Author Topic: Can you connect an iPac to consoles?  (Read 1409 times)
mahuti
« on: June 06, 2003, 10:39:18 am »
Is there an adapter for the ipac to connect to various consoles? USB to Playstation or Xbox? Or is there some other encoder that can connect to various systems?
steve_pss
  • Last login:December 19, 2020, 06:56:53 pm
Re:Can you connect an iPac to consoles?
« Reply #1 on: June 06, 2003, 11:08:48 am »
The I-Pac works by using joystick or button signals to emulate a coorenspoding keystroke. So unless your console could utilize a keyboard for control (and I'm sure it can't) your out of luck.
Check around this site, there are a number of people that have hacked (modified) control pad innards to work with real controls.
anthony691
  • Last login:January 29, 2016, 03:10:23 pm
    • Lightgun.tk
« Reply #2 on: June 06, 2003, 01:31:41 pm »
One word: Dreamcast ;D
There is a device that allows you to input PS/2 into your DC ;D
It is cheap too! Whats the dead system now? ;D
Visit my MAME lightgun site:
http://www.lightgun.tk
mahuti
« Reply #3 on: June 06, 2003, 02:01:25 pm »
I seem to recall Playstation 2 having a usb port. Anyone with experience doing that?
Also, I heard that the xarcade had some sort of proprietary encoder that could handle output to multi systems.
Has anyone had experience with that?
Nervous
  • Last login:May 25, 2005, 08:48:50 pm
  • * sigh *
« Reply #4 on: June 06, 2003, 08:51:58 pm »
I know that the IPac won't work witn an XBox.  Bummer.
Hafta hack an XBox controller...
Hoe
  • Last login:September 05, 2004, 01:17:09 pm
« Reply #5 on: June 08, 2003, 12:59:47 am »
IPacs output scan codes... right?
You'd need to build a converter. You may be able to get away with a few 74 logic chips to rencode the serial pins. I'm not too sure on the actual communications of modern console controller ports (I miss the days of nes/snes using a 4021 for controler encoding)
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #6 on: June 08, 2003, 12:07:51 pm »
this device would allow an i-pac to be connected? how many simultaneous players. i have a 4-player ipac. could i get 2 players running off this deviece?
It's all about the Pentiums
mahuti
« Reply #7 on: June 08, 2003, 01:41:00 pm »
BTW the post with the link to the XArcade encoder is exactly what I'm talking about. I couldn't find a direct link to that anywhere on their site.
That' pretty much solves my dillemma.
