,"Font AlbumFontSize not specified, setting to TitleFont"
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] AlbumFontCondensedSize is set to 18."
0:00:00.36,3,FONT_INIT,"Font AlbumFontCondensedSize not specified, setting to match previous size and font"
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] AlbumFontSmallSize is set to 18."
0:00:00.36,3,FONT_INIT,"Font AlbumFontSmallSize not specified, setting to match previous size and font"
0:00:00.36,4,GET_CONFIG_SYMBOL,"[Fonts] TitleAdressFontCase is set to the default value (0)."
0:00:00.36,4,GET_CONFIG_SYMBOL,"[Fonts] TitleAdressFontAddQuotes is set to the default value (0)."
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] TitleAdressFontSize is set to 18."
0:00:00.36,3,FONT_INIT,"Font TitleAdressFontSize not specified, setting to TitleFont"
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] TitleAdressFontCondensedSize is set to 18."
0:00:00.36,3,FONT_INIT,"Font TitleAdressFontCondensedSize not specified, setting to match previous size and font"
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] TitleAdressFontSmallSize is set to 18."
0:00:00.36,3,FONT_INIT,"Font TitleAdressFontSmallSize not specified, setting to match previous size and font"
0:00:00.36,4,GET_CONFIG_SYMBOL,"[Fonts] CDAddressFontCase is set to the default value (0)."
0:00:00.36,4,GET_CONFIG_SYMBOL,"[Fonts] CDAddressFontAddQuotes is set to the default value (0)."
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] CDAddressFontSize is set to 18."
0:00:00.36,3,FONT_INIT,"Font CDAddressFontSize not specified, setting to TitleFont"
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] CDAddressFontCondensedSize is set to 18."
0:00:00.36,3,FONT_INIT,"Font CDAddressFontCondensedSize not specified, setting to match previous size and font"
0:00:00.36,3,GET_CONFIG_INT,"[Fonts] CDAddressFontSmallSize is set to 18."
0:00:00.36,3,FONT_INIT,"Font CDAddressFontSmallSize not specified, setting to match previous size and font"
0:00:00.36,3,FONT_INIT->PATH_EXISTS,"File 'jbdotmat.fnt' found"
0:00:00.36,3,FONT_INIT,"Loading fixed font jbdotmat.fnt"
0:00:00.37,2,LOAD_SKIN,"Background window: x=0 y=128 w=1024 h=768"
0:00:00.95,3,LOAD_SKIN,"Background image configured"
0:00:00.95,3,GET_CONFIG_INT,"[TitleStrips] height is set to 0."
0:00:00.95,3,GET_CONFIG_INT,"[TitleStrips] width is set to 0."
0:00:00.95,2,LOAD_SKIN,"Using solid titlestrips"
0:00:00.95,4,LOAD_SKIN,"TitleStrip Scaling: W=301 H=100 DestW=412 DestH=137 "
0:00:00.95,3,LOAD_SKIN->PATH_EXISTS,"File 'jb45lb01.jpg' found in path: skins\labels\jb45lb01.jpg"
0:00:00.96,4,LOAD_SKIN,"Titlestrip image loaded."
0:00:00.96,2,LOAD_SKIN,"Building jukebox user interface..."
0:00:00.96,2,LOAD_SKIN,"Looking for titlestrip grids"
0:00:00.96,3,LOAD_SKIN,"Titlestrip grid found: StripGrid"
0:00:00.96,3,GET_CONFIG_SYMBOL,"[StripGrid] order is set to Horizontal."
0:00:00.96,4,GET_CONFIG_SYMBOL,"[StripGrid] CoverArtSide is set to the default value (3)."
0:00:00.96,4,LOAD_SKIN,"Coordinate transform for strip 0: Source :cx: 165  cy: 319  Dest: cx: 226  cy: 261"
0:00:00.96,3,LOAD_SKIN,"Creating animation image buffers..."
0:00:00.96,4,LOAD_SKIN,"Coordinate transform for strip 1: Source :cx: 558  cy: 319  Dest: cx: 763  cy: 261"
0:00:00.96,4,LOAD_SKIN,"Coordinate transform for strip 2: Source :cx: 165  cy: 449  Dest: cx: 226  cy: 439"
0:00:00.96,4,LOAD_SKIN,"Coordinate transform for strip 3: Source :cx: 558  cy: 449  Dest: cx: 763  cy: 439"
0:00:00.96,4,LOAD_SKIN,"Coordinate transform for strip 4: Source :cx: 165  cy: 579  Dest: cx: 226  cy: 617"
0:00:00.96,4,LOAD_SKIN,"Coordinate transform for strip 5: Source :cx: 558  cy: 579  Dest: cx: 763  cy: 617"
0:00:00.96,4,LOAD_SKIN,"Coordinate transform for strip 6: Source :cx: 165  cy: 709  Dest: cx: 226  cy: 794"
0:00:00.96,4,LOAD_SKIN,"Coordinate transform for strip 7: Source :cx: 558  cy: 709  Dest: cx: 763  cy: 794"
0:00:00.96,2,LOAD_SKIN,"Tracker contains 16 strip segments"
0:00:00.96,2,LOAD_SKIN,"Tracker contains 16 label segments"
0:00:00.96,3,LOAD_SKIN,"Animation master object is #16"
0:00:00.96,5,LOAD_SKIN,"Freeing memory block 3589790 (trackerbuf)"
0:00:00.96,3,GET_CONFIG_SYMBOL,"[Display1] Enabled is set to True."
0:00:00.96,3,GET_CONFIG_SYMBOL,"[Display1] fontcase is set to UpperCase."
0:00:00.96,3,GET_CONFIG_SYMBOL,"[Display2] Enabled is set to True."
0:00:00.96,3,GET_CONFIG_SYMBOL,"[Display2] fontcase is set to UpperCase."
0:00:00.96,3,GET_CONFIG_SYMBOL,"[Display3] Enabled is set to True."
0:00:00.96,4,GET_CONFIG_SYMBOL,"[Display3] fontcase is set to the default value (0)."
0:00:00.97,3,GET_CONFIG_SYMBOL,"[Display4] Enabled is set to True."
