Author Topic: G07, where to put the white wires from the metal CRT casing ?  (Read 2619 times)
Level42
« on: February 09, 2009, 03:55:44 pm »
Quick question: I'm trying to connect a replacing G07 PCB set to the tube that came with my Centipede (so also G07). I got all connections back easy enough, but I'm not 100% sure about the two white wires coming from the metal casing that surrounds the CRT. I guess that's the degauss-coil ??
Do the wires go on the two pins near the mains power connection ?
Checked the manual but pictures are not clear and I'm not sure about the schematics.....
Thanks !
« Last Edit: February 09, 2009, 04:07:12 pm by Level42 »
Ummon
  • Trade Count: (+13)
Re: G07, where to put the white fires from the metal CRT casing ?
« Reply #1 on: February 09, 2009, 03:58:16 pm »
Two white FIRES, huh?  Heheheh.  That title is gooood.
Yo. Chocolate.
Stephen Hawking
Kevin Mullins
    • Me on Myspace
Re: G07, where to put the white wires from the metal CRT casing ?
« Reply #2 on: February 09, 2009, 05:19:44 pm »
Yes..... should also be a little black box nearby, that would be the PTC component for the degauss.
« Last Edit: February 09, 2009, 05:24:42 pm by Kevin Mullins »
Level42
« Reply #3 on: February 11, 2009, 01:06:03 pm »
Thanks Kev, that was the one I thought it would be !
I tried the "new" PCB set on my Centi G07 tube and it seems to work. At least I got an over bright screen (turned down the HVT pot). Haven't connected the video signals though...tonight !
Level42
« Reply #4 on: February 13, 2009, 04:42:07 pm »
It works ! :) !
Can't get a full size horzizontal picture though. Doing the cap-kit now and let's see if that improves it. Else it's carefully adjusting the width coil.
Question: Bob Roberts' instruction with the kit mentions a mod. I found some info about this on the net saying it was to prevent curl with some more modern game PCB's ? Would this be a benefit with my Centipede ?
Kevin Mullins
    • Me on Myspace
« Reply #5 on: February 13, 2009, 04:51:12 pm »
Be sure to use the right tool...... plastic.... otherwise you will break the core.
Honestly, I've personally only had that problem with the newer games (modern).
I would think with Centipede it should be OK.
And by "horizontal" do you actually mean "vertical" as if it was in the Centipede?
(horizontal = long side, vertical = short side)
Level42
« Reply #6 on: February 13, 2009, 05:19:27 pm »
Yes, I've got a complete plastic toolset I forgot to return to one of my former employers (no really !).
OK, I'll keep it original, it was working OK before the cap-kit so....
Horizontal and vertical are always referened to the base of the monitor isn't it ? Not the way it's mounted in the cab.
Anyway, yes when the monitor would be in the cab, I couldn't get the full height (=width) :D
Kevin Mullins
    • Me on Myspace
« Reply #7 on: February 13, 2009, 06:22:08 pm »
Well, yes and no.....  ;)
There are vertically mounted frames, which would make the vertical side the base....but yeah, you got the right idea.
Level42
« Reply #8 on: February 14, 2009, 07:05:48 am »
Well, I changed my mind (again) and did the mod, it was easy enough.
The good news is that after the cap-kit everything worked like before. I thought the monitor was a bit dim though. Checked B+ and it was only 95V. Could up it to 120V with the pot, but it was hard to get exactly 120V. I figure the pot is not that good anymore. Monitored it and it stays firm though.
Screen is nice and bright again. Also the width has increased because of this, but I still have to see if I can get it a bit wider.
Seems like the convergence is not perfect, but acceptable. So some adjustments and it can be mounted back into the Centi.
