Author Topic: mame CMD / mamewah help?  (Read 2894 times)
dizney
  • Last login:August 13, 2010, 07:51:16 am
« on: May 06, 2008, 05:33:43 am »
hi I'm running Mame with mamewah and some games namely r-type and bubble bobble are not working but they do work in mame32 the ROM directory is the same.
I'm not sure if i need to set something in Mame.ini Ive had a search around but not found anything.
this all started because i found out I'm no good at bubble bobble when i was at a gaming event for charity on Monday in wolverton milton Keynes, anyone here go?
also the reason I'm running mamewah and not 32 is because I'm not using great hardware in my bartop project but that's another post.
James
Ginsu Victim
  • Comanche, OK -- USA
Re: mame CMD / mamewah help?
« Reply #1 on: May 06, 2008, 08:25:51 am »
Are you using the same version number of MAME as you were MAME32?
If not, your romsets may be different.
dizney
« Reply #2 on: May 06, 2008, 09:04:41 am »
no they are not i guess that would be it but i am using the latest 125 version of mame i also had this problem with 124, where should i go from here, find out what mame32 i have and build that for mamewah?
Ginsu Victim
« Reply #3 on: May 06, 2008, 09:07:38 am »
whatever version your roms are for, get that version. The version of 32 they worked with, get the same version for standard.
Though if you're using an older computer, you might want to go even older in your mame version, then search here for how to rollback your romsets.
I use FastMAME .84 myself with mamewah and it works great in my cabinet's 733mhz.
dizney
« Reply #4 on: May 06, 2008, 10:18:30 am »
i did not know that worked like that i got a the roms from my xbox rom set so they are all over the shot im going to get a new rom set i did get mame 109 and r-type then worked so i guess thats sorted that.
Thanks again
dizney
« Reply #5 on: May 07, 2008, 02:27:12 pm »
just liked to say thanks i got a mame125 set tested the 2 games in question and they are fine, and it means im all upto date now Win Win.
cheers..
Ginsu Victim
« Reply #6 on: May 07, 2008, 02:44:04 pm »
If everything works great for you at this point, there's really no need to upgrade with the next mame release. Unless you're like me and you update your MAME roms with every release.