0:00:00.97,4,GET_CONFIG_SYMBOL,"[Display4] fontcase is set to the default value (0)."
0:00:00.97,4,GET_CONFIG_SYMBOL,"[Display5] Enabled is set to the default value (0)."
0:00:00.97,2,LOAD_SKIN,"Looking for icons..."
0:00:00.97,4,GET_CONFIG_SYMBOL,"[Icon0] Action is set to the default value (145)."
0:00:00.97,3,GET_CONFIG_SYMBOL,"[Icon1] Action is set to MSG_CREDITS."
0:00:00.97,3,LOAD_SKIN,"Found Icon1..."
0:00:00.97,3,GET_CONFIG_SYMBOL,"[Icon1] Clickable is set to False."
0:00:00.97,4,LOAD_SKIN,"Icon1 before scaling: X: 464  Y: 193  W: 93  H: 94 "
0:00:00.97,4,LOAD_SKIN,"Icon1 after scaling: X: 634  Y: 89  W: 127  H: 129 "
0:00:00.97,4,GET_CONFIG_SYMBOL,"[Icon1] NormallyOff is set to the default value (1)."
0:00:00.97,4,GET_CONFIG_SYMBOL,"[Icon1] NormallyOn is set to the default value (0)."
0:00:00.97,3,LOAD_SKIN->PATH_EXISTS,"File 'instroff.bmp' found in path: skins\icons\instroff.bmp"
0:00:00.97,3,LOAD_SKIN->PATH_EXISTS,"File 'instron.bmp' found in path: skins\icons\instron.bmp"
0:00:00.98,2,LOAD_SKIN,"Icon 1 is not clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 1 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon2] Action is set to MSG_POPULAR."
0:00:00.98,3,LOAD_SKIN,"Found Icon2..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon2] Clickable is set to False."
0:00:00.98,4,LOAD_SKIN,"Icon2 before scaling: X: 624  Y: 281  W: 11  H: 11 "
0:00:00.98,4,LOAD_SKIN,"Icon2 after scaling: X: 853  Y: 209  W: 15  H: 15 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon2] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon2] NormallyOn is set to the default value (0)."
0:00:00.98,3,LOAD_SKIN->PATH_EXISTS,"File 'r-ledon.bmp' found in path: skins\icons\r-ledon.bmp"
0:00:00.98,3,LOAD_SKIN->PATH_EXISTS,"File 'r-ledoff.bmp' found in path: skins\icons\r-ledoff.bmp"
0:00:00.98,2,LOAD_SKIN,"Icon 2 is not clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 2 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon3] Action is set to MSG_POPULAR."
0:00:00.98,3,LOAD_SKIN,"Found Icon3..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon3] Clickable is set to False."
0:00:00.98,4,LOAD_SKIN,"Icon3 before scaling: X: 738  Y: 281  W: 11  H: 11 "
0:00:00.98,4,LOAD_SKIN,"Icon3 after scaling: X: 1009  Y: 209  W: 15  H: 15 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon3] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon3] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 3 is not clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 3 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon4] Action is set to BTN_A."
0:00:00.98,3,LOAD_SKIN,"Found Icon4..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon4] Clickable is set to True."
0:00:00.98,4,LOAD_SKIN,"Icon4 before scaling: X: 477  Y: 413  W: 33  H: 33 "
0:00:00.98,4,LOAD_SKIN,"Icon4 after scaling: X: 652  Y: 390  W: 45  H: 45 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon4] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon4] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 4 is clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 4 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon5] Action is set to BTN_1."
0:00:00.98,3,LOAD_SKIN,"Found Icon5..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon5] Clickable is set to True."
0:00:00.98,4,LOAD_SKIN,"Icon5 before scaling: X: 514  Y: 413  W: 33  H: 33 "
0:00:00.98,4,LOAD_SKIN,"Icon5 after scaling: X: 703  Y: 390  W: 45  H: 45 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon5] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon5] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 5 is clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 5 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon6] Action is set to BTN_B."
0:00:00.98,3,LOAD_SKIN,"Found Icon6..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon6] Clickable is set to True."
0:00:00.98,4,LOAD_SKIN,"Icon6 before scaling: X: 477  Y: 450  W: 33  H: 33 "
0:00:00.98,4,LOAD_SKIN,"Icon6 after scaling: X: 652  Y: 440  W: 45  H: 45 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon6] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon6] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 6 is clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 6 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon7] Action is set to BTN_2."
0:00:00.98,3,LOAD_SKIN,"Found Icon7..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon7] Clickable is set to True."
0:00:00.98,4,LOAD_SKIN,"Icon7 before scaling: X: 514  Y: 450  W: 33  H: 33 "
0:00:00.98,4,LOAD_SKIN,"Icon7 after scaling: X: 703  Y: 440  W: 45  H: 45 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon7] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon7] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 7 is clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 7 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon8] Action is set to BTN_C."
0:00:00.98,3,LOAD_SKIN,"Found Icon8..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon8] Clickable is set to True."
0:00:00.98,4,LOAD_SKIN,"Icon8 before scaling: X: 477  Y: 487  W: 33  H: 33 "
0:00:00.98,4,LOAD_SKIN,"Icon8 after scaling: X: 652  Y: 491  W: 45  H: 45 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon8] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon8] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 8 is clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 8 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon9] Action is set to BTN_3."
0:00:00.98,3,LOAD_SKIN,"Found Icon9..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon9] Clickable is set to True."
0:00:00.98,4,LOAD_SKIN,"Icon9 before scaling: X: 514  Y: 487  W: 33  H: 33 "
0:00:00.98,4,LOAD_SKIN,"Icon9 after scaling: X: 703  Y: 491  W: 45  H: 45 "
Johnny Andersen
 Oslo - Norway
Johnny
« Reply #2 on: May 02, 2009, 11:20:08 pm »
Here is my debug log: (Part three)
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon9] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon9] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 9 is clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 9 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon10] Action is set to BTN_D."
0:00:00.98,3,LOAD_SKIN,"Found Icon10..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon10] Clickable is set to True."
