Author Topic: U3000 Pincushion  (Read 1723 times)
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
U3000 Pincushion
« on: March 20, 2009, 08:36:48 pm »
I'm trying to adjust pincushion out of a u3000 monitor.  I have adjusted the width coil and pincushion amp and trap and nothing seems to fix it.  The horizontal size on the remote adjustment board doesn't do anything either.  What other adjustments can I make to try and correct this problem?
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
grantspain
Re: U3000 Pincushion
« Reply #1 on: March 21, 2009, 05:23:53 am »
i would be looking at the east/west correction diodes and the width control circuit-this looks more like component failure than adjustment issue
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: March 21, 2009, 02:41:23 pm »
for starters,  check d705,c720...... then r733, q704,705
qrz
tjkeller
  • Last login:January 13, 2010, 12:29:16 pm
« Reply #3 on: November 03, 2009, 07:03:58 am »
Hello, I have the EXACT same problem brock stated above with my U3100 14" WG Monitor.
Pincushion effect, No H. Size or trap Adjustment. Current display width exceeds display area.
I have replaced:
Q1.......D1......C1
Q2.......D2......C6
Q3.......D3......R15....and IC201
Also standard cap kit replacement = C411, C414, C612, C621, & C623
I have discovered D3 (MUR460) keeps blowing. Replacement of this diode temporarily
give H.Size back and slight pin cushion adj. The display colors become much lighter
but H.Size works. Not enough pin cush adj to make much of a difference. Anyway, this
only lasts for several seconds (less than minute) until the diode gives out and it all
reverts back to original problem state.
Any help/advice would be greatly appreciated.
Thanks,
Travis
