February 05, 2026, 01:03:17 am
My car has a tiny little LED on the rearview mirror to light up the shifter area.
Sardu - Maybe you should have a signature that says, "Not THAT Sardu"If you don't know what I'm talking about, look up NESticle, Genecyst, and Callus. (Oh, and Bloodlust Software)
Good suggestions guys, although I was thinking along the following lines and using a lighted ON or OFF system.Check this stuff out: http://www.elbestbuy.com/2hibrperfo.htmlIt would require me cutting a 2.3mm groove in the lightning bolts using some sort of dremel or router (very careful is the word!) but then I could turn ON or OFF as needed. I also like the fact that I am not using a BLACKLIGHT - those things get into your eyes and bother you I seem to recall, but maybe not.Ah the choices are endless and will certainly take time to work thru testing the options!As a side note, the link above also sells this LIVE TRACK system which really looks cool to add around the cabinet for detailing. http://www.elbestbuy.com/newlwimosy.html
Quote from: Missile on November 22, 2008, 01:11:35 amMy car has a tiny little LED on the rearview mirror to light up the shifter area. odd...does your car have a light to illuminate the clutch/brake/& gas pedals too...?who looks at the shifter to shift...?