0:00:00.98,4,LOAD_SKIN,"Icon10 before scaling: X: 477  Y: 524  W: 33  H: 33 "
0:00:00.98,4,LOAD_SKIN,"Icon10 after scaling: X: 652  Y: 541  W: 45  H: 45 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon10] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon10] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 10 is clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 10 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon11] Action is set to BTN_4."
0:00:00.98,3,LOAD_SKIN,"Found Icon11..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon11] Clickable is set to True."
0:00:00.98,4,LOAD_SKIN,"Icon11 before scaling: X: 514  Y: 524  W: 33  H: 33 "
0:00:00.98,4,LOAD_SKIN,"Icon11 after scaling: X: 703  Y: 541  W: 45  H: 45 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon11] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon11] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 11 is clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 11 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon12] Action is set to BTN_SELECT."
0:00:00.98,3,LOAD_SKIN,"Found Icon12..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon12] Clickable is set to True."
0:00:00.98,4,LOAD_SKIN,"Icon12 before scaling: X: 477  Y: 561  W: 70  H: 33 "
0:00:00.98,4,LOAD_SKIN,"Icon12 after scaling: X: 652  Y: 592  W: 96  H: 45 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon12] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon12] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 12 is clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 12 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon13] Action is set to BTN_CLEAR."
0:00:00.98,3,LOAD_SKIN,"Found Icon13..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon13] Clickable is set to True."
0:00:00.98,4,LOAD_SKIN,"Icon13 before scaling: X: 477  Y: 598  W: 70  H: 33 "
0:00:00.98,4,LOAD_SKIN,"Icon13 after scaling: X: 652  Y: 643  W: 96  H: 45 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon13] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon13] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 13 is clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 13 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon14] Action is set to BTN_POPULAR."
0:00:00.98,3,LOAD_SKIN,"Found Icon14..."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon14] Clickable is set to True."
0:00:00.98,4,LOAD_SKIN,"Icon14 before scaling: X: 477  Y: 635  W: 70  H: 33 "
0:00:00.98,4,LOAD_SKIN,"Icon14 after scaling: X: 652  Y: 693  W: 96  H: 45 "
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon14] NormallyOff is set to the default value (1)."
0:00:00.98,4,GET_CONFIG_SYMBOL,"[Icon14] NormallyOn is set to the default value (0)."
0:00:00.98,2,LOAD_SKIN,"Icon 14 is clickable."
0:00:00.98,2,LOAD_SKIN,"Icon 14 is normally off."
0:00:00.98,3,GET_CONFIG_SYMBOL,"[Icon15] Action is set to BTN_PREVPG."
0:00:00.99,3,LOAD_SKIN,"Found Icon15..."
0:00:00.99,3,GET_CONFIG_SYMBOL,"[Icon15] Clickable is set to True."
0:00:00.99,4,LOAD_SKIN,"Icon15 before scaling: X: 477  Y: 672  W: 33  H: 70 "
0:00:00.99,4,LOAD_SKIN,"Icon15 after scaling: X: 652  Y: 744  W: 45  H: 96 "
0:00:00.99,4,GET_CONFIG_SYMBOL,"[Icon15] NormallyOff is set to the default value (1)."
0:00:00.99,4,GET_CONFIG_SYMBOL,"[Icon15] NormallyOn is set to the default value (0)."
0:00:00.99,2,LOAD_SKIN,"Icon 15 is clickable."
0:00:00.99,2,LOAD_SKIN,"Icon 15 is normally off."
0:00:00.99,3,GET_CONFIG_SYMBOL,"[Icon16] Action is set to BTN_NEXTPG."
0:00:00.99,3,LOAD_SKIN,"Found Icon16..."
0:00:00.99,3,GET_CONFIG_SYMBOL,"[Icon16] Clickable is set to True."
0:00:00.99,4,LOAD_SKIN,"Icon16 before scaling: X: 514  Y: 672  W: 33  H: 70 "
0:00:00.99,4,LOAD_SKIN,"Icon16 after scaling: X: 703  Y: 744  W: 45  H: 96 "
0:00:00.99,4,GET_CONFIG_SYMBOL,"[Icon16] NormallyOff is set to the default value (1)."
0:00:00.99,4,GET_CONFIG_SYMBOL,"[Icon16] NormallyOn is set to the default value (0)."
0:00:00.99,2,LOAD_SKIN,"Icon 16 is clickable."
0:00:00.99,2,LOAD_SKIN,"Icon 16 is normally off."
0:00:00.99,3,GET_CONFIG_SYMBOL,"[Icon17] Action is set to BTN_PAUSE."
0:00:00.99,3,LOAD_SKIN,"Found Icon17..."
0:00:00.99,3,GET_CONFIG_SYMBOL,"[Icon17] Clickable is set to True."
0:00:00.99,4,LOAD_SKIN,"Icon17 before scaling: X: 477  Y: 746  W: 70  H: 33 "
0:00:00.99,4,LOAD_SKIN,"Icon17 after scaling: X: 652  Y: 845  W: 96  H: 45 "
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon17] NormallyOff is set to the default value (1)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon17] NormallyOn is set to the default value (0)."
0:00:01.00,2,LOAD_SKIN,"Icon 17 is clickable."
0:00:01.00,2,LOAD_SKIN,"Icon 17 is normally off."
0:00:01.00,3,GET_CONFIG_SYMBOL,"[Icon18] Action is set to BTN_VOL_DOWN."
0:00:01.00,3,LOAD_SKIN,"Found Icon18..."
0:00:01.00,3,GET_CONFIG_SYMBOL,"[Icon18] Clickable is set to True."
0:00:01.00,4,LOAD_SKIN,"Icon18 before scaling: X: 477  Y: 783  W: 33  H: 33 "
0:00:01.00,4,LOAD_SKIN,"Icon18 after scaling: X: 652  Y: 896  W: 45  H: 45 "
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon18] NormallyOff is set to the default value (1)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon18] NormallyOn is set to the default value (0)."
0:00:01.00,3,LOAD_SKIN->PATH_EXISTS,"File 'btnvoldn.jpg' found in path: skins\icons\btnvoldn.jpg"
0:00:01.00,2,LOAD_SKIN,"Icon 18 is clickable."
