Author Topic: Xbox360 cooling mods you have seen before.  (Read 4249 times)
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« on: May 28, 2008, 08:23:40 pm »
controller shot for no reason.
The machine was bought used and the seal was broken by the last owner to install a NME chip. Knowing a 360 could red ring at any moment I decided to do some cooling mods.
Curls in the squat rack !?!?!
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
Re: Xbox360 cooling mods you have seen before.
« Reply #1 on: June 19, 2008, 09:44:45 am »
The best mod to install to almost guarantee not getting a RRoD is the X-Clamp mod.  One of my 360's gave an RRoD, I went out and purchased a new one.  A week later I did the X-Clamp fix on the broken one and it works perfectly now and has been for a long while now.
testicle187
  • Last login:January 24, 2026, 06:08:15 pm
« Reply #2 on: June 19, 2008, 12:43:34 pm »
I would never dream of putting X-Clamps on a perfectly working 360.  They are a last resort and normally they don't fix the problem permanently (although I have had one going for over a year now on the fix).  If it messes up though, they can be a great fix if the solder cools down in the correct position.
northerngames
  • Trade Count: (+18)
« Reply #3 on: June 22, 2008, 01:49:01 pm »
I know a good method.
I got mine in and it was used but it did not have the x-clamp fix or the red light problem.
I had turned it on for around 5 minutes and the rear fan port area felt hot as a hair dryer.
 I thought geez no wonder there burning up so fast and I thought to myself I dont even trust this and doubt I would get an hour of playing in before it burns it self up.
so I ordered a x-clamp fix and some arctic silver 5 even know it did not have the 3rol.
as testicale stated that he would never dream of doing that well he probably wished he would have did it before it even started and if so would never have the problem to begin and now hopes it does not happen again down the road becuase prevasive action was not taken prior.
 The stock heatsink actually dont even toach the chip like there made to there is an actual gap between the heatsink and the chip wich actually defeats the whole purpose of having a heatsink on there in the first place when left stock.
the x-clamp kit makes it sit and toach like it should be in the first place with the correct amount of force to pinch the heatsink and chip togther tight enough wich the stock clamps could never do.
the arctic silver 5 replace's the stock tar like play-do that actually was a waste to even put it on them to begin with and it contributed to the heating issue instead of helping it.
so I got my parts in took it apart and had cut out the rear fan grill on both the metal case and plastic case why?
it actually takes 12%-15% of the air flow away becuase the grills block the airflow somewhat.
the metal fan grill was removed becuase metal gets hot from the exuast heat constantly blowing on it  :timebomb: and holds heat so all that stock hot air heats up that metal grill and it holds it and after awhile the whole damn thing heats up like its a giant heatsink so by removing the metal fan grill it allows the airflow to improve and also allows heat to escape and not be passed around the whole inner console becuase the whole frame is warming up.
next thing to do is add two small wire on the motherboard to make the fans run at 12V constanty.  it is loud but they can also be set to 9v wich is a tad more quiter and still a way better improvement over the stock setting.
the aftermarket fans are junk and have burned up and caused damage in various ways to themselves the console case motherboard etc. the stock fan mod is the best fan kit really becuase it can be ran at 12V safely.
then you need to take a piece of poster board and masking tape and lay it where it covers your gpu heatink completely and connect it with the masking tape to your fan shroud.
for the CPU side you do the same but only cover half of the cpu and connect it to the fan shroud with masking tape.
then tape the sides where the heatsinks meet the fan shroud I also did where the fans meet the shroud just to get in that extra bit of suction.
then you download the cutout piece that gets placed down the center of the fan shroud to point the air where it needs to be instead of sucking from every direction this way it is focused on where it should be drawing from.
when left stock the air only gets pulled from the front 20% of the heatsinks and the rear barely get any cooling or suction strengh from the fans at all with this method it does the gpu 100% and around 90% of the cpu side.
by sealing this up like this it make's it have more of the vacuum effect where the air is sucking out much better and now nothing is restricitng it anymore now that the grills were removed.
heat rise's but it will not catch fire and with this method it does not get hot and it also sheild your dvd drive from getting to hot if it were left stock there have been known instance's where the gpu got so hot it ruined the dvd drive that site right above it.
there is also a Co-GPU kinda like the orignal xbox's MCPX chip if you add a heatsink on there it will drop it 4 degree's gaming and 7 degree at idle/dash over stock.
but after I did the x-clamp kit with arctic silver 5, cut  out the fan grills and added the 12 volt wires and the poster board trick with the shrouds I now can play for hours and when I place my hand back there now it feels like I am running a A/C unit in there.
the change from stock to now was just unbelievable on the difference it made for cooling it went from hair dryer hot to feeling like a A/C unit.
all parts needed can be had for under $20.00 and you will get your moneys worth for sure by doing these easy upgrades.
when you get the heatsink off to do the x-clamp kit use arctic silver 5 instead of the stock play-do I forgrot the actaull specs on the improvement over stock but I think it was around 17 degrees.
add them all up and it makes a huge overall difference when compared to stock.
« Last Edit: June 22, 2008, 04:15:11 pm by northerngames »
Edgedamage
« Reply #4 on: June 23, 2008, 07:58:39 pm »
Finished the last steps. I installed the talismoon whispermax fans. I did the ducting mods inside the box. And also added a switch for the fans to run under xbox control or 12v.
These mods might have not been needed as this box runs very cool and super quiet. It had no problem running GTA 4. The stock fans never sped up at all. But you never know about the Rrod that's why I did the mods.
northerngames
« Reply #5 on: June 24, 2008, 11:16:26 am »
12V is loud but there is a way to make them run at 9V constant wich I am considering becuase of the 12V noise level.
on your 12V fan mod did you cut your fan wires or bridge the 2 legs on the 2 chips on the motherboard itself?
« Last Edit: June 24, 2008, 11:22:45 am by northerngames »
Edgedamage
« Reply #6 on: June 24, 2008, 06:55:55 pm »
Yes the 12v mod is loud but so is the DVD drive. The whisper max is not that annoying when running at 12v. I got the 12v from the tab of Q3F1 seen here:
http://forums.xbox-scene.com/index.php?showtopic=613160
Hoagie_one
  • Um....whats a cabinet
« Reply #7 on: June 25, 2008, 01:40:57 pm »
This thread makes me sad.  We shouldn't have to do cooling mods on retail sold equipment.  Just sad.
northerngames
« Reply #8 on: June 25, 2008, 03:25:56 pm »
I agree I was amazed on how hot it got in les then 5 minutes and I did not trust it to even play it so I did the mods and all is good so far.
 I went through gears of war on hardcore within 3 days so I got some stright hours in and never had any problems with heating skipping or video glitchs.
« Last Edit: June 25, 2008, 03:28:04 pm by northerngames »
Edgedamage
« Reply #9 on: June 25, 2008, 06:56:22 pm »
Tell me about it!!!!!!!!!!!!!! I only got this box because a coworker sold it to me for a steal. And because it's modded, but to be honest I would have never bought a 360 for retail.
