Author Topic: Help de-casing Mag Monitor!?  (Read 2026 times)
BillyJack
  • Last login:August 17, 2025, 02:58:00 pm
  • Must...paint...cab...! Must...buy...marquee..!
« on: June 20, 2003, 01:00:51 am »
I've got a Mag DJ920 and I've removed it from the plastic case.  There were 2 copper plates (strips) attached (with glue/tape) to the plastic casing.  One on the top, one on the bottom.  BOth have wires running to the inside of the monitor.  The glass itself has 2 pieces of the same copper at the top and bottom of the monitor.  What do I need to do with the two strips from the case?  I'm not sure what to do , as it's sparked once (I powered it off / unplugged quickly, however the sparking did not affect the picture.)
Thank you so much for any help,
BillyJack
« Last Edit: June 20, 2003, 10:19:06 am by BillyJack »
Now I've had my head in an elephant, a hippo, and a giant sloth.
-Homer
spectre
  • -- banned --
  • Last login:April 07, 2004, 08:45:11 am
  • -- banned --
Re:Help de-casing Mag Monitor!?
« Reply #1 on: June 20, 2003, 12:08:03 pm »
 "as it's sparked once (I powered it off / unplugged quickly"
don't decase a monitor while it's plugged in...
LMFAO
-- banned --
BillyJack
« Reply #2 on: June 20, 2003, 12:16:37 pm »
LMFAO
I didn't decase the monitor while it was plugged in.  It was sitting there doing nothing then sparked.  I decased it, installed it, plugged it in, turned it on, about 30 seconds later it sparked.  I shut it down, fiddled with stuff, turned it back on to see if it was dead, it wasn't and it hasn't done anything since.
BillyJack
-Homer
spectre
  • -- banned --
  • -- banned --
« Reply #3 on: June 20, 2003, 05:56:46 pm »
ah, cuz u said after it sparked you unplugged it, but anyway...u probably shorted something out somehow, i dunno much about monitors sorry
-- banned --
BillyJack
« Reply #4 on: June 23, 2003, 09:25:38 am »
Ha... easy fix...  the two scary strips were to help ground the tube etc...  They weren't touching properly, so I re-attached them and used a little electrical tape.  NO MORE PROBLEMS!!! WOO!  The sparking was caused by static buildup on the tube jumping to the copper strips.
BillyJack
-Homer