0:00:01.00,2,LOAD_SKIN,"Icon 18 is normally off."
0:00:01.00,3,GET_CONFIG_SYMBOL,"[Icon19] Action is set to BTN_VOL_UP."
0:00:01.00,3,LOAD_SKIN,"Found Icon19..."
0:00:01.00,3,GET_CONFIG_SYMBOL,"[Icon19] Clickable is set to True."
0:00:01.00,4,LOAD_SKIN,"Icon19 before scaling: X: 514  Y: 783  W: 33  H: 33 "
0:00:01.00,4,LOAD_SKIN,"Icon19 after scaling: X: 703  Y: 896  W: 45  H: 45 "
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon19] NormallyOff is set to the default value (1)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon19] NormallyOn is set to the default value (0)."
0:00:01.00,3,LOAD_SKIN->PATH_EXISTS,"File 'btnvolup.jpg' found in path: skins\icons\btnvolup.jpg"
0:00:01.00,2,LOAD_SKIN,"Icon 19 is clickable."
0:00:01.00,2,LOAD_SKIN,"Icon 19 is normally off."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon20] Action is set to the default value (145)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon21] Action is set to the default value (145)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon22] Action is set to the default value (145)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon23] Action is set to the default value (145)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon24] Action is set to the default value (145)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon25] Action is set to the default value (145)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon26] Action is set to the default value (145)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon27] Action is set to the default value (145)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon28] Action is set to the default value (145)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[Icon29] Action is set to the default value (145)."
0:00:01.00,2,LOAD_SKIN,"Looking for system LEDs..."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[LED0] LED is set to the default value (0)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[LED1] LED is set to the default value (0)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[LED2] LED is set to the default value (0)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[LED3] LED is set to the default value (0)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[LED4] LED is set to the default value (0)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[LED5] LED is set to the default value (0)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[LED6] LED is set to the default value (0)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[LED7] LED is set to the default value (0)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[LED8] LED is set to the default value (0)."
0:00:01.00,4,GET_CONFIG_SYMBOL,"[LED9] LED is set to the default value (0)."
0:00:01.00,5,GUI_OBJ_DUMP,"0 - x=226 y=261 w=412 h=45 d1=-1 d2=1 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"1 - x=226 y=353 w=412 h=45 d1=-1 d2=2 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"2 - x=763 y=261 w=412 h=45 d1=-1 d2=1 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"3 - x=763 y=353 w=412 h=45 d1=-1 d2=2 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"4 - x=226 y=439 w=412 h=45 d1=-1 d2=1 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"5 - x=226 y=531 w=412 h=45 d1=-1 d2=2 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"6 - x=763 y=439 w=412 h=45 d1=-1 d2=1 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"7 - x=763 y=531 w=412 h=45 d1=-1 d2=2 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"8 - x=226 y=617 w=412 h=45 d1=-1 d2=1 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"9 - x=226 y=709 w=412 h=45 d1=-1 d2=2 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"10 - x=763 y=617 w=412 h=45 d1=-1 d2=1 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"11 - x=763 y=709 w=412 h=45 d1=-1 d2=2 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"12 - x=226 y=794 w=412 h=45 d1=-1 d2=1 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"13 - x=226 y=886 w=412 h=45 d1=-1 d2=2 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"14 - x=763 y=794 w=412 h=45 d1=-1 d2=1 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"15 - x=763 y=886 w=412 h=45 d1=-1 d2=2 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"16 - x=226 y=261 w=412 h=137 d1=0 d2=0 type=Animation "
0:00:01.00,5,GUI_OBJ_DUMP,"17 - x=226 y=306 w=412 h=47 d1=0 d2=0 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"18 - x=763 y=261 w=412 h=137 d1=0 d2=0 type=Animation "
0:00:01.00,5,GUI_OBJ_DUMP,"19 - x=763 y=306 w=412 h=47 d1=0 d2=0 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"20 - x=226 y=439 w=412 h=137 d1=0 d2=0 type=Animation "
0:00:01.00,5,GUI_OBJ_DUMP,"21 - x=226 y=484 w=412 h=47 d1=0 d2=0 type=Titlestrip "
0:00:01.00,5,GUI_OBJ_DUMP,"22 - x=763 y=439 w=412 h=137 d1=0 d2=0 type=Animation "
0:00:01.00,5,GUI_OBJ_DUMP,"23 - x=763 y=484 w=412 h=47 d1=0 d2=0 type=Titlestrip "
0:00:01.01,5,GUI_OBJ_DUMP,"24 - x=226 y=617 w=412 h=137 d1=0 d2=0 type=Animation "
0:00:01.01,5,GUI_OBJ_DUMP,"25 - x=226 y=662 w=412 h=47 d1=0 d2=0 type=Titlestrip "
0:00:01.01,5,GUI_OBJ_DUMP,"26 - x=763 y=617 w=412 h=137 d1=0 d2=0 type=Animation "
0:00:01.01,5,GUI_OBJ_DUMP,"27 - x=763 y=662 w=412 h=47 d1=0 d2=0 type=Titlestrip "
0:00:01.01,5,GUI_OBJ_DUMP,"28 - x=226 y=794 w=412 h=137 d1=0 d2=0 type=Animation "
0:00:01.01,5,GUI_OBJ_DUMP,"29 - x=226 y=839 w=412 h=47 d1=0 d2=0 type=Titlestrip "
0:00:01.01,5,GUI_OBJ_DUMP,"30 - x=763 y=794 w=412 h=137 d1=0 d2=0 type=Animation "
0:00:01.01,5,GUI_OBJ_DUMP,"31 - x=763 y=839 w=412 h=47 d1=0 d2=0 type=Titlestrip "
0:00:01.01,5,GUI_OBJ_DUMP,"32 - x=208 y=98 w=399 h=107 d1=1 d2=4 type=Display "
Johnny Andersen
 Oslo - Norway
Johnny
« Reply #3 on: May 02, 2009, 11:22:01 pm »
Here is my debug log: (Part Four)
0:00:01.01,5,GUI_OBJ_DUMP,"33 - x=789 y=98 w=399 h=107 d1=2 d2=4 type=Display "
0:00:01.01,5,GUI_OBJ_DUMP,"34 - x=663 y=299 w=77 h=33 d1=3 d2=4 type=Display "
0:00:01.01,5,GUI_OBJ_DUMP,"35 - x=663 y=234 w=77 h=33 d1=4 d2=4 type=Display "
0:00:01.01,5,GUI_OBJ_DUMP,"36 - x=634 y=89 w=127 h=129 d1=142 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"37 - x=853 y=209 w=15 h=15 d1=141 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"38 - x=1009 y=209 w=15 h=15 d1=141 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"39 - x=652 y=390 w=45 h=45 d1=1 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"40 - x=703 y=390 w=45 h=45 d1=28 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"41 - x=652 y=440 w=45 h=45 d1=2 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"42 - x=703 y=440 w=45 h=45 d1=29 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"43 - x=652 y=491 w=45 h=45 d1=3 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"44 - x=703 y=491 w=45 h=45 d1=30 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"45 - x=652 y=541 w=45 h=45 d1=4 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"46 - x=703 y=541 w=45 h=45 d1=31 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"47 - x=652 y=592 w=96 h=45 d1=53 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"48 - x=652 y=643 w=96 h=45 d1=62 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"49 - x=652 y=693 w=96 h=45 d1=55 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"50 - x=652 y=744 w=45 h=96 d1=57 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"51 - x=703 y=744 w=45 h=96 d1=58 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"52 - x=652 y=845 w=96 h=45 d1=69 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"53 - x=652 y=896 w=45 h=45 d1=80 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"54 - x=703 y=896 w=45 h=45 d1=79 d2=0 type=Icon "
0:00:01.01,5,GUI_OBJ_DUMP,"55 - x=0 y=0 w=0 h=0 d1=0 d2=0 type=Idler "
0:00:01.01,1,SFX_LOAD,"Loading sound effects..."
0:00:01.01,3,SFX_LOAD->PATH_EXISTS,"File 'coin.wav' found in path: skins\sounds\coin.wav"
0:00:01.01,3,SFX_LOAD,"sfx for BTN_COIN1 is skins\sounds\coin.wav... loaded"
0:00:01.01,3,SFX_LOAD,"sfx for BTN_COIN2 is skins\sounds\coin.wav... cached"
0:00:01.01,3,SFX_LOAD,"sfx for BTN_COIN3 is skins\sounds\coin.wav... cached"
0:00:01.01,3,SFX_LOAD,"sfx for BTN_COIN4 is skins\sounds\coin.wav... cached"
0:00:01.01,3,SFX_LOAD->PATH_EXISTS,"File 'invalid.wav' found in path: skins\sounds\invalid.wav"
0:00:01.01,3,SFX_LOAD,"sfx for MSG_INVALID is skins\sounds\invalid.wav... loaded"
0:00:01.01,3,SFX_LOAD->PATH_EXISTS,"File 'recpop.wav' found in path: skins\sounds\recpop.wav"
0:00:01.01,3,SFX_LOAD,"sfx for MSG_PRESONG is skins\sounds\recpop.wav... loaded"
0:00:01.02,2,LOAD_SKIN,"No art objects or displays, art cache not initialized."
0:00:01.02,5,MOUSE,"Set mouse to pointer HOURGLASS (8)"
0:00:01.03,2,APPLY_SKIN,"Refreshing tracker"
0:00:01.03,3,APPLY_SKIN,"Tracker initialized"
0:00:01.03,3,APPLY_SKIN,"Tracker drawn"
0:00:01.04,4,DISPLAY_PROC,"Destroying temp bitmap for display 1"
0:00:01.04,4,DISPLAY_PROC,"Destroying back buffer for display 1"
0:00:01.04,4,DESTROY_BACKBUFFER,"Destroying backbuffer #0 for object 6527e98"
0:00:01.04,4,DISPLAY_PROC,"Destroying temp bitmap for display 2"
0:00:01.04,4,DISPLAY_PROC,"Destroying back buffer for display 2"
0:00:01.04,4,DESTROY_BACKBUFFER,"Destroying backbuffer #1 for object 6527ed0"
0:00:01.04,4,DISPLAY_PROC,"Destroying temp bitmap for display 3"
0:00:01.04,4,DISPLAY_PROC,"Destroying temp bitmap for display 4"
0:00:01.04,3,APPLY_SKIN,"Tracker destroyed"
0:00:01.04,5,STATUS,"Loading Database/"
0:00:01.06,2,INDEXER,"Entering indexer..."
0:00:01.06,3,GET_CONFIG_INT,"[Index] MaxFolderDepth is set to 3."
0:00:01.06,3,GET_CONFIG_SYMBOL,"[Index] UseID3 is set to false."
0:00:01.06,4,GET_CONFIG_SYMBOL,"[Index] SmartCrop is set to the default value (1)."
0:00:01.06,3,GET_CONFIG_SYMBOL,"[Index] FilenameCrop is set to Smart."
0:00:01.06,3,GET_CONFIG_SYMBOL,"[Index] UpdateIndex is set to True."
0:00:01.06,3,INDEXER,"Initializing cover art search masks..."
0:00:01.06,4,INDEXER,"*** MASK DUMP ***"
0:00:01.06,4,INDEXER,"   Mask 1: folder.jpg"
0:00:01.06,4,INDEXER,"   Mask 2: AlbumArt_{????????-????-????-????-????????????}_Large.jpg"
0:00:01.06,4,INDEXER,"   Mask 3: *.jpg"
0:00:01.06,4,INDEXER,"*** MASK DUMP COMPLETE***"
0:00:01.06,3,INDEXER,"Initializing path index..."
0:00:01.06,5,STATUS,"Initializing indexes/"
0:00:01.06,3,INDEXER,"Preparing indexes..."
0:00:01.06,3,INDEXER,"Building index for 2 songs..."
0:00:01.06,3,INDEXER,"Backfilling pointers to index..."
0:00:01.06,3,INDEXER,"Temporary indexes complete."
0:00:01.06,5,STATUS,"Updating Database/"
0:00:01.08,2,INDEXER-LOOP,"Entering folder ...."
0:00:01.08,5,STATUS,"Updating database/."
0:00:01.08,3,INDEXER-LOOP,"No art found for this folder"
0:00:01.08,2,INDEXER-LOOP,"Entering folder data..."
0:00:01.08,5,STATUS,"Updating database/data"
0:00:01.08,2,INDEXER-LOOP,"Entering folder docs..."
0:00:01.08,5,STATUS,"Updating database/docs"
0:00:01.09,2,INDEXER-LOOP,"Entering folder skins..."
0:00:01.09,5,STATUS,"Updating database/skins"
0:00:01.09,3,INDEXER-LOOP,"No art found for this folder"
0:00:01.09,2,INDEXER-LOOP,"Entering folder bgrounds..."
0:00:01.09,5,STATUS,"Updating database/bgrounds"
0:00:01.09,3,INDEXER-LOOP,"Art for this folder (mask 3): D:\Jukebox\skins\bgrounds\bgaj8.jpg"
0:00:01.09,2,INDEXER-LOOP,"Entering folder fonts..."
0:00:01.09,5,STATUS,"Updating database/fonts"
0:00:01.09,2,INDEXER-LOOP,"Entering folder icons..."
0:00:01.09,5,STATUS,"Updating database/icons"
0:00:01.11,3,INDEXER-LOOP,"Art for this folder (mask 3): D:\Jukebox\skins\icons\bj_cmgup.jpg"
0:00:01.11,2,INDEXER-LOOP,"Entering folder labels..."
0:00:01.11,5,STATUS,"Updating database/labels"
0:00:01.11,3,INDEXER-LOOP,"Art for this folder (mask 3): D:\Jukebox\skins\labels\bj45lb05.jpg"
0:00:01.11,2,INDEXER-LOOP,"Entering folder sounds..."
0:00:01.11,5,STATUS,"Updating database/sounds"
0:00:01.12,3,INDEXER-LOOP,"No art found for this folder"
0:00:01.12,2,INDEXER-LOOP,"Entering folder tutorial..."
0:00:01.12,5,STATUS,"Updating database/tutorial"
0:00:01.12,3,INDEXER-LOOP,"Art for this folder (mask 3): D:\Jukebox\skins\tutorial\tutorial.jpg"
0:00:01.12,2,INDEXER-LOOP,"Entering folder ...."
0:00:01.12,5,STATUS,"Updating database/."
0:00:01.12,2,INDEXER-LOOP,"Entering folder Bjarte Hjelmeland..."
0:00:01.12,5,STATUS,"Updating database/Bjarte Hjelmeland"
0:00:01.14,3,INDEXER-LOOP,"No art found for this folder"
0:00:01.14,3,INDEXER-LOOP,"Working on 01- Engler I Sneen.mp3 (5691731 bytes)..."
0:00:01.14,4,INDEXER-LOOP,"Found song in database record #1 (ID 69173101-E)... Up to date."
0:00:01.14,2,INDEXER-LOOP,"Entering folder Sarah McLachlan..."
0:00:01.14,5,STATUS,"Updating database/Sarah McLachlan"
0:00:01.14,3,INDEXER-LOOP,"Working on 01- Answer.mp3 (5713639 bytes)..."
0:00:01.14,4,INDEXER-LOOP,"Found song in database record #0 (ID 71363901-A)... Up to date."
0:00:01.14,5,STATUS,"Update complete!/"
0:00:01.14,1,INDEXER,"*** INDEX OPERATION COMPLETE ***"
0:00:01.14,2,INDEXER,"0 songs added"
0:00:01.14,2,INDEXER,"0 songs updated"
0:00:01.14,2,INDEXER,"2 songs unchanged"
0:00:01.14,2,INDEXER,"0 songs not found"
0:00:01.14,2,INDEXER,"Elapsed index time: 0 min, 0.06 sec"
0:00:01.14,2,INDEXER,"**********************************"
0:00:01.14,3,INDEXER,"Initializing popularity index..."
0:00:01.14,3,INDEXER,"Popularity index initialized"
0:00:01.19,5,INDEXER,"Freeing memory block 226e638 (idsortindex)"
0:00:01.19,5,INDEXER,"Freeing memory block 356d1f0 (idindex)"
0:00:01.19,4,DISPLAY_PROC,"Destroying temp bitmap for display 0"
0:00:01.19,2,APPLY_SKIN,"Refreshing tracker"
0:00:01.19,3,APPLY_SKIN,"Tracker initialized"
0:00:01.20,3,APPLY_SKIN,"Tracker drawn"
0:00:01.20,4,DISPLAY_PROC,"Destroying temp bitmap for display 1"
0:00:01.20,4,DISPLAY_PROC,"Destroying back buffer for display 1"
0:00:01.20,4,DESTROY_BACKBUFFER,"Destroying backbuffer #0 for object 6527e98"
0:00:01.20,4,DISPLAY_PROC,"Destroying temp bitmap for display 2"
0:00:01.20,4,DISPLAY_PROC,"Destroying back buffer for display 2"
0:00:01.20,4,DESTROY_BACKBUFFER,"Destroying backbuffer #1 for object 6527ed0"
0:00:01.20,4,DISPLAY_PROC,"Destroying temp bitmap for display 3"
0:00:01.20,4,DISPLAY_PROC,"Destroying temp bitmap for display 4"
0:00:01.20,3,APPLY_SKIN,"Tracker destroyed"
0:00:01.20,5,MOUSE,"Set mouse to pointer ARROW (0)"
0:00:01.20,1,MAIN,"Creating titlestrips..."
0:00:01.20,2,TITLESTRIPS_INIT,"Initializing titlestrips..."
0:00:01.20,3,GET_CONFIG_SYMBOL,"[Settings] SongSort is set to Artist."
0:00:01.20,4,GET_CONFIG_SYMBOL,"[Index] OrphanControl is set to the default value (1)."
0:00:01.20,3,TITLESTRIPS_INIT,"Initializing titlestrip sort..."
0:00:01.20,3,TITLESTRIPS_INIT,"Sorting titlestrips..."
0:00:01.20,5,TITLESTRIPS_INIT,"Index dump"
0:00:01.20,5,TITLESTRIPS_INIT,"INDEX: 0: 1"
0:00:01.20,5,TITLESTRIPS_INIT,"INDEX: 1: 0"
0:00:01.20,5,TITLESTRIPS_INIT,"Index dump complete"
0:00:01.20,4,TITLESTRIPS_INIT,"Building strip #0 for Bjarte Hjelmeland"
0:00:01.20,4,TITLESTRIPS_INIT,"Building strip #1 for Sarah McLachlan"
0:00:01.20,1,TITLESTRIPS_INIT,"Done building strips."
0:00:01.20,5,TITLESTRIPS_INIT,"Sequence number for strip 0 is 1; artist is Bjarte Hjelmeland"
0:00:01.20,5,TITLESTRIPS_INIT,"Sequence number for strip 1 is 1; artist is Sarah McLachlan"
0:00:01.20,5,TITLESTRIPS_INIT,"Freeing memory block 226e648 (artistindex)"
0:00:01.20,5,TITLESTRIPS_INIT,"Freeing memory block 6528c10 (artistlist)"
0:00:01.20,1,TITLESTRIPS_INIT,"Attaching titlestrips to song database records..."
0:00:01.20,1,TITLESTRIPS_INIT,"Built 2 titlestrips."
0:00:01.20,1,TITLESTRIPS_INIT,"About to set titlestrips for song page 0..."
0:00:01.20,3,GET_CONFIG_SYMBOL,"[ScreenSaver] ScreenSaver is set to Lines."
0:00:01.20,3,GET_CONFIG_SYMBOL,"[ScreenSaver] ScreenSaverTimeout is set to Disabled."
0:00:01.20,3,GET_CONFIG_SYMBOL,"[ScreenSaver] ScreenSaverCancelTimeout is set to Disabled."
0:00:01.20,3,GET_CONFIG_SYMBOL,"[ScreenSaver] ShowSongInfo is set to True."
0:00:01.20,3,GET_CONFIG_SYMBOL,"[ScreenSaver] CornerMirror is set to True."
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] LineCount is set to 80."
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] ColorVariance is set to 100."
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] StepSize is set to 5."
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] MinRed is set to 50."
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] MinGreen is set to 50."
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] MinBlue is set to 50."
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] MaxRed is set to 250."
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] MaxGreen is set to 250."
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] MaxBlue is set to 250."
0:00:01.20,4,SSAVER_INIT,"ssaverw=560, ssaverh=157, ssaverwmax=1120, ssaverhmax=840"
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] SongInfoLines is set to 5."
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] SongInfoWidth is set to 560."
0:00:01.20,3,GET_CONFIG_INT,"[ScreenSaver] SongInfoHeight is set to 157."
0:00:01.20,1,MQ_INIT,"Initializing message queue"
0:00:01.20,1,MQ_INIT,"Free Play enabled, credits not required"
0:00:01.20,1,MAIN,"Starting GUI..."
0:00:01.29,3,MQ_PROCESS,"Processing message: MSG_START"
0:00:01.29,1,MQ_PROCESS,"*** MSG_START received at 1.29 seconds; message queue is now being processed. ***"
0:00:01.29,5,QUEUE_RANDOM,"maxlastsongpointer set to 20 "
0:00:01.29,3,MQ_PROCESS,"Processing message: MSG_IDLE"
0:00:01.29,3,MQ_PROCESS,"Processing message: MSG_CREDITS"
0:00:01.29,3,MQ_PROCESS,"Processing message: MSG_FREEPLAY"
0:00:02.22,3,MQ_PROCESS,"Processing message: -MSG_POPULAR"
0:00:05.45,2,APPLY_SKIN,"Tracker already active"
0:00:27.51,1,IDLER_PROC,"Jukebox shutdown requested via application close"
0:00:27.51,4,DISPLAY_PROC,"Destroying temp bitmap for display 1"
0:00:27.51,4,DISPLAY_PROC,"Destroying back buffer for display 1"
0:00:27.51,4,DESTROY_BACKBUFFER,"Destroying backbuffer #0 for object 6527e98"
0:00:27.51,4,DISPLAY_PROC,"Destroying temp bitmap for display 2"
0:00:27.51,4,DISPLAY_PROC,"Destroying back buffer for display 2"
0:00:27.51,4,DESTROY_BACKBUFFER,"Destroying backbuffer #1 for object 6527ed0"
0:00:27.51,4,DISPLAY_PROC,"Destroying temp bitmap for display 3"
0:00:27.51,4,DISPLAY_PROC,"Destroying temp bitmap for display 4"
0:00:27.51,1,MAIN,"Exited GUI"
0:00:27.51,1,UNLOAD_SKIN,"Cleaning up skin..."
0:00:27.51,2,UNLOAD_SKIN,"Destroying bitmap buffers..."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 16"
0:00:27.51,5,UNLOAD_SKIN,"Object 16 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 16 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 18"
0:00:27.51,5,UNLOAD_SKIN,"Object 18 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 18 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 20"
0:00:27.51,5,UNLOAD_SKIN,"Object 20 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 20 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 22"
0:00:27.51,5,UNLOAD_SKIN,"Object 22 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 22 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 24"
0:00:27.51,5,UNLOAD_SKIN,"Object 24 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 24 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 26"
0:00:27.51,5,UNLOAD_SKIN,"Object 26 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 26 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 28"
0:00:27.51,5,UNLOAD_SKIN,"Object 28 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 28 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 30"
0:00:27.51,5,UNLOAD_SKIN,"Object 30 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 30 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 36"
0:00:27.51,5,UNLOAD_SKIN,"Object 36 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 36 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 37"
0:00:27.51,5,UNLOAD_SKIN,"Object 37 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 37 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 38"
0:00:27.51,5,UNLOAD_SKIN,"Object 38 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 38 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 39"
0:00:27.51,5,UNLOAD_SKIN,"Object 39 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 39 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 40"
0:00:27.51,5,UNLOAD_SKIN,"Object 40 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 40 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 41"
0:00:27.51,5,UNLOAD_SKIN,"Object 41 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 41 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 42"
0:00:27.51,5,UNLOAD_SKIN,"Object 42 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 42 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 43"
0:00:27.51,5,UNLOAD_SKIN,"Object 43 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 43 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 44"
0:00:27.51,5,UNLOAD_SKIN,"Object 44 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 44 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 45"
0:00:27.51,5,UNLOAD_SKIN,"Object 45 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 45 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 46"
0:00:27.51,5,UNLOAD_SKIN,"Object 46 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 46 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 47"
0:00:27.51,5,UNLOAD_SKIN,"Object 47 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 47 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 48"
0:00:27.51,5,UNLOAD_SKIN,"Object 48 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 48 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 49"
0:00:27.51,5,UNLOAD_SKIN,"Object 49 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 49 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 50"
0:00:27.51,5,UNLOAD_SKIN,"Object 50 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 50 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 51"
0:00:27.51,5,UNLOAD_SKIN,"Object 51 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 51 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 52"
0:00:27.51,5,UNLOAD_SKIN,"Object 52 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 52 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 53"
0:00:27.51,5,UNLOAD_SKIN,"Object 53 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 53 buffer 2 destroyed."
0:00:27.51,4,UNLOAD_SKIN,"Destroying bitmap buffers for object 54"
0:00:27.51,5,UNLOAD_SKIN,"Object 54 buffer 1 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Object 54 buffer 2 destroyed."
0:00:27.51,5,UNLOAD_SKIN,"Freeing memory block 6527798 (tracker)"
0:00:27.51,2,UNLOAD_SKIN,"Tracker freed"
0:00:27.51,2,UNLOAD_SKIN,"Destroying sound effects..."
0:00:27.51,3,UNLOAD_SKIN,"Destroying sound effect for BTN_COIN1"
0:00:27.51,4,UNLOAD_SKIN,"Destroying cached sound effect pointer for BTN_COIN2"
0:00:27.51,4,UNLOAD_SKIN,"Destroying cached sound effect pointer for BTN_COIN3"
0:00:27.51,4,UNLOAD_SKIN,"Destroying cached sound effect pointer for BTN_COIN4"
0:00:27.51,3,UNLOAD_SKIN,"Sound effect for BTN_COIN1 destroyed."
0:00:27.51,3,UNLOAD_SKIN,"Destroying sound effect for MSG_INVALID"
0:00:27.51,3,UNLOAD_SKIN,"Sound effect for MSG_INVALID destroyed."
0:00:27.51,3,UNLOAD_SKIN,"Destroying sound effect for MSG_PRESONG"
0:00:27.51,3,UNLOAD_SKIN,"Sound effect for MSG_PRESONG destroyed."
0:00:27.51,2,UNLOAD_SKIN,"Destroying fonts..."
0:00:27.51,1,FONT_EXIT,"Destroying font cache..."
0:00:27.51,5,FONT_EXIT,"Destroyed font 0, bluehigh.ttf, 36 pt."
0:00:27.51,5,FONT_EXIT,"Destroyed font 1, bluecond.ttf, 33 pt."
0:00:27.51,5,FONT_EXIT,"Destroyed font 2, bluecond.ttf, 18 pt."
0:00:27.51,1,ARTCACHE_EXIT,"No art cache to remove"
0:00:27.51,5,MAIN,"Freeing memory block 223caf8 (skinpage)"
0:00:27.51,1,QUEUE_EXIT,"Cleaning up songbuf..."
0:00:27.51,5,QUEUE_EXIT,"Freeing memory block 22773d0 (songqueue)"
0:00:27.51,1,GUI_EXIT,"Cleaning up GUI..."
0:00:27.51,1,GUI_EXIT,"Idle loop average: 87366 loops/sec"
0:00:27.51,2,GUI_EXIT,"Backbuffer list is empty."
0:00:27.51,1,SSAVER_EXIT,"Cleaning up ssaver..."
0:00:27.51,4,DISPLAY_PROC,"Destroying temp bitmap for display 6"
0:00:27.51,1,SONGBUF_EXIT,"Cleaning up songbuf..."
0:00:27.51,1,TITLESTRIPS_EXIT,"Cleaning up titlestrips..."
0:00:27.51,5,TITLESTRIPS_EXIT,"Freeing memory block 226e638 (titlestrip[0])"
0:00:27.51,5,TITLESTRIPS_EXIT,"Freeing memory block 226e6b8 (titlestrip[1])"
0:00:27.51,5,TITLESTRIPS_EXIT,"Freeing memory block 226e6a8 (titlestrip)"
0:00:27.51,5,TITLESTRIPS_EXIT,"Freeing memory block 226e648 (titlestripindex)"
0:00:27.51,5,TITLESTRIPS_EXIT,"Freeing memory block 226e658 (stripsequence)"
0:00:27.51,4,TITLESTRIPS_EXIT,"Done cleaning up titlestrips"
0:00:27.51,1,SONGLIST_EXIT,"Cleaning up songlist..."
0:00:27.51,5,SONGLIST_EXIT,"Freeing memory block 226e618 (popularsort)"
0:00:27.51,1,SHUTDOWN,"Expected jukebox shutdown"
0:00:27.51,5,DEBUGLOG_EXIT,"DWJukebox 3.3.1 Exited"
Sorry to do it this way, but file was to big in one go.....
Johnny Andersen
 Oslo - Norway
Chris
  • Moderator
    • Chris's MAME Cabinet
« Reply #4 on: May 03, 2009, 12:30:32 am »
The key line here is:
So this is not a crash.  Vista is asking the application to close; this is equivalent to you killing it through Task Manager or clicking the Close option on the taskbar menu.  Why it is doing this I am not sure.  The jukebox can run in Vista, although some people report mouse issues with it in Vista.
Are you just clicking on the taskbar button to make it full-screen and it immediately exits?
--Chris
Johnny
« Reply #5 on: May 03, 2009, 11:12:55 am »
Yes I do, but the problem is continuing. After I have closed it with the Task manager and trying the wincab.exe in the orginal folder would not start. It start up, but end at the taskbar.
Johnny Andersen
 Oslo - Norway
